Old 05-27-2019, 03:10 PM   #1
redblockpowered
redblockpowered's Avatar
Default M90 slave cylinder failure or overtraveling?
I just finished putting an M90 in my 940. I used a dog dish flywheel instead of the stock dual mass unit, with 940 diesel clutch setup and turbo pressure plate. I shimmed the pivot ball 3.25 mm (measured with a digital caliper). Around 200 miles afterward I suffered a loss of clutch pedal pressure after holding the pedal down for 15-30 seconds. Looking underneath revealed that the slave boot had blown off and pissed fluid all over the ground. Obviously this means the slave cylinder is allowing fluid through. This morning I took the slave off (which I had given a new seal installed in the correct direction before mounting) and found... nothing of note. The seal looked fine, the bore was clean and without scoring. Did I not shim the ball enough, allowing for the slave to overtravel, or do I simply have a failed slave cylinder that looks and feels normal?
1993 944 B230FT/M90
1991 245 B230FNA/M47 LeMons car
1991 245 B230F/M47 street car
Old 05-27-2019, 03:27 PM   #2
Lankku
Lankku's Avatar
I think the piston has come so far out that the seal is outside of the cylinder.
444 -55, 145 Express -71,
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -90 "B6284T", 965 -93 B6304T
Old 05-27-2019, 08:05 PM   #3
sbabbs
sbabbs's Avatar
Longer slave push rod to the fork is what I do. I take a longer bolt and grind the ends so there round.
Old 05-28-2019, 01:53 AM   #4
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
maybe it came out due to installing a new clutch, is now back into position and left you with a rubbercollar full of brakefluid.. i once had that...
Old 05-28-2019, 04:21 AM   #5
Lankku
Lankku's Avatar
It's a possibility.
And now that I dig my memories, there have been 2-3 cars with a new stock clutch and the rod had to be extended because the piston came out.
Old 05-28-2019, 06:23 AM   #6
crogthomas
crogthomas's Avatar
The pivot needs to be spaced about 6mm to work properly in my experience.
crogthomas is offline   Reply With Quote
Old 05-28-2019, 10:37 AM   #7
okoye
okoye's Avatar
I found out that the slave cylinders have different internals. A fix is the 5mm trick for the pivot or 20mm pushrod extension
Old 05-28-2019, 12:54 PM   #8
shoestring
shoestring's Avatar
Does anybody know what the proper stroke length is for the slave cylinder pushrod? We had it measured at 19mm, at which point the head of the slave cylinder piston is 6mm deep in the cylinder, and the clutch worked correctly. That put it 2mm below the bevel that's at the end of the cylinder, I assume to aid assembly at the factory. Point is that the piston is well in the bore, at least at this stroke length.
Old 06-04-2019, 10:47 PM   #9
redblockpowered
Changed slave cylinder AND bumped the shim up to 1/4". Scientific? No. Will it solve the problem? Yes.
Old 06-05-2019, 09:24 AM   #10
shoestring
shoestring's Avatar
Youthful optimism.
Old 06-05-2019, 12:40 PM   #11
Dirty Rick
Dirty Rick's Avatar
If the piston comes too far out of the slave it can tip and jam (not return).
If the piston is too far down the slave (relaxed) it might bottom out as the clutch wears, but that is an easy fix to adjust the push rod length.
Old 06-05-2019, 01:06 PM   #12
sbabbs
sbabbs's Avatar
I've had the clutch fork go too far and bind with the throw out bearing and stick the clutch in at the drag races no less. This happened after I made my shaft longer. How did I fix that? I zip tied a piece of wood behind the clutch pedal so I then couldn't push it too far. So keep that in mind, long shafters.
Old 06-06-2019, 02:49 PM   #13
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
omg.. this fix is more tbstyle than everything i ever saw! :D
Old 06-06-2019, 08:39 PM   #14
redblockpowered
...Yikes.
Old 06-13-2019, 05:07 PM   #15
sbabbs
sbabbs's Avatar
Ran 12.61 with it yikey bro's..
Old 06-16-2019, 08:47 PM   #16
ryanfay
more bounce to the ounce
ryanfay's Avatar
My clutch fork that came from Europe has a Kevlar pivot ball bushing in it. I think without it the 3mm spacer is more like 6 or it'll hyperextend the slave.
ryanfay is offline   Reply With Quote
Old 06-17-2019, 09:36 AM   #17
redblockpowered
~500 miles in after the update posted above. The 6mm spacer puts the release point in a far more normal place and there's no evidence of leakage.
Old 06-17-2019, 09:37 AM   #18
shoestring
shoestring's Avatar
1/4" spacer with 1/4" hole, drilled to 5/16", purchased from local Ace Hardware, provided the correct result. Piston stroke is approx. 18mm.
