Old 01-28-2018, 12:44 AM   #1
VolvoNutt
K-jet Newbie
VolvoNutt's Avatar
Default 240 Strut Tower Brace
‘92 245 DD, for the front suspension, If I were to use Yoshifab’s GT strut tower/firewall brace & their lower chassis brace.
Would it be necessary for anything to go between the two strut towers themselves? Or would that be overkill?? When let’s face it, this is a DD not a race car......or should I forgo the GT brace from Yoshi and buy the crazy expensive kaplhenke 240 strut tower brace?(when it’s back in stock)
Or Could I run wagonmeister’s Strut tower brace with Yoshi GT brace?
Thanks for the guidance, I just want to do this right the first time :>)
VolvoNutt is offline   Reply With Quote
Old 01-28-2018, 12:57 AM   #2
EivlEvo
You can use a brace or not use a brace. Sort of like staged stiffening. Lots of the STBs don't work with the GT bars iirc.
Old 01-28-2018, 02:12 AM   #3
VolvoNutt
K-jet Newbie
VolvoNutt's Avatar
Then where is the best bang for my buck going to be? STB or GT? Look I realize I will never have a monster engine pumping out huge HP #ís or anything like that, this car will never see a track.
That being said I do want my ďplayĒ car to be fun to drive and for me that means it should corner on rails!! Or as near as possible a volvo station wagon can :-)
So I put sway bars on, now on to the next step. Where should I invest my hard earned money? I think lower chassis brace is a no brainer, but what about in the front strut - firewall area???
Educate me!!!
Old 01-28-2018, 02:40 AM   #4
Disco Inferno
Disco Inferno's Avatar
Educate me!!!
Strut tower -> firewall braces became standard on Australian 240s to stop them falling apart on our roads, so if you want to improve it beyond unlikely to fall apart on roads in 1970s Australia then triangulating the bracing with a strut tower -> strut tower brace would be a good idea.
None of that is even remotely as useful for improving handling as a properly aligned & corner-balanced suspension setup combined with some nice lightweight wheels and high performance tyres, so don't even bother if you haven't gone all out elsewhere yet, you won't notice a difference.
Originally Posted by badvlvo View Post
Oh look, a tire review on TB. In true TB fashion it's about used tires. Used Chinese tires.
Duuuuddee.....weed snot a drug
____caligamerbong___--''"
Originally Posted by coonmanx View Post
I'm going with Windows 9.
Disco Inferno is offline   Reply With Quote
Old 01-28-2018, 06:21 AM   #5
photoman327
photoman327's Avatar
I put braces on my 87 244 NA is stages and notice a Improvment each time I added something. Started with IPD tower to tower then added tower to to firewall then a couple years later their lower brace. Love racing but can’t afford to do any. A better program is Ben’s ultimate brace up top and the no longer made IPD lower brace. Its 3 pieces strap metal and easy to make. Braces along with supporting mods make the old 240 handle more like a BMW than a brick.
Old 01-28-2018, 08:19 AM   #6
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
Let’s not wax hyperbolically, here.
Before the OP drops the coin on a $150 or $330 strut bar, how about grab some previously loved turbo or ipd sway bars, assuming he hasn’t gone for them first?
Upper and lower gt braces is where I went in leu of a strut bar, after ipd sway bars. They made the curves around town discernibly better, but not like the sway bars did.
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 01-28-2018, 08:38 AM   #7
white855T
Letís not wax hyperbolically, here.
Before the OP drops the coin on a $150 or $330 strut bar, how about grab some previously loved turbo or ipd sway bars, assuming he hasnít gone for them first?
Op already got ipd sway bars(turbo bars are most ideal for dd). Ben's strut bar is totally overkill for 90% of people on tb. Firewall braces and lower brace will be improvement you feel and won't hurt the wallet. This is the approach I went on one of my 240's.
I like the David Samuel's strut bar but it won't clear a b21f intake. OMP has a strut bar depending on your preference.
https://www.ebay.com/itm/OMP-Italy-F...ZZlFmR&vxp=mtr
Buyer/Seller Feedback
Old 01-28-2018, 11:11 AM   #8
photoman327
I have Ben’s upper brace and booster brace that I have not installed but it’s not overkill to me. It is a lot of coin but it clears a flat hood according to Ben. Had I know about it before I went IPD bar I would have gone that way. I said supporting mods! I tend to be a little over the top on my cars but 300-350 on one strut brace is not that bad considering how good I think it is. David Samuel makes a bar close to the IPD one that may clear a flat hood. Ben’ s brace is wait to clear the B21F intake but for the red 242, going with the best!
Old 01-28-2018, 03:33 PM   #9
SlowRide
SlowRide's Avatar
Iíll admit, I shot down ever trying a strut bar because of my flat hood.
Old 01-28-2018, 04:15 PM   #10
keesue
San Francisco Native
keesue's Avatar
I'll chime in. Here is what I experienced with each bar installation.
I firstly installed Yoshifab's tower to firewall braces. They provided the most bang for the buck in steering stability in turns. I then installed Yoshifab's bottom bars, which tie the engine cradle to an existing threaded hole in the frame. They greatly affected the way the car stopped - very controlled and straight with controlled nose dive. These were the biggest bangs for the buck. The front end felt like a part of the car rather than separately attached to the car.
I then installed a CravingBoost tower to tower brace which is no longer available. Why I chose this specific brace is its adjust-ability. Not a requirement but something that worked for me. This brace was less noticeable except under very hard cornering or uneven surfaces. It does provide the last word in front end integrity however, but if funds are a concern, I would submit you could do without that brace until funds are available. It is really discretionary but I am happy I installed mine for sure. There is also the visual when you pop the hood and see that bar. Heh, I admit it.
I had previously scored the flat steel IPD bottom brace with the cross bar but had not installed it. I decided to add it in anyway. What the heck. It installs to the rear bushing cup so a hole was drilled. Kinda hokey but I did it just to get the cross bar in the mix. In retrospect, I could have just gotten way with the IPD cross brace but Yoshi's bars are just so darned stout and they attach to the frame.
After all is said and done, what I will say is the front end is, well, stout, that's for sure. Along with the sway bars, springs and shocks, it handles quite well. Admittedly, I don't drive that hard but an anecdotal comment from the mizzuz sums it up nicely. When a garbage can dropped off a truck in front of me out at speed out on the interstate and I took emergency evasive measures, before she could come unglued we were around the hazzard as if it never happened. She said, "I guess I now know what those upgrades did to the car". Uh, yeah....
It's just an old Volvo...
Even a crappy old volvo....
'81 Black 242 GLT Turbo bought new, now with over 365K. Installed Factory Intercooler . K-Jet and a/c working righteous. Bilstein HDs; IPD springs, 25/25 sway bars and bottom X-brace; CravingBoost adjustable tower brace with Yoshifab top and bottom chasis braces; Crandandall adjustable poly torque rods and panhard bar; Fred Goeske 25mm rear wheel spacers; Redwood Chair window scrapers; Kenwood/ARC sound system.
keesue is offline   Reply With Quote
Old 01-28-2018, 04:38 PM   #11
VolvoNutt
K-jet Newbie
VolvoNutt's Avatar
Keesue Uh, yeah...... thatís exactly whatís I was looking for!!! Thank you sir
Now I have an idea how to layout my todo list for the front end
Old 01-28-2018, 07:35 PM   #12
LC4CARL
Aero challenged
LC4CARL's Avatar
You may have already done this, but to my perception, poly bushings tightened up handling "feel" more than the upper and lower bars did on my rig.
Built-not-bought: PDXdl Resto-Mod.
#carlfeague on IG.
Old 01-28-2018, 09:13 PM   #13
photoman327
What other mods do you have?
Old 01-28-2018, 09:38 PM   #14
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
I’ll admit, I shot down ever trying a strut bar because of my flat hood.
Don't believe it till you see it.
I was told the same thing repeatedly. I bought a cherrys turbo brace for my coffin-hood car, and saved it when that car was crushed. I never even tried it on the flathood for over a year, because supposedly it didnt fit. One day i layed it on top of the strut towers and tried the hood. It closed, with the brace sitting on top of the strut mount nuts........I promptly installed it and its been on there ever since. I put a big hunk of plasticine on top of the bar and closed the hood , and i have over 1.25 Inches of clearance.....Who woulda thunk?
Btw, if you stack stuff up and use clay/playdoh or something like that you can get an accurate measurement of a known point on the engine to the hood. Then get people with the brace you want to measure from the same point on their engine to the top of their brace. Assuming neither of you has collapsed motor mounts, as long as the motor to brace measurement is smaller than your motor to hood, the brace will fit.
Btw, that old cherry turbo brace is strong enough that i ran a ratchet strap from the manifold on each side of the engine up to it to lift/tilt the engine to change motor mounts......
Old 01-28-2018, 09:57 PM   #15
Volvo 240 Front Strut Tower Brace
Old 01-28-2018, 10:07 PM   #16
greasegram
Member Board
greasegram's Avatar
http://www.geocities.ws/MotorCity/Ga.../twrbrace.html
I copied what this guy did. Cost me about $150 and Iím quite happy with it
8v death squad
greasegram is offline   Reply With Quote
Old 01-28-2018, 10:26 PM   #17
VolvoNutt
K-jet Newbie
VolvoNutt's Avatar
Does anyone have a picture of that old cherry turbo brace? I have never seen one but have heard it come up many times, people talk about it with great appreciation.
Old 01-28-2018, 10:29 PM   #18
It's very similar to the wagonmiester brace I posted but with less gusseting.
Old 01-28-2018, 10:30 PM   #19
NotSoFresh
NotSoFresh's Avatar
Yup. Thats basically the same as the old cherrys one I got.
Old 01-28-2018, 10:31 PM   #20
centason
CNT-FAI
centason's Avatar
Edit: Missed RWC's post on David Samuel's brace.
Member: TBCCS
"Democracy is also a form of worship. It is the worship of Jackals by Jackasses." -H. L. Mencken
Just remember this guys. Im related to cocaine.
Any forums history.
Old 01-28-2018, 10:33 PM   #21
keesue
keesue's Avatar
Thanks. This is my next upgrade. Those IPD?
I'm on the fence about the rear trailing arm bushings. Trying to get a handle on why or why not.
Old 01-28-2018, 10:53 PM   #22
VolvoNutt
K-jet Newbie
VolvoNutt's Avatar
Iíve always wanted to ask about this.....
Is this supported enough? Iíve never seen one in person and the picís, to me, seem like it couldnít handle much of a load, it seems thin.
It seems Iím asking you guys, is it stout enough to do the job, can it handle the load successfully?
I guess Iím comparing it to Bens small tower brace, which is beefy in comparison.
Old 01-28-2018, 11:00 PM   #23
photoman327
This is plenty strong but Benís is ties the firewall also! These cars do not have frames, unibody! If you car is nice donít dick around and get the best!
Old 01-28-2018, 11:03 PM   #24
VolvoNutt
K-jet Newbie
VolvoNutt's Avatar
Well I was comparing bens small tower-to-tower brace, not the full Monty strut tower/firewall brace
But ya I agree if you have the coin, go full throttle everything Kaplhenke Racing Baby!!
Old 01-29-2018, 04:10 PM   #25
LC4CARL
Aero challenged
LC4CARL's Avatar
Superpro!
http://forums.turbobricks.com/showthread.php?t=314692
Gary is THE MAN.
If I understand prevailing wisdom, we put poly on the front control arms and the rear torque arms only. (And sways.)
Good luck.
