Old 05-29-2019, 05:36 PM   #1
swizzy
Default Rare -976 Ecu hates Chipping
Hi Guys,
Does anyone know why nobody offers chips for the 0 280 000 976 Ecu?
It's in my '96 Lpt together with a 219ezk.
The chips i had caused stalling/idle issues and ran lean under boost -> stayed in closed loop.
Mods:
016amm in 012/3" housing
green giants 440cc/42lb injectors
20T
TTV/240mm Clutch
3" downpipe-stock cat-2.5" exhaust
Greetings from Switzrland
Janis
swizzy is offline   Reply With Quote
Old 05-29-2019, 05:54 PM   #2
300+hp on the shelf club
i don't think we had that ecu in any cars here. Maybe try checking in with thelostartof or sbabbs? See what they have for you?
Old 05-29-2019, 06:02 PM   #3
sbabbs
sbabbs's Avatar
Do you have the stock chip? I'd read that and then modify the stock bin. Or put in 984 modified bin. Or 967. Something close number wise should be lh 2.4.4 later bin type. Other problem I see is your 3 in AMM and your injector size. I'd up the injectors to 550cc's what I run with 3 inch tube with 016 guts in it with gasoline. 750cc with 3 inch amm and E85. No lean problem here with stock chip.
Quick fix put stock 016 back in and try that with 440's.
Old 05-30-2019, 04:28 AM   #4
swizzy
Thanks guys for the quick reply!
I put the stock chip back in and it runs fine, doesn't like boost that much though.
3000rpm - 12psi - afrs at 12.8/1 should be a bit richer to be safe!
if someone makes chips for this ecu then i think it shouldn't be a problem with the injectorsize.
Old 05-31-2019, 04:29 AM   #5
ipdown
Член на форума
ipdown's Avatar
Hi, this is indeed rare version. If you find a way to read the stock chip, we can take a look and provide an XDF for TunerPro. This is likely one of the last versions with finer emission friendly tunes and maybe immobilizer responder.
ipdown is offline   Reply With Quote
Old 06-06-2019, 09:18 AM   #6
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
actually... that's not tooo bad. it would be nice if it was a little fatter. is it leaning out further the higher you go, or getting richer? You could put the stock amm back on there...
Megasquirt Tuning!
