Karl Buchka
- Mar 25, 2007
- Los Angeles
Glad to see an update. You've got a beautiful car.
I would love to see it some time over the summer.
Yeah, the access is a concern, but I should be able to just remove the wheel and inner fender and drop the entire assembly down. There's a fair amount of space to get a wrench on the nuts/bolts holding that bracket in place. Certainly don't plan on removing the whole fender to change a relay!
I hope to have some more significant updates soon. The parts are piling up again!
If you have any setup or install questions feel free to call or email me.
[*]John Parker aluminum/steel flywheel
[*]8.5" kevlar full clutch disk
[*]Dual diaphragm Clutchnet PP
[*]Hydraulic clutch conversion
300 lb front and 250 lb rear springs.
Those are way too close of spring rates.
This sounds almost identical to what I have but I think the PP is also a John P sourced unit. What did you end up shimming your pivot to? 5mm?
Says you
I had 300/250 on my wagon with the Koni race dampers on short front struts which sounds pretty much identical to what Bob posted he is going to run... I was very happy with those rates on my street car.
Says you
Sounds awful to me but I can tell I'm going nowhere fast in this argument.
street car.
