volvohyes
- Jun 26, 2019
- Charlotte, NC
Hello TB,
After months of internal debate between swapping either a 93+ B230FT or B230F+T in place of my current slaptastic motor in the 92 wagon, I saw an ad for a good running 95 NA motor from an EGR 940 for cheap with 191k and jumped on it, therefore my path was decided: B230F+T.
Based off what I've read, my eventual goal will be around 300 whp. Initially it will be less of course but I will build up to that. I also need it do be dd and long road trip reliable.
For now, I'm thinking that while I accumulate the rest of the turbo parts, I swap the new motor in and keep it NA since I'm can't have thr car out of service for too long. However since I already have the engine out, it would be really easy to prepare it for a +T. Currently I plan on drilling, and tapping the oil drain 1/2 npt. Then I'll do a fitting that goes to 10 an and then put a 10 an cap on it to seal it temporarily. I was also planning on checking the oil pump transfer tube seal thing, and doing the other seals on the engine. Also gonna delete the EGR (just need to swap exhaust manifold right?)
Beyond that, I'm unsure how far I should go. Should I replace/check the oil pump? Check bearing clearences? Do a complete rebuild with new bearings and hone cylinders and new rings? Head work?
These are some of the questions I have before I start and am hoping those with more knowledge and experience can help.
