Old 05-28-2019, 12:29 PM   #26
dbarton
Dejected by Volvo
dbarton's Avatar
Originally Posted by Texas240 View Post
It does make difference. Im still using the mustang master on the stock 240 calipers. R calipers did brake better except the squeal was horrible on my car and turned into a slight grinding sound here and there after the brakes would get warm. But it does make a difference
My question was about the STEPPED bores.
It appears that the Mustang master has the same bore for front and rear ports.
But with Volvo, you have a stepped bore, at least from what I can gather in any MC prior to ABS. Maybe with ABS too.
From VOLVO: Dual circuit reliability. Volvos have a triangle-split dual circuit braking system, including a stepped-bore master cylinder. This means that if one circuit should fail, both front brakes and one rear will still operate, retaining about 80% braking effect with maximum directional stability.
From an early Greenbook for 1975+ 240:
Master Cylinder (tandem-type, step-bored), 4 cyl., 6 cyl.
Primary bore diameter: 22.3 mm
Secondary bore diameter: 15.75 mm
Does anyone know if going from the stepped Volvo MC to a non-stepped Ford MC makes any difference? Or if you just don't know, will ignoring this matter?
Dave
Old 05-28-2019, 12:32 PM   #27
dbarton
Dejected by Volvo
dbarton's Avatar
Originally Posted by DrZiplok View Post
I haven't looked, sorry. In our case it's actually more interesting for the front / rear bore ratios to look completely non-Volvo as we're attempting to get the EBFD in the ABS to think it's in an E46 M3.
As a datapoint, we did about 15 hours of our last 24-hour race on just the front brakes after breaking a rear caliper bracket. It made late trail braking a bit weird, but didn't seem to affect our lap times or overall enjoyment. So, probably not a huge difference.
Thanks. You posted this as I was composing my above post. That helps a little.
Old 05-28-2019, 10:36 PM   #28
Texas240
Prius Owner
Texas240's Avatar
I remember having this convo with you before about how the 240 master was stepped but the mustang wasnt.
93 245 LS Engine Swap Project
Old 05-28-2019, 10:45 PM   #29
2turbotoys
Salaminizer
2turbotoys's Avatar
The Mustang MC I bought was over a 1" bore, I bought it from Rockauto, and they had the bores listed. I bought the largest one. I revisited those MC's and most are not listed anymore.. I do not have it here, it's in my huge pile of LS swap parts at my friends shop. I will try to get the p/n this week.
What is the difference between a stepped bore and a non stepped bore?
2006 V50 T5 AWD 16 PSI +
Old 05-29-2019, 12:14 AM   #30
The stepped bore master was developed by Volvo to reduce the pedal travel and pressure required to stop the car in the event of a circuit failure. ABS masters are not stepped.
https://www.jstor.org/stable/4471799...n_tab_contents
Old 05-29-2019, 08:40 AM   #31
dbarton
Dejected by Volvo
dbarton's Avatar
So ABS masters are not stepped? Ok, that answers that question.
So then I guess all other 240 masters are Stepped.
Stepped bore means the front circuit has a smaller piston than the rear circuit.
Volvo REAR bore: 22.3 mm
Volvo FRONT bore: 15.75 mm
Old 05-29-2019, 06:34 PM   #32
mck1117
How is it? I'm in need of a master cylinder and will go big brake eventually, so I might just skip to the mustang master on the stock brakes. My car is non-ABS. What is it like with the mustang master and stock brakes?
mck1117 is offline   Reply With Quote
Old 05-29-2019, 09:29 PM   #33
DrZiplok
DrZiplok's Avatar
Just in case this confuses someone; the "FRONT" bore in this case actuates the rear brakes, and likewise the "REAR" bore the front brakes.
DrZiplok is offline   Reply With Quote
Old 05-29-2019, 10:39 PM   #34
Texas240
Prius Owner
Texas240's Avatar
Harder pedal, a little more effort to brake. Thats about it. Went from V70r front calipers back to stock 240 calipers. Lost about 6-8 pounds going back to stock. Was able to lock up the fronts now I cant with the stock. Was too lazy to switch back to a non abs master so I left it on. Im not complaining.
Old 05-30-2019, 07:05 AM   #35
photoman327
photoman327's Avatar
Following
Old 05-30-2019, 08:56 AM   #36
dbarton
Dejected by Volvo
dbarton's Avatar
If you're referring to NON-ABS, pretty sure you're wrong.
The below diagram is how my '84 242 is from the factory.
Are you referring to ABS brakes? Maybe that's different.
Dave B.
Old 05-30-2019, 11:13 AM   #37
DrZiplok
DrZiplok's Avatar
Yes, my turn to inject confusion, sorry.
Old 05-30-2019, 11:54 AM   #38
dbarton
Dejected by Volvo
dbarton's Avatar
Ok, cool. I have not yet found a good diagram for 240 ABS brakes, but I did find this Greenbook diagram for 700 brakes. I suspect it's similar to the 240.
EXCEPT: I would kind of expect the fronts to have individual brake lines going to each front caliper, not a "T" as shown here.
Dave
Old 05-31-2019, 01:14 AM   #39
DrZiplok
DrZiplok's Avatar
The ABS-II routing is pretty boring. There are two lines from the master that go to the ABS valve block; one for the fronts (V), one for the rears (H).
There are three lines that come out of the ABS valve block; front right (r), front left (l), rear (h).
Here's a really good shot of the valve body; you can see the front circuit on the left and the rear circuit on the right: https://www.flickr.com/photos/47640483@N04/5154785667/
