Old 08-02-2009, 10:34 PM   #1
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Default The li'l 780 project of '09
If any link is broken, please let me know, until then please go to my PhotoBucket 780 Project Page
My 780 headlamp mod thread My Mod Thread
Started the project last year actually just gathering parts. Started putting it all together the middle of June. Lots of setbacks (oh, so many setbacks) Rain mostly.
I'm just hoping for somewhere in the area of 250-275HP. Nothing extreme, just drivable enjoyment.
If anyone has suggestions, I'd like to hear them.
Now, if I can just finish the projector lamps...
Basic updates:
Rear Sway Bar Install
Painting
New Grille
S.A.M. Strut Tower Brace
Side Marker Install
AC condenser fan ALA Mr. Bill
RSI stage 1 cam with RSI adjustable cam sprocket currently @ -2°.
New front cam belt cover. (Mine disintegrated into dust, literally)
"New" Turbo T3 .48 A/R I bought about 10 years ago, but only used for a summer.
Ported 90+
Mikes Chips (Injection & ignition)
4 flow matched 52#/576cc model INJL55 injectors from Racetronix
External CBV (Forge)
3" intake
3" 012 AMM
Airaid AA720-431 air filter http://www.airaidsales.com/AirAid-Un...ters-PRD9.aspx Tucked up behind the bumper
under the passenger side headlamp.
ATP UIWG Ultimate Internal Waste Gate (3" outlet)
NPR Intercooler
Volvo 2 speed electric fan mounted in the stock mechanical fan shroud with 2-speed relay. Low speed side in the radiator using the
"over heat" port. High speed control will be in the upper radiator hose.
3" turbo back exhaust custom made and installed by EurodesignMK with Magnaflow muffler and CAT.
VDO OIL 80PSI pressure gauge and sender.
VDO Oil temperature gauge. Sensor will be installed in the big assed banjo bolt for the oil filter relocation arm.
AEM Wideband
G-Valve
Pics:
Project link at Photobucket
My Photobucket page
Originally Posted by 740freak View Post
how psi a stock can support?
Originally Posted by speedn_j View Post
I think this might be my chariot if I can jew the price down.
1990 780t Kind of Modded 1994 945t Pegz, Tintz, Hidz.
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
"Lister, you are a polyp on the anus of society." - A.J. Rimmer
Ursan is offline   Reply With Quote
Old 08-02-2009, 10:42 PM   #2
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Old 08-03-2009, 12:06 AM   #3
auditechjs
Clever words here
auditechjs's Avatar
Sweet.
-1990 780 Bertone-M46 N'stuff
-1994 945 Turbo. Stock.
-2012 Triumph Tiger 800 w/ABS.
Originally Posted by mr brick driver View Post
Do you realize this is a rare car. From what i can see you ruined the eblems, the door lock cylenders, and casued about an additional 1000 in work for someone who wants to actally paint this car. I don't get it. It needed the upper surfaces painted and you completed f-ed the whole car.
auditechjs is offline   Reply With Quote
Old 08-03-2009, 01:23 AM   #4
stick70
All the gauges
stick70's Avatar
nice, i have a gauge panel just like that in my s70
Kyle and the "Projects" -- '84 242 TI -- '66 220 S -- '89 Supra Turbo -- '84 Rabbit GTI -- '91 Honda Beat
Old 08-03-2009, 04:31 PM   #5
doucheNozzle
doucheNozzle's Avatar
Looking good!
So is that 2 oil filters?
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 08-03-2009, 10:22 PM   #6
Ursan
Ursan's Avatar
2 filters, yes.
The issue I'm having is dialing in the right boost. I think the G-valve may have had it as a little loose makes almost no boost, a little tight & it blows hoses off.
Better hoses than HG though, eh?
Old 08-03-2009, 11:56 PM   #7
doucheNozzle
I'm intrigued! What's the advantage of this? Where'd you get the kit to run that?
Old 08-04-2009, 12:57 AM   #8
Vol242vo
Vol242vo's Avatar
It adds about a quart of extra oil capacity without the need of a deeper sump or expensive pan. Also better filtration.
Derek - 1980 242
Old 08-04-2009, 09:32 AM   #9
Ursan
Ursan's Avatar
This. Also, I'd rather *not* crawl under the car to change them out. I simply unbolt it from the bracket, hold them over a bucket & remove one at a time. I don't replace both of them. If I could, I'd install one of those remote oil pan bungs. Though I haven't seen them in a while.
If I wanted to get sick about it, I could get the bigger 3001 filters which are even bigger.
Or even still, we have Caterpillar filters here at work that are 14" long with the same base. But that's way WAY overkill.
Old 08-04-2009, 12:23 PM   #10
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
your call is pretty neat!
Mr.Borrie is offline   Reply With Quote
Old 08-04-2009, 09:24 PM   #11
Ursan
Ursan's Avatar
call?
Old 08-04-2009, 10:02 PM   #12
Volvo Dan
Volvo Dan's Avatar
I just love the 780s... That looks like a load of fun!
Dan Wildey
1991 940 Turbo Wagon 'Daily Driver'
1999 C70 Convertible, NGK Iradium's, IPd Sways, IPd SR5T Intake, EuroSport Exhaust
1996 855 (Wifey)
1988 744 Turbo... Soon to be done...
Rebuilt B230ft (.030 over), T3/T4, 3" Exhaust, B-G Springs, Bilsien Shocks/Struts, IPd Sways, IPD Chasis Brace, Custom strut brace, Bar & plate IC, MBC, Autometer Boost and A/F ratio gauges,K&N Cone filter w/ heat shield, Blaupunkt Head unit w/ JBL 12", 850 Front Seats
www.volvospeedshop.com
Volvo Dan is offline   Reply With Quote
Old 08-14-2009, 10:25 PM   #13
Ursan
Ursan's Avatar
Default Updates
V-band ATP 3"
V-band with UIWG
V-band Ditto
Exhaust side. Exhaust side
Photobucket Electric fan mounted in stock shroud Upper hose, 95°/100° switch. Switch is grounded back to the thermostat housing.
A Little noise, but I'll get a better recording tomorrow(ish).
If any of the links are broken, just go here:
My 780 Photobucket page
Old 12-12-2009, 01:22 PM   #14
Ursan
Ursan's Avatar
Finally, as promised, another vid. But I'm not sure I like the sound quality
Old 12-12-2009, 01:27 PM   #15
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
That's sort of a girly car isn't it?
Crazychopstick is offline   Reply With Quote
Old 12-15-2009, 02:24 PM   #16
Ursan
Ursan's Avatar
see that vapor? Pure estrogen.
Old 12-15-2009, 03:05 PM   #17
amerbritcan
Hnnnnnng
amerbritcan's Avatar
hahaha
EDIT: also, courb?
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 01-19-2011, 03:26 PM   #18
Ursan
Ursan's Avatar
It's still running for all interested.
Added E-Codes
Old 04-01-2011, 04:53 PM   #19
Ursan
Ursan's Avatar
Default Recenter pics
Oil temperature sender
The long lost pic of the oil temperature sender located in the big banjo bolt in the oil filter relocation deally.
E-Code head lamps on the 780
The E-codes.
Spoiler
I spoiled my car.
catch can
The catch can.
Catch Can,Greener IS better
Because greener is better.
Old 04-01-2011, 05:18 PM   #20
amerbritcan
Hnnnnnng
so uh... 2009 project huh. looks good.
Old 04-01-2011, 05:36 PM   #21
2fast4u
2fast4u's Avatar
now dyno it...
1993 940T
2005 RSX Type S
Originally Posted by badvlvo View Post
Sounds like you are afraid of the horse cock Kenny.
I will freely admit that yes, yes I am. and I'm not ashamed of that fact.
Originally Posted by MrBill View Post
im skeptical... i hope this isnt your last post. famous last words, rite? "anyone JB welded this?"
2fast4u is offline   Reply With Quote
Old 04-02-2011, 03:02 AM   #22
Bassrocker88
Bassrocker88's Avatar
puuurddy!!
Never ending projects...
-82' 242 Turbo - New Project
-88' 240 - Daily Driver Project
Bassrocker88 is offline   Reply With Quote
Old 04-02-2011, 01:44 PM   #23
You must mean because they are so gorgeous, they appeal to women as well as men, right?
Old 04-03-2011, 08:23 PM   #24
Ursan
Ursan's Avatar
No, someone I work with accused me of driving a girly car.
Mind you, this guy drove a Honda mini van.
Old 04-03-2011, 08:23 PM   #25
Ursan
Ursan's Avatar
Originally Posted by 2fast4u View Post
now dyno it...
80WHP.
