Old 06-06-2019, 06:33 PM   #1
autoloclys
Default best cam for a b230F +t, daily driving
at the risk of asking "how much boost can stock support"
I have a B230F squirter engine that is going to into my LH2.4 +t wagon, is there any consensus on the best cam for spirited daily driving?
autoloclys is offline   Reply With Quote
Old 06-06-2019, 06:40 PM   #2
Marvelous3
Who engineered this?
Marvelous3's Avatar
Daily driven? Probably a T cam. Want to have some serious fun? Enem V16.
Old 06-06-2019, 07:07 PM   #3
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
ipd turbo cam is probably the easiest to lay hands on
Megasquirt Tuning!
Old 06-06-2019, 07:30 PM   #4
Marvelous3
Marvelous3's Avatar
^this is probably the best suggestion for what most people want on this board.
Old 06-06-2019, 08:33 PM   #5
Tonyte619
I have a 91 740 wagon with a +T and 15G
With the T cam i could do brake stands and the car left hard off the line.
With an IPD turbo cam, its a little laggy, but crazy fun past 3K rpm.
still drives fine off boost under 3k, but not nearly as torqey with the T cam.
Tonyte619 is offline   Reply With Quote
Old 06-06-2019, 09:23 PM   #6
quillc
yv1a.com
quillc's Avatar
Pretty much anything other than the M cam that the engine came with.
As stated before, T seems to work well in a +T configuration as you have more compression in an NA motor.
An A, V, iPD turbo or other cam would be good as well. More duration + more lift = more fun (up to a limit).
Chris
www.yv1a.com
Old 06-06-2019, 09:31 PM   #7
oldschoolvolvo
oldschoolvolvo's Avatar
^^good suggestions
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 06-06-2019, 11:30 PM   #8
Wren
Porkchop Sandwiches
Wren's Avatar
A cam is a nice improvement and cheaper than the IPD if your budget is tight.
Old 06-07-2019, 01:19 AM   #9
RvolvoR
honestly, t-cam
Old 06-07-2019, 06:03 AM   #10
autoloclys
Thanks for the advice.
Since the T cams seem harder to find the IPD turbo cam sounds like the next best option
The ipd turbo cam description makes it sound like it's focused on high revving performance @>5000 tpm. But It also improves low end? For daily driving I'm assuming idle to 4000 is where I care most about
Sorry for a basic question. Cam tuning is new to me
Old 06-07-2019, 08:59 AM   #11
oldschoolvolvo
Post in wanted section...shouldn't be too hard to scrounge up a T cam.
*Edit: here is one for sale
http://www.forums.tbforums.com/showthread.php?t=349446
Old 06-07-2019, 02:37 PM   #12
bobxyz
bobxyz's Avatar
Automatic or Manual? What turbo? How much low speed / stop-n-go daily traffic?
Are you OK with running/shifting at higher RPMs most of the time so that you can have best high RPM performance, or would you prefer less performance and more sedate shift points?
Old 06-07-2019, 10:10 PM   #13
autoloclys
M47 converted from an aw70 so the ratio in the rear end is low. Turbo is a 13c at stock boost. I live in a city so a high strung engine is not ideal.
Old 06-07-2019, 11:16 PM   #14
It should spool nicely with the 373s.
Same gearing as the 240 Turbos came with.
Nothing wrong with the much malinged T cam in a daily driver.
Old 06-08-2019, 12:25 AM   #15
bobxyz
bobxyz's Avatar
^^^ agreed.
The late factory 240 turbo auto's had a 3.91 rear end. The 240 turbo manual's used 3.73. All the non-turbo auto's had a 3.73, so your converted auto will be the same gearing as the factory 240 manual turbos. In other words, you have Volvo's choice for a manual turbo DD.
The 13c is a smaller turbo, and is better suited to a lower RPM range. Keep your eye out for a good 15G - a bit more power but still boosts well at lower RPMs. The factory '85 turbos were a T3, which is an older design, with a bit higher RPM range.
The T cam was Volvo's choice for a turbo DD cam.
You certainly want to change to a turbo cam from your NA M? cam. In a simplistic view, the intake stroke on a NA engine sucks the fuel/air mix into the cylinder. At higher RPMs, the momentum in the intake manifold helps push air into the cylinder. On a turbo engine, the boost pressure also pushes the fuel/air mix into the cylinder. With this, you need a cam with less overlap than a NA cam to avoid the boost pressure pushing the fuel/air mix straight through the cylinder and immediately out the exhaust.
Old 06-08-2019, 03:38 AM   #16
Originally Posted by bobxyz View Post
^^^ agreed.
Would you please stop it with the facts and common sense, this is Turbobricks home of the hopeless hapless dreams.
:sheesh:
Old 06-08-2019, 04:55 AM   #17
classicswede
Volvo upgrades
If limited to used Volvo cams the A cam is the best bet for a daily.
If aftermarket the T3 grind is a great cam for a daily that still has decent low end but a much better mid/higher end
Old 06-08-2019, 12:02 PM   #18
mocambique-amazone
Good evening Dai.
T3 cam?
I need a little help, where you will find a T3 cam?
Which company grind this?
Regards, Kay
Old 06-08-2019, 12:51 PM   #19
Ok while you are a city driver. The car has a 3.73 rear which likes a few rpms. It is fine with a T cam which is volvos choice. But in my experience it is even better with a cam that gives the engine more mid and high rpm power. The low gearing will still give you fine low rpm torque but having a better mid and top end will put more smiles per mile.
A Volvo A, or B cam is a good choice. If you go aftermarket I have only good experience with enem cams. The V15T would be what I suggest. I've been running that in my turbo for many years now.
Old 06-08-2019, 04:05 PM   #20
bobxyz
bobxyz's Avatar
Do you care about emissions? If not, you can go with a wider variety of cams, and tradeoff worse idle for better higher rpm performance. Compared to swapping in a +T'd engine, swapping cams is easy. Pick one and give it a try, while keeping an eye out for a different cam choice, and a 15G turbo.
Old 06-10-2019, 11:00 AM   #21
drift256
My T cam with 15G was fun and really torquey. I also noticed that I could brake boost and blow the tires off with the T cam, but once I swapped in the IPD cam it doesn't really build any power until about 3500rpm but breathes way better up top. Both cams were fun for different reasons.
Anyway I do have a T cam for sale. I think I have someone pending purchase though.
drift256 is offline   Reply With Quote
Old 06-10-2019, 11:55 AM   #22
JW240
All idiot, no savant
JW240's Avatar
Running T cam on my +T now. Dat torks. For a DD, not bad, but I do miss the punch a good cam gives.
Was running a V cam, which I liked better, but cam had some damage and decided to try the T cam from my parts pile.
I'd only put any effort in sourcing a decent/real/non-stock cam if you are planning to do supporting mods. Check if valve springs are any good, play around with ignition timing and mixture. The B230F generation i'm running has weak valve springs from factory and until I change those no fun cam will work, heck even now valves like to float.
240 | 1991 | 341K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
940 | 1992 | B230FB
Old 06-10-2019, 12:02 PM   #23
redblockpowered
redblockpowered's Avatar
T or V seem like the best bet for a regular street car with a street car powerband.
1991 245 B230FNA/M47 no thread: secret LeMons car technology abounds
1991 245 B230F/M47 no thread: very boring (320k!)
redblockpowered is online now   Reply With Quote
Old 06-10-2019, 12:57 PM   #24
This^
You never notice the torque loss below 2500 because no AW7x ever operates at that low RPM.
Old 06-10-2019, 06:34 PM   #25
cosbySweater
cosbySweater's Avatar
T cam
1995 Porsche 993
2013 VW Passat TDI
