blakemcelroy2000
- Oct 18, 2017
- Portland OR
Hey all,
So my radiator end tank finally reached the end of its life. Small crack, small leak right below the upper hose. Planning on replacing the radiator, but while looking at my car, I noticed that only the transmission cooler hoses (drivers side of radiator) are hooked up. The passenger side ports (where the oil cooler lines should attach) are completely empty, and the hoses are nowhere to be found. Is this a common delete? Should I get the radiator with only the trans cooler ports? Thanks.
