Old 06-06-2019, 04:31 AM   #1
PAULDRIVER
Default Volvo 96o part number needed
Does anyone know the part number by any luck, for my 1996 volvo 96O crankshaft ?
Its a 2.9L 24v whiteblock
My local volvo dealer said "we dont give part numbers out"
I need it to find the spec of the splines, as i need to make a crank for my motor, and a part number will save some $
WHALE OIL BEEF HOOKED
(use Irish accent)
PAULDRIVER is offline   Reply With Quote
Old 06-06-2019, 07:23 AM   #2
poulrais
poulrais's Avatar
Does it have to be a 1996? I think I have a 1994 crank on the shelf.
1990, Volvo 740 16v +T
poulrais is online now   Reply With Quote
Old 06-06-2019, 07:25 AM   #3
redblockpowered
redblockpowered's Avatar
You can get parts manuals for all classic Volvos at gcp.se. I don't know why you would be making a crankshaft, that seems terribly involved to do, but you can get part numbers through GCP.
1991 245 B230FNA/M47 no thread: secret LeMons car technology abounds
1991 245 B230F/M47 no thread: very boring (320k!)
Old 06-06-2019, 08:02 AM   #4
Broke4speed
Broke4speed's Avatar
I use this site for all my part number inquiries. It's awesome.
https://www.volvopartswebstore.com/
Old 06-06-2019, 08:30 AM   #5
poulrais
poulrais's Avatar
I have 1 crank from a 1994 on the shelf and another one I can take off a 1992 B6304 engine that is out of the car if you ever need a crank.
Old 06-06-2019, 09:38 AM   #6
PAULDRIVER
Thanks broke 4 speed, i found the part number i need.
What it is im trying to find the actual crank specs, as my motor will run around 800 hp,
I wanted to know if my crank would take the power ?
and also use the part number to identify the crank splines if i need to have a crank made.
What sort of power will my crank take, before it lets go, as i want to be safe as opposed to sorry ?
Old 06-06-2019, 02:00 PM   #7
Lankku
Lankku's Avatar
Stock crank will take over 1000hp and 1200Nm easy. Use B6284T or FWD B6304/B6294 crank if you want to have a lighter one. Bearings and timing gear spline are the same.
444 -55, 145 Express -71,
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -90 B6294,
245 -90 "B6284T", 965 -93 B6304T
