Ok so I currently have a 1987 740 b200e, a 1992 940 wentworth turbo b200ft lpt, and a 1985 240 with a b230k engine
I plan to use the 240 body and put the b200ft engine in upgrade the turbo, 3 inch exhaust t5 injectors and an ecu chip, with this setup I don?t plan to make mega boho but if it livens the car up a bit and makes it fun to drive
Whilst I?m driving the car I plan on building a b230, bigger turbo, upgraded cam shaft, injectors etc with the hope of seeing around 400bhp. My question is will the block from the b230k be strong enough, I?m not sure what the compression ratio of this engine is or what conrods and pistons it has but they will probably be upgraded if their not up to scratch
