Old 09-01-2004, 05:19 PM   #1
adrianpike
adrianpike's Avatar
Default "Chainsaw" Heater Core Swap
So let's say you're heater core is failing. How do you know, you say?
  • Leaking Coolant
  • Smell of antifreeze with heater running
  • No defrost or heat
  • Some cases are bad enough that your windows will actually fog when you try to run the defrost
So you've got two or more of those symptoms, you've decided to do the heater core swap, and all you've heard about the job is how much a pain it is. Perhaps you've heard rumors, or in my case, even been given diagrams, that there is "a better way". Well, my friends, (droogs, if you will) there is a better way, and I'm here to show you how to do it, in true pictoral fashion.
There are a few names circulating around for this "hack", which it truly is.
The Chainsaw method, the Dremel method, and sometimes, it's just called "cutting a big hole in the side of the heater box".
Basically, to replace the heater core the classic way, it requires removing the entire heater assembly, which to do, you usually have to remove the dash. Removing the dash in and of itself isn't really all that horrible, it can be done. It's the removal of the center console and guages, plus the myriad of little electric glitches that will present themselves once you've put everything back together, that really gets you. Here is a photo of an assembly in it's natural environment, highlighted for your viewing pleasure.
So now, I shall speak of my better way. It's not for everybody, as it involves permanently modifying parts of your car that are in some ways better off unmodified, but it makes the job night and day easier.
Pros:
-Shaves hours off core replacement.
-Less headache with wiring
-Easy to replace in future
-Don't have to de-pressurize A/C system
Cons:
-Heater will be less efficient
-Ethical issues with a "quick fix"
Tools/equipment required:
-New Core
-Dremel or close-quarters hack saw
-Eye protection if you're using a powered cutting tool
-RTV Silicone
-Foam, with one adhesive side (weatherstripping works)
-Screwdrivers, socket wrenches, etc.
-Vacuum (not required, but desired)
-Sandpaper (optional, see below)
Here's a diagram of the cut you'll make, much thanks to kyle242GT:
And here's a photo outlining the same cut:
Note that the cut has to be curved around the top to create a slot for the core tubes to slide out, as shown in the next photo:
Now that I have shown and described the cut, I'll do a step-by-step process on how to swap in a new heater core, using the "chainsaw" method.
1. Remove the front passenger seat. This is optional, but it makes your life a lot easier.
2. Remove the fabric on the underside of the dash in the passenger footwell. It's held in by little black clips. All you have to do is turn them 90 degrees and they come out.
3. Remove the center console passenger-side trim, as well as the front trim. The side trim is held in by a screw at the top side of the front trim, and a clip, again which you turn 90 degrees, at the bottom of the front trim.
4. Remove the glovebox. Six screws, open the glovebox and they're on the lip.
5. Remove the passenger kickpanel. Again, this is optional, but you might as well, it's easy to pull out. Pull up the rocker trim, peel back the rubber weatherstripping around the door, and pull out the kickpanel.
6. Pull back the carpet as far as you like. This is optional, but a good idea, as it's very likely that some coolant will come in your direction.
7. Here's where it gets fun. Now you should be able to make out the heater unit, and now you get to remove the "oh %$@*" clips that hold the panel on the outside of the unit. Here's a photo showing where they like to hide.
They like to shoot off into the void when you pry them off with a screwdriver, so have something ready to retain them. I found that a magnet right next to the clip would grab it before it got a chance to zoom off into god-knows where.
Keep in mind that you may have to loosen the vertical support bracket for the dash on the passenger's side of the console to get at all the clips, and to remove the panel. I've outlined the bracket in the following photo:
Note that it has already been unbolted and moved out of the way.
8. Now that you've got the clips off, remove the panel that they were holding on. It may take some persuasion. Now you'll see the blower fan:
Pull the blower fan off by removing the clip. The clip slides up or down relative to the shaft, and the clip is narrower in the middle. The shaft is slotted for the clip to fit. Slide the clip until the shaft is in one of the larger holes and pull it out.
9. You might want to sand down the shaft to help the fan slide off it.
10. Slide the fan off the shaft. Be careful, I've got a cut on my finger that says it likes to bite.
11. Now remove the three screws holding in the backing plate for the fan.
12. Now go have a beer, because the goal is in sight! While you're at it, drain the cooling system.
13. Let's cut! Make the cuts mentioned earlier, and when you're done, this is what you should see:
Make sure and wear eye protection, and cover anything you don't want plastic dust on. A filter mask is a good idea here too.
14. Now that you see the core, remove the two coolant hoses that run to the top of it, being careful not to spill too much all over yourself (you did drain the coolant, right? ). Have a plug or rag ready to stopper the flow. The core slides out your hole easy as can be, but it may require a little bit of extra cutting for it to be butter-like. Don't cut too much, you've got to seal that hole back up in a few minutes.
15. Clean out the heater core area of any coolant, dirt, or plastic chips and dust that will have accumulated in there. This is where the vacuum comes in handy.
16. Slide the new core in the way the old one came out, and hook up the coolant lines to it.
17. Now, using an RTV silicone or equivalent sealing adhesive, glue and seal the plate that you cut out back into place, and let the glue dry.
18. Reassembly is the reverse of removal. Don't replace all of the trim until you test it out and make sure that all of your re-wiring is correct, especially the blower motor. This is a scary one to find doesn't work once you get everything back together.
19. No matter how well you vacuumed everything up, the first time you fire up the blower motor, a little bit of plastic chips and dust will come flying out. Don't worry about it, unless it lasts more than a few seconds.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 09-01-2004, 05:28 PM   #2
the poi
Has been
the poi's Avatar
I don't even have a 240 and I find this helpful. Great writeup, and I'm not even sure about the "less heater efficeincy", enough RTV ought to make it good as new. Sounds like the way to go
Old 09-01-2004, 05:55 PM   #3
kyle242gt
Still has a Volvo
kyle242gt's Avatar
Good job!!! ... though personally, I think the 240 core replacement should remain shrouded in mystery and disinformation to better separate the hardcore volvo maniacs from the wimps. Otherwise, the supply of solid low mileage cars, "for sale, runs great, needs heater core" might dry up.
Originally Posted by stickbuilder View Post
You don't grow wealthy by working your ass off.
Get a life.
I killed a 5.044!
kyle242gt is offline   Reply With Quote
Old 09-01-2004, 08:57 PM   #4
rwturbo
rwturbo's Avatar
Default yeah
Thats the way I have been doing it for about 5 years, done 15 so far and no complaints, it has become a 1.5 hr job. however I leave it up to the customer if they want it done the correct expensive way or shortcut cheeper way, as for I would never charge the customer the full given time, and so far have had only one want it the correct way.
rwturbo is offline   Reply With Quote
Old 09-01-2004, 11:36 PM   #5
boostdemon
creative mastermind
boostdemon's Avatar
nice, this will be a perfect article for our new "preventive maintenance" article section... to include things like poly bushing installs, seal replacment, headlights through a relay, other tricks we've learned etc..
"the best way to get the right answer on the internet is not to ask a question; it's to post the wrong answer."
1983 242 TIC Flathood
1986 745 GLE
1988 Toyota Pickup 4x4
2001 V70 T5
2004 V70 R
"Flathood" Owners | Motorcyclists | Guitarists
boostdemon is offline   Reply With Quote
Old 09-02-2004, 12:03 AM   #6
adrianpike
adrianpike's Avatar
Cool, I wasn't sure if there was any interest in maintenance articles, but I figured, what the hell. Let me know if anybody's got any ideas to fill in any holes or finds any typos, other than that it's pretty much complete.
Old 09-02-2004, 01:35 AM   #7
vurbo
cool adrian, nice job!
-Elliot
-adrian Really needs a turbo, now that he's megasquirting...
Originally Posted by Snoop Dougy Doug
My guess is if you think hard enough, your brain will catch fire.
vurbo is offline   Reply With Quote
Old 09-02-2004, 04:21 PM   #8
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
thats a champion hack right there. there's a trick to 700 series heatercores as well, but I won't be sharing that one with anyone, it remains more of a rite of passage..
Megasquirt Tuning!
Old 09-02-2004, 09:04 PM   #9
stylngle2003
stylngle2003's Avatar
adrian...thats so cool, gotta be one of the biggest timesavers around!
-Billy
1990 Mazda Miata (track toy)
Old 09-03-2004, 03:05 AM   #10
boosted
boosted's Avatar
ahh, the 240's seem to be built AROUND the heater core
-1998 V70r AWD
boosted is offline   Reply With Quote
Old 09-03-2004, 02:20 PM   #11
Default How about this suggestion?
If you take off the dash you can get to the heater core from the top of the heater unit. That would be a lot less to cut. Then you just slide the core right out the top. Then you won't have to do as much disassembly of the console area. Plus with the new core installed the area to cover up won't affect the efficiency of the heater at all.
Nice job for an alternative method Adrian!
Old 09-03-2004, 03:14 PM   #12
adrianpike
adrianpike's Avatar
Well, aside from the problem with removing the dash (in my case, removing the guages would be a biznatch) there would actually be a signifigantly harder cut to make going from the top. I'll try to explain with a diagram (viewed from the side)
Those braces keep the core from moving forward and back in the housing, and they would be a beast to cut through. You have to kind of nick the edges of them to cut the side panel, and that's pretty annoying. It would be nice to pull out the top... especially if the vent/speaker hole in the top was big enough..
Old 09-04-2004, 02:44 AM   #13
v240tic
v240tic's Avatar
I don't see the problem, last time I changed the heater core "the propper way" it took me less than 3 hours. (but then I just might be a "hardcore" volvo mechanic).
Stein Ove Vikeboe
Norway
'80 244 DL USA (Currently under reconstruction)
'86 740 Turbo Intercooler (Rusting in peace)
'97 940 LPT Wagon (Daily Ride)
240 Turbo by R-sport (Norwegian page)
volvo@vikeboe.com
v240tic is offline   Reply With Quote
Old 09-08-2004, 01:57 AM   #14
volvorod85
volvorod85's Avatar
I can get the dash out of a 700 series in an hour or less, center console and all. Now putting it back together, that takes up words of...oh 4-5 hours, depending how how you installed all of your electrical goodies. personally, im taking the dash off....again....cause the new heater core of 2 months....is leaking. *yelling and a sigh of whatever*
Mark
But a very good deminstration none that less! This wouldnt be the first car ive seen 'modified' for ease of heater core replacement.
2019 Buick TourX <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1982 Austin Mini <-- Wifeys toy
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 09-08-2004, 12:49 PM   #15
adrianpike
adrianpike's Avatar
I guess you're a hardcore mechanic, but even the most hardcore of us get a little impatient when it starts pouring rain all over your shop, and the yellowjackets are literally flying into the spinning blade of your Dremel, because it's the only dry place for miles.
And volvorod:
Oh yeah on the putting back together. Taking everything apart is fine, but putting it back together (correctly) is a real biznatch. It's always cool when you put everything back together and have a screw or two left over. Or especially when your blower motor doesn't work.
So this thread has been around for a few days now, I guess it's almost time to zip it up and send it over to Dana... Anybody got any last additions to make?
Old 09-08-2004, 10:41 PM   #16
Tenacious Todd
We call people like you at our shop (HACKS) .
2013 C30 Polestar
1998 C70 Coupe
Tenacious Todd is offline   Reply With Quote
Old 09-09-2004, 01:06 AM   #17
The Aspirator
It's a girl!
The Aspirator's Avatar
Originally Posted by adrianpike
Hahahaha, I LOVE the use of "VOLVO" font! I know it's not true old school volvo font, but it's what the new advertisements use. I've got it on my computer also.
Very sweet little write up you've done here! If I ever have to do a heater core swap I'll DEFINATELY be reading this one again. I like your use of pictures and really like how you outlined and highlighted everything important. Great job!
So how's it working? Nice and HOT? Not that it really gets cold in a pacific northwest winter, but it sure gets cold enough to want the heater bad enough!
John
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 09-09-2004, 12:52 PM   #18
adrianpike
adrianpike's Avatar
Yeah, it works just fine. If I were doing it again, I would have got some wider weatherstripping to fit around the core for more of an airtight seal and therefore more heat, but my car never gets over about 60°, so it's not going to be scalding anyways. As it is it works great, let me know if you want to check it out sometime. Defrost is nice to have again.
I call people who have a shop to work in (SPOILED) . But thanks for the compliment.
Originally Posted by dictionary.com
hacker
1. A person who enjoys exploring the details of
programmable systems and how to stretch their capabilities, as
opposed to most users, who prefer to learn only the minimum
necessary.
2. One who programs enthusiastically (even obsessively) or who
enjoys programming rather than just theorizing about
programming.
3. A person capable of appreciating hack value.
4. A person who is good at programming quickly.
5. An expert at a particular program, or one who frequently
does work using it or on it; as in "a Unix hacker".
(Definitions 1 through 5 are correlated, and people who fit
them congregate.)
6. An expert or enthusiast of any kind. One might be an
astronomy hacker, for example.
7. One who enjoys the intellectual challenge of creatively
overcoming or circumventing limitations.
Definition 6 and 7 are most appropriate in this sense, although number three works as well.
In my original writeup, I specifically said that this isn't for everybody, and those who have the time and patience to do it the correct way will be better off swapping cores the correct way. For those of us who care less about the work and more about the results, this method is ideal. Just in case you haven't noticed, this is in the "article composition" section, not off-topic. If you've got something useful or positive to say regarding heater core replacement and repair, say it. Otherwise, go post somewhere else, this isn't the thread for personal comments as to my ability or aptitude for automotive repair.
Old 09-09-2004, 12:57 PM   #19
Tenacious Todd
I am A Volvo tech I was just admiring your work you did save a lot of money doing it yourself and that has to be comended for doing tit yourself..
Old 01-21-2011, 06:00 AM   #20
MARS
MARS's Avatar
Sorry to dig this up from 7 years ago, but all the links for the pics are dead, it's 8f out side and my heat is randomly blowing steam. Does any one have these pics?
One of mine:
MARS is offline   Reply With Quote
Old 12-15-2014, 03:07 PM   #21
Koston740
Koston740's Avatar
is this for 2 or 7 series?
90 745 w/ b230ft- Holset He351cw, TLAO chips, eBay ic, Delphi 65's, bmw oil squirters, spec stage 2+ clutch, t5 WC E85
Feedback thread:
http://forums.turbobricks.com/showthread.php?t=236339
Koston740 is offline   Reply With Quote
Old 12-16-2014, 09:20 AM   #22
thelostartof
unbalanced chemical
thelostartof's Avatar
2 Series
Old 03-12-2016, 06:54 AM   #23
TestPoint
TestPoint's Avatar
Any chance of getting the 12 year old picture links back up?
Ford V8 Conversion Manual -
Old 08-14-2020, 03:53 PM   #24
Eglacias
Default Get the pictures for this post that, it’s so essential.
I would hate to do this job without the photos. Can the original poster throw those back up there! Man, I PayPal you 15 bucks to do it :-)
If I never hear back, I’m going to re-post the entire original paragraph with my own pictures to update the site
Eglacias is offline   Reply With Quote
Old 08-14-2020, 08:27 PM   #25
2turbotoys
Astro Zombie
2turbotoys's Avatar
I don't think it saves that much work. I just did it the regular way using this: http://cleanflametrap.com/heater_core/ and a couple other things I googled since my car is older than the one in the link.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
