Old 03-28-2022, 05:08 AM   #1
jrrzo
Question Will it ping, knock, detonate?
Hello,
Planning to +t the b230e (with lh2.4 swap from b230f) engine.
At the moment I have:
- b230e (10.3:1 CR), with ~11.7bar (170psi) at all 4 cyls
- V cam
- full lh2.4 swap from b230f
- 95 RON fuel
Planning to put TD04HL13T turbo
The question is, how much boost that setup could safely handle? Without pinging, detonating, knocking?
Maybe someone had similar build and could share some advice?
Thanks
edit:
getting turbo computers soon (probably from b230ft), green giants (to run w/o resistor pack), adjustable fpr, mbc, wideband and a pretty huge intercooler
jrrzo is offline   Reply With Quote
Old 03-28-2022, 06:57 AM   #2
mrjaybeeze
Team Jetronic.info
Hi
1-2 psi should work flawlessly on regular gasoline.
!0 psi and above with E85
YS
Jaybee
ipdown.net/jetronic.info/tiki-index.php
Site open in "lame mode"
If you have some issues
just send me a message
mrjaybeeze is offline   Reply With Quote
Old 03-28-2022, 08:23 AM   #3
jrrzo
Thanks for the answer.
Forgot to mention:
Getting turbo computers soon (prob. from b230ft), green giants (to run w/o resistor pack), adjustable fpr, mbc, and a wideband
Old 03-29-2022, 04:14 PM   #4
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
No turbo computers? No boost.
Turbo computers with proper tune? Some boost. Probably as much as the little 13T can do before it starts throwing hot air.
I sell chips for LH 2.4!
Old 03-30-2022, 03:41 AM   #5
mrjaybeeze
Team Jetronic.info
Boosting a 230E is like voting Democrat and hoping for lower gas prices....
Reduce compression to around 8:1 and boost happily ever after.
YS
Jaybee
Old 03-30-2022, 10:56 AM   #6
jrrzo
Getting 984 ecu very very soon.
I guess it will arrive even faster than turbo by itself
Old 03-30-2022, 11:03 AM   #7
- Stock PSI Or Bust -
How stock can sprout?
how psi stock cna sprout?
Old 03-30-2022, 12:57 PM   #8
Pretty easy on the coast or the PNW.
Originally Posted by Toyotahead View Post
That's why you give blowies with a mouth full of Listerine, sanitizes the sausage and leaves everyone with a fresh clean wintergreen taste or scent!
Originally Posted by megulon-7 View Post
Sigh…. It leads to the hard stuff. Hot sauce or I can’t get off now.
Old 05-14-2022, 03:47 AM   #9
klr142
Turbo, what?
klr142's Avatar
You'll want a camshaft with more duration to get the dynamic compression lower to help prevent knock/detonation. A K cam or similar would be the minimum, I'd think! Set the intake clearances a bit on the tight side as well to bleed off a little extra.
Also, there's zero need for an adjustable FPR because the car will just tune itself around it. It may or may not like the Green Giants, either, I can't remember if they're within a reasonable adaption range for the stock tuning. They're also complete overkill for a 13C. I'd recommend something smaller.
Old 05-14-2022, 11:21 AM   #10
shoestring
shoestring's Avatar
Or voting Republican and thinking they care about people who work for a living.
Old 05-14-2022, 01:51 PM   #11
ryanfay
more bounce to the ounce
ryanfay's Avatar
I think the old 1980’s technology computers will be your limiting factor. People boost those engines in the high 9’s static successfully with different engine management.
ryanfay is offline   Reply With Quote
