Old 06-11-2019, 01:07 PM   #1
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Default Remote Oil Filter Help
Does anyone have an idea where I can find a good quality filter relocation kit for my B20. I'd like to move the filter away from my header while at the same time making the filter more accessible.Any help would be appreciated.
Steven
1966 Volvo Amazon, 1968 Volvo Amazon Combi, 2004 VW R32 Golf
R32RennSport is offline   Reply With Quote
Old 06-11-2019, 01:24 PM   #2
carver
Redblock for life.
carver's Avatar
Maybe start here...
carver is offline   Reply With Quote
Old 06-11-2019, 01:33 PM   #3
R32RennSport
Outlaw Amazonian
Originally Posted by carver View Post
Thanks
Old 06-12-2019, 09:55 AM   #4
rb92673
This kit has everything I needed for a b230FT. Not as nice looking as that other thread, but it gets the job done for cheap. With this kit I was able to use the remaining Volvo filters I had as well as use bigger Ford filters as they use the same thread.
https://www.summitracing.com/parts/s...85-1/overview/
Hose is long enough to put the filter almost anywhere.
Old 06-12-2019, 01:18 PM   #5
R32RennSport
Outlaw Amazonian
That looks great, just what I need and nothing I don't. At that price I could afford some 90 degree fittings and nicer lines as well.
Old 06-13-2019, 10:39 AM   #6
dbarton
Dejected by Volvo
dbarton's Avatar
That's probably the kit I used years ago originally when I put my filter behind the front bumper. I don't remember if 8 feet was enough hose, but that will be close if you want to mount the filter in the same place.
Dave B
Old 06-15-2019, 12:51 PM   #7
lummert
lummert's Avatar
Kit meant for a Ford?
Old 06-15-2019, 02:25 PM   #8
dbarton
Dejected by Volvo
dbarton's Avatar
Yes. Ford uses 3/4-16 thread on the oil filter. Same as Volvo redblock.
Old 06-16-2019, 12:36 AM   #9
rb92673
The Summit kit has an adapter that allows it to fit several different threads on the engine, but it only fits 3/4-16 for the filter. You can order bigger Ford filters or use up your stock of Volvo filters.
Old 06-18-2019, 06:29 PM   #10
johfraser
Maybe mount on the inside of the frame near the front. Spend the money for crimped on swivel fittings instead of hose clamps.
johfraser is offline   Reply With Quote
Old 06-18-2019, 06:45 PM   #11
R32RennSport
Outlaw Amazonian
I found a decent generic relocation kit through NAPA. It did need a little clean up around the threads but I like the orientation of the outlet/inlet ports. It did not come with hose, but I will most likely upgrade the fittings and hose as suggested. Since I'm relocating the battery to the rear of the car I think I will use the battery tray compartment to house the filter as it will be the most accessible and safe area available to me, also the shortest distance for house routing.
