reduction by 1 3/4" up front and 1.5" in rear is about as low as you'dwant to go and be able to drive the car as a DD on the roads in most places. Unless you go with coil overs that allow height adjustment.
I went with the new style IPD Sport Springs. Lowers frt by 1 3/4" and rear by 1.5" Low enough and I would not want it any lower for my purposes,.
I'd suggest the 242 GT shock tower brace plates while you're at it as well as IPD sways and adjustable panhard rod of some type.
Also plan on rebuilding the suspension and steering pieces (IE replace all the bushings , tie rod ends, lower ball joints and upper strut mounts to name a few) if you haven't done so already.
Lowering a car on 22+ year old rotted out/crapped out susp bushings and steering componentsis *not the way to go*............and can be unsafe.
You need a "good foundation" to start with before doing further susp mods such as lowering.
Thanks for the reply!
Yes, i thought about the same, ~40mm lowering springs, probably Lesj?fors.
And a bright idea came to my mind yesterday night. My car can carry 5 people, has a big trunk and a trailer hitch. When fully loaded, i don't think that the lowering springs will hold up well. A pneumatic cylinder next to the shock absorber would do the trick pretty well in the rear. What do you think?
I was against any strut tower brace for a DD, because in a side accident not only one tower will move drastically, but two.
But if you guys really recommend it because the towers are not that strong i may do it.
For the sways I think I'll do the ghetto double sway mod, because the IPD ones are hard to find here and it is too expensive to ship here.
Stiffer sways (double mod) are really needed, the car rolls really bad...
I can make adjustable panhard and torque rods myself, but I don't know how the guys will tolerate that at MOT. I have to make them factory looking.
Is strenghtening the lower control arms and trailing arms required for a safe DD? I can do this myself, not a big job.
