Fresh Air Inspector
- Nov 4, 2018
- LaHave, Nova Scotia, Canada
Hello All,
I have a weird one.
My 940 wagon came will all the windows tinted with a 20% (?), film. I believe the film is quite old (probably at least 20). I wanted to replace the film on three of the windows starting the the tailgate. The latter had some chunks missing along with some tears that I suspect happened when the PO moved large items.
I warmed up the film and managed to remove what I thought was the film in ~4 pieces. The window was sticky so a cleaned it up with lacquer thinner, followed by Simple Green (50/50 solution), and then Windex. Window looked spotless but still appeared dark. I noticed what I thought were two small pieces of film still stuck to the glass and used a razor blade to remove this. To my surprise the 'tint' started to come off the glass. I now have a small 'clear' section (15 x 25mm), where I used the razor blade.
Needless to say I can't use a razor to scrape the whole window as it may damage the defroster grid. I have tried every chemical I have (carb cleaner, MEK, brake cleaner), using a Q-Tip to test the film around the scrapped area - NOTHING worked.
It appears that the tint separated from the backing and remains adhered to the glass. I haven't tried Ammonia as yet, as this seems to be a recommended route (soak the film, wait an hour and then scrap off). But I'm concerned this may not work either plus I haven't figured out what to use as a scrapper.
So, any thoughts / words of wisdom on how to tackle this?
I have a weird one.
