Old 05-27-2019, 10:39 PM   #1
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Location: Kingsville, MD/Morgantown, WV/Your mom's house
Default 140 exhaust size choice
Need to build an exhaust system for the 142
I have 10' of 3" pipe and clamps as well as a muffler already. Will this be OK? I know its wicked overkill and will probably hurt performance due to the total absence of backpressure.
1971 142 DD/beater/fake racecar
Originally Posted by stick70
It's all just lifter noise til it comes out the side.
vwbusman66 is online now   Reply With Quote
Old 05-28-2019, 07:37 AM   #2
sksmith
sksmith's Avatar
I would say too big for a stock B20.
Steve
Old 05-28-2019, 09:01 AM   #3
JohnMc
JohnMc's Avatar
It's too big. But there is no performance advantage to a smaller exhaust system.
There are tuning effects of the exhaust manifold/header/merge styles and distances and tubing diameters. But after all that, all the rest of the exhaust system needs to do is stay out of the way.
Since you have it, might as well? 2.25 or 2.5 is probably about all a heated up B20 would ever need.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 05-28-2019, 09:10 AM   #4
240240
Cocaina space cowboy
240240's Avatar
Why stop at 3"?
Shoot the poop!
Old 05-28-2019, 02:34 PM   #5
Jack
junkman
Jack's Avatar
Why stop at 3"?
why does he need 10 feet when routing it up through the hood only takes maybe 1.5
Old 05-28-2019, 03:00 PM   #6
283SD
Too big
Old 05-28-2019, 04:20 PM   #7
240240
240240's Avatar
Why even pipe, just flip the header, use some spacers to clear the carbs. theyre almost symmetrical anyway.
Old 05-28-2019, 04:21 PM   #8
Originally Posted by 283SD View Post
Too big
It'll nevar spewl.
Old 05-28-2019, 04:29 PM   #9
Jack
junkman
Jack's Avatar
good point or route 4 inch into the passenger compartment
Old 05-28-2019, 04:41 PM   #10
Just get the 2" sport system from VP and be done with it.
http://212.247.61.152/US/main.aspx?p...cle&artno=071K
Old 05-28-2019, 06:20 PM   #11
240240
240240's Avatar
That's too good of an idea.
OP doesn't want $22 of steel pipe to go to waste.
Old 05-28-2019, 08:08 PM   #12
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Correct
Old 05-28-2019, 08:48 PM   #13
Originally Posted by vwbusman66 View Post
Correct
Sell it on here to somebody with a Turbo car for $14.99.
Old 05-30-2019, 04:56 PM   #14
jwernerny
jwernerny's Avatar
A good first step is a 142E exhaust, but building is more fun. I say 2.5" straight off the joining from the manifold into a 2 chamber, Flowmaster. No restriction. Lots of noise. Terrible at low RPM with a cam with a lot of overlap.
It also confused a cop hearing the car coming, seeing a yellow 145 with white (fiberglass fenders and cage) slide through a left at the end of an off ramp. He just shook his head and pretended not to see anything.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 05-30-2019, 09:44 PM   #15
I used 2" system on my 123gt. Bought a 142E front pipe. Then had a local shop make up the rest with only one muffler. Had a nice bark to it and was in the affordable zone. I think it was a couple hundred?
Old 06-06-2019, 03:19 PM   #16
klr142
Turbo, what?
klr142's Avatar
Simons Sport system, 2" is fine if you don't mind quiet performance at a reasonable price. Otherwise, 2.25" is fine. If you are doing head work, bigger camshaft, more compression, more fuel, you might benefit from 2.5". The larger you go, the louder it'll be with no help to anything else but more weight.
Old 06-06-2019, 03:51 PM   #17
240240
240240's Avatar
Op went with 6" twin freightliner stacks instead
Old 06-06-2019, 04:32 PM   #18
klr142
Turbo, what?
klr142's Avatar
SWEET! Pics or ban!
Old 06-06-2019, 05:52 PM   #19
classicswede
Volvo upgrades
For a mild B20 2.25 is about the ideal size. For a well worked B20 then you will likely want 2.5 inch
Going too bit will loose you low and mid range power
