Old 05-30-2019, 10:43 PM   #1
Texas240
Prius Owner
Texas240's Avatar
Default softer 240 V8 STS mounts
Has anyone found a replacement in a softer rubber or poly than what sts offers in their mounts? I made a good amount of difference going with a higher stall converter in my 4l60e but there mounts and the poly that is offered still translates a good amount of vibration at idle through the the car. Even worse with a/c on.
93 245 LS Engine Swap Project
Old 05-30-2019, 11:19 PM   #2
apachechef
Burnt Sierra Madre
perhaps ask STS?
Dammit, Lummert.
Old 05-30-2019, 11:20 PM   #3
Texas240
Prius Owner
Texas240's Avatar
Originally Posted by apachechef View Post
perhaps ask STS?
His response 3 years ago was, we buy in bulk and they won't sale a softer mount to you.
Old 05-30-2019, 11:24 PM   #4
apachechef
Burnt Sierra Madre
Originally Posted by Texas240 View Post
His response 3 years ago was, we buy in bulk and they won't sell a softer mount to you.
Damn, thought they would at least tell you if it was an interchange to some common part.
Poly rubber bushings are made by energy suspension
call them up, but I'm thinking getting it out to examine is not easy
Old 05-30-2019, 11:59 PM   #5
enzedal
I’m doing an LS swap right now in a 240....going with 1989 Corvette clam type and they bolt to the LS swap mount plates
1978 262 Bertone pickup truck
1961 F85 Olds
1982 244 with 350TPI Chevy (dd since '91...225Kmiles)
1953 Studebaker coupe
enzedal is offline   Reply With Quote
Old 05-31-2019, 07:39 AM   #6
M.H. Yount
M.H. Yount's Avatar
See if Scott will at least give you the dimensions/model # of what's in there -- then you can shop around on your own for replacements. I made my mounts out of the rear upper torque arms - and lucked out when I ordered the poly bushings for mine. FWIW, they were a black poly. They seem softer compared to the blue and red poly bits used in other places on the car. Use an OEM rubber tranny mount with some modifications to keep it from moving around as much. Smooth/quiet - and with the 3rd torque mount on the driver's side head -- virtually no movement under torque/decel.
Old 05-31-2019, 11:58 AM   #7
cosbySweater
cosbySweater's Avatar
what cam do you have? also are you sure the converter is seated properly? my 6.0 with a stock cam was smoother then any redblock ive ever owned with the sts mounts installed. I had vibrations in mine at first and it ended up being a messed up flex plate
1990 Volvo 245, Efan conversion, tcam, Aw71 FOR SALE
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
2013 VW Passat TDI
Old 05-31-2019, 09:17 PM   #8
Texas240
Prius Owner
Texas240's Avatar
Stock truck cam. Its been like this from that start off getting the engine/trans out of a wrecked avalanche. Was never taken apart. The vibration has since settled a little with the new circle d 2800 stall converter but is pretty harsh with the ac on. In park or neutral the engine super smooth. I put a can of beer on my intake manifold cover I made and it doesn't move.
Flex plate looks fine.
Old 06-01-2019, 01:00 PM   #9
A tough rowing ho
Do a tune up, sounds like you got a miss
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 06-01-2019, 05:37 PM   #10
Texas240
Prius Owner
Texas240's Avatar
nope. Maybe 8K miles on plugs, wire, coils. 2-3k on fresh oil change. Drove the car today. Vibration at idle didn't seem as bad as before.
Old 06-02-2019, 04:15 PM   #11
77volvo245
77volvo245's Avatar
Where was the truck hit?
STSmachining
Old 06-02-2019, 08:50 PM   #12
Texas240
Prius Owner
Texas240's Avatar
I honestly dont remember. That was 4 years ago when I went to the salvage yard. They had the engine out already. I did see the truck when I had them grab the pedal. I think front end. What are you thinking.
Old 06-03-2019, 11:25 PM   #13
77volvo245
77volvo245's Avatar
Hard front end collisions can cause issues with the crank being unbalanced, all depends where it was hit etc etc. Just throwing out ideas.
Old 06-03-2019, 11:28 PM   #14
Texas240
Prius Owner
Texas240's Avatar
who knows. I vaguely remember seeing side impact.
Old 06-04-2019, 12:00 AM   #15
77volvo245
77volvo245's Avatar
Our 4.8 spun a center thrust bearing for not reason, the truck was a front impact collision. We drove it for about 10k miles before the bearing spun
Old 06-04-2019, 12:00 AM   #16
cosbySweater
the crankshaft on my original 5.3 i swapped in was all kinds of ****ed up and bent. shattered the oil pump
Old 06-05-2019, 11:32 AM   #17
Texas240
Prius Owner
Texas240's Avatar
We'll see what happens in another 3-4k miles.
Old 06-10-2019, 07:31 PM   #18
klr142
Turbo, what?
klr142's Avatar
Raise the idle speed a little.
