LC4CARL
Aero challenged
- Sep 8, 2008
- Vancouver, WA
It all starts with an idea that won't go away, right?
Here's the deal: I found a '92 940T, 200k miles, "runs fine." After a mild part-out (Hydra's, etc) the car would be essentially free to me.
Swap the turbo motor to my '87 245 / M47.
As I understand it:
The 2.4 to 2.2 swap doesn't sound too bad. Not sure about finding a 2.4 harness for the 240 though. The 940 ecu may be chipable? Speedo?
http://forums.turbobricks.com/showthread.php?t=230687
The '92 would have the bigger rods, and desirable exhaust manifold.
The M47 would likely die under any abuse and a T5, or other, would be in the future.
The head from my '87 would need to be swapped on along with the distributor. "B" cam OK?
The T motor would come with the oil return and oil cooler stuff.
I'll need a different header pipe.
Will the 940 cooling units fit in a 240?
Wide band O2.
Clutch.
Future:
Swap the 3.31 for a 3.73.
Aforementioned T5.
Boost silliness ensues...
What am I missing? Brilliant idea or not so much?
Thanks!
As I understand it:
Wide band O2.
Clutch.
Future:
Aforementioned T5.
Thanks!
