Mostly just a clean up and inspection for the bottom end. The head is getting ported and it's getting (possibly reground) GLT cams.
wow, this would be a perfect time for rods that dont bend...
Fantastic work man. Post a picture of that indestructible whiteblock bottom end. The crank supporting is so tough looking in those motors.
Are you porting the head yourself or are you sending it out? What are the specs on the cam grind? Total lift mm and overlap?
I'm porting it myself. I haven't nailed any cam specs down, but I've been looking at something like 10-11mm of lift, ~320 degrees of measured duration, and an LSA of ~100 degrees.
