Old 06-06-2019, 10:54 AM   #1
A tough rowing ho
Default Timing adjustment for 100 octane gas
So I have a reliable supply of non ethanol 100 octane gas (@$7/gal.) Can I just bumped my whole timing table in MS by say 5%? It seems a little doggy now out of boost.
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 06-06-2019, 11:36 AM   #2
dbarton
Dejected by Volvo
dbarton's Avatar
I'll be shocked if anyone actually recommends a percentage of advance increase. My only experiences in finding a precise difference involved advancing until I could detect pinging with lower octane and then doing the same with 100 octane. Listening by ear is not the most precise, but it's a start. A better method is to build yourself a DET CAN setup.
Here's the basic idea: https://www.youtube.com/watch?v=mPau_BrALI4
It's been 10 plus years, but I did run exclusively 100 octane in my stroker 2.6 motor for a couple years and I think I gained around 10 degrees of knock resistance at 20 psi using 100 octane versus 91.
Dave B
Old 06-06-2019, 11:49 AM   #3
JohnMc
JohnMc's Avatar
Not a tuner, did not stay at a Holiday Inn Express last night. But not all advance is good advance. If you advance too far, and the fuel (and the rest of the setup) is really ping/detonation resistant, you'll start to make less power, but still continue to make more stress. And this is not always very evident unless you're on a dyno. And know how to interpret the results.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-06-2019, 01:20 PM   #4
dbarton
Dejected by Volvo
dbarton's Avatar
I think he meant bumping the boost RETARD table, not all advance upward. Hopefully he knows the difference.
Old 06-06-2019, 01:36 PM   #5
superboosted
You wish you had some..
superboosted's Avatar
100 octane is only $5 here,and i bump the base timing on the Amazon to 22base while running it. Probably doesnt help but i just kind of want to boast about my cheap gas
-1966 122S 4-door
Originally Posted by centason View Post
You may get detonation and the kool-aid man loves 940s
superboosted is offline   Reply With Quote
Old 06-06-2019, 01:38 PM   #6
JohnMc
JohnMc's Avatar
E85 is half the price, and acts like 110 octane. Or better. :D
Old 06-06-2019, 02:11 PM   #7
A tough rowing ho
Only place that has E85 here is on base. Yes I was talking about multiplying the timing table x 1.05
Old 06-06-2019, 03:52 PM   #8
740atl
educator monkey
740atl's Avatar
I'm going to ramble on a bit with this because I've been thinking about this for a while.
I think you have to tread carefully. Is this a +T 8 valve? Before I had ms3x I used det cans exclusively to monitor knock.
I had a friend drive the car while I listened in on a set of det cans. At the time, the car was really loud, so "hearing" knock even with the det cans was a bit like listening to the ground for hoof-beats while a cargo train rolled by. I would advance the timing a bit, make a pull on a deserted road and both listened for knock and tried to see if the car felt faster. I had no way of estimating how much power I picked up so one method I used to kind of get an educated (maybe not) guess was to use the torque feature in megalogviewer and guesstimated a torqueincrease every time I advanced the timing. (it was a really sketchy way to go but it was the only thing I had to work with. More on this below) The road was flat, I was starting the run in the same place each time etc. I advanced the timing until I heard a bit of knock, then backed it off a couple degrees. I was never really comfortable with the 8v head. With conversations with others much more knowledgeable and experienced than I, the 8v head didn't start really making power until it was knocking a little bit. I deliberately avoided knock at all costs around the torque peak (about 3500rpm for the 8v), but past the torque peak into the 4's and 5000's rpm a little bit of knock was ok.
I recommend the friend to do the driving for you so you can listen in. Driving, tuning, and listening in for knock all at the same time is a little nerve wracking. You're concentrating hard to listen to see if you're engine's about to blow up and miss the red light and hit the kid on his cellphone standing in the middle of the street.
The 16v was a different animal. (16V +T...) First thing is the torque peak is higher (4-4500rpm). Cylinder pressure is at a maximum at torque peak so that's why it's nice to keep it from knocking there. With e85, I found I could add an additional 10 degrees beyond my already lame and probably too conservative pump gas map. This time I'm using the ms3x knock chip to help sort out the knock from the noise. I've forced the car to knock just to know what it "sounds like" or rather looks like when I'm observing the logs by using cheapo 87 octane. It's a possibility that I've added enough timing to actually go past MBT... I don't have a way of doing a spark hook test on the street, but the 10 degrees of extra timing keep making more power. I will experiment more with it this summer at the track. The one thing I found at least with e85 is that being too rich will cause the thing to knock
Obviously, the best way to really know how much timing it use is to take it to a dyno. Assuming you already have a decent base tune with your afr's well sorted, it should be a simple matter to add the timing and figure out what it'll do with a spark hook test.
I get the idea that dyno time is expensive. Which is probably why I haven't been to the dyno since 2007 and I've replaced 5 redblocks that I've done blowed up.
The other way to do this is just take it to the track. Make a pull, verify that it's not knocking on what you've currently got, advance the timing a smidgen, make another pull and see if the car's faster.
From earlier... what we really need is a system that gives a reliable estimate of engine output so we can advance the timing and get a realistic/reliable/repeatable measure of engine performance while street tuning. I tried a couple things with megalogviewer... observing RPM/sec, m/s2, torque, horsepower and the data was always... ALWAYS too noisy to make any REAL determination that that particular run was an improvement over the previous if you catch my drift.
I then got the idea to use the fancy GPS speed thing that tunerstudio sells... maybe I could get a speed vs time reading... never worked.
Some future ideas... rig up a VR sensor to one of the front wheels to calculate wheel speed vs rpm. Tunerstudio offers this as an input for the torque calculation. I haven't gotten around to it yet but I think that's my next avenue to explore... because basically I'm cheap and want to go fast but don't have the money for dyno tuning.
EDIT.... if this is for a b21FT then everything I said (most of it) doesn't apply. With 7.5:1 compression ratio you probably don't even need the 100 octane. You probably haven't reached MBT yet on pump gas.
Old 06-06-2019, 03:52 PM   #9
240240
Cocaina space cowboy
240240's Avatar
Keep advancing until it blows up, then back down a few degrees and you got it right
Originally Posted by Cwazywazy View Post
I believe the D24 was designed by hitler himself.
Old 06-06-2019, 05:59 PM   #10
A tough rowing ho
The last time on the dyno I thought my peak torque was higher between 3800-4300 area.
I've had it off the road slapping a bad paint job on it. I may get to drive it tonight if I can locate a missing wiper spring, I found the little clip that the spring hooks on that I thought was awol, I dropped the spring somewhere down in the engine bay. I'm tired of ****ing with it. I stitch welded some of the window and door openings and added 2) 2"x1/4" x1/8" C Channel subframe connectors. This really seems to tie the whole car together. I started on the paint job the Wednesday before memorial day and have been at it every day since
Old 06-07-2019, 11:36 PM   #11
lummert
lummert's Avatar
Adjust timing until you get the best seat of the pants run. Then back off a bit.
