Like I said (or did I?) the boat engine probably has very little actual use on it. Mine sure didn't had I wanted the 8 bolt crank and heavy rods it wouldn't have taken much to get it running.
You did say haha. Are you suggesting I just clean the bottom end and run as is? Mine is already a 6 bolt crank so that's not a concern of mine.
I'll call and get prices for the simple machine work I mentioned earlier.
What cams came in the 6 bolt AQ130's?
Also does anyone have the details on modding the marine head to accept the automotive water pump. You mentioned you had done it Bobbyz...and details/tips?
