Old 05-23-2019, 02:59 AM   #1
Jack
junkman
Jack's Avatar
Default china turbo oil drain or oil intake
just to make sure
big one drain small one intake?
looking for AN10 adapter for this - mine is too small
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 05-23-2019, 03:45 AM   #2
tryingbe
Boosting along.
tryingbe's Avatar
https://www.ebay.com/itm/Turbo-Oil-D...4AAOSwctJb36wd
85 GLH 367whp
00 Insight mpg > yours.
Old 05-23-2019, 04:13 AM   #3
Jack
junkman
Jack's Avatar
thank you
what do you use for oil inlet
Old 05-23-2019, 07:57 AM   #4
tryingbe
Boosting along.
tryingbe's Avatar
I assume you have a redblock?
https://www.ebay.com/sch/i.html?_fro...kw=t3+oil+feed
Old 05-23-2019, 11:55 AM   #5
Jack
junkman
Jack's Avatar
Yeah b230 block with oil coming out front of engine above alternator mount
Old 05-23-2019, 12:48 PM   #6
rb92673
The inlet on my T3/T4 was threaded and 1/8 inch NPT. I used this:
https://www.summitracing.com/parts/SUM-220446B
Old 05-23-2019, 12:52 PM   #7
Jack
junkman
Jack's Avatar
Nice did you use a copper gasket between?
Old 05-23-2019, 01:09 PM   #8
Stiggy Pop
Stiggy Pop's Avatar
you wouldn't, pipe thread seals on the thread. I'd suggest a quality teflon thread sealant over the TB-style grey RTV.
'79 242
943 pickup
Old 05-23-2019, 01:18 PM   #9
rb92673
Nope. Just screwed it in. If others are suggesting a thread sealant that might be a good idea. I also replaced the banjo with a similar metric to AN, but I don't know the size.
Old 05-23-2019, 01:50 PM   #10
Jack
junkman
Jack's Avatar
thanks just ordered along with https://www.summitracing.com/parts/sum-260487b
Old 05-23-2019, 06:48 PM   #11
culberro
culberro's Avatar
Careful with that socket-less hose, I wouldn’t use that for a turbo oil feed. The heat from the turbine housing will soften up the rubber hose, and it may fail.
Old 05-23-2019, 06:54 PM   #12
Duder
His Dudeness, El Duderino
Duder's Avatar
Don't use any RTV or sealant goop on a turbo oil inlet. Best option is a bolt on flange adapter with a gasket or o-ring to the top of the turbo, then a 37deg (AN) flare fitting to your oil line.
Big one is the drain, yep.
Old 05-23-2019, 11:04 PM   #13
122power
dude
122power's Avatar
Use JIC fittings instead.
I used the kinugawa kit, its only $20 bucks and has the pre made line and some fittings. May have to drill the inlet banjo bolt though as I did. It was only like .041" oil feed. Depending if you have a journal or ball bearing turbo.
Old 05-24-2019, 03:55 PM   #14
Stiggy Pop
Stiggy Pop's Avatar
I get it but also feel like this is advice for people who donít know how to use thread sealant properly. That said Iíve never had a turbo that had pipe thread on the inlet so idunno
Old 05-25-2019, 01:35 AM   #15
Jack
junkman
Jack's Avatar
too small
Old 05-25-2019, 04:28 PM   #16
Duder
Duder's Avatar
There is some truth to that. It's a "best practice" though and not worth risking clogging the very small internal oil passages IMO.
Old 05-26-2019, 10:24 AM   #17
cwdodson88
+1
The Build Thread
SVEA - PUSHROD TURBO!
Old 05-26-2019, 01:48 PM   #18
rb92673
too small
Sorry to hear that. I had the opposite problem, had the parts for the oil line and my first NPT to AN was too big.
