- Aug 7, 2003
- San Francisco
doesnt fit. the M90 has a much thicker output shaft. I tried.
4 bolt it is!
The whiteblock M90s seem to come more often than not with the round, 4 bolt output flange. I wonder if the bolt pattern is the same as in earlier 200-series cars. Or are you going to change the flange and use the never style drive shaft with a guibo?
Why you would actually intentionally change that setup to use a POS guibo is beyond me. Use the 4 bolt.
That's odd. The starter is pinned to needs to bolt to that bump. The bolt on the block is largely useless.
Cool, now get that stop ring welded!
Nah not right now. Gonna reseal it, fill er up and be done with that.
dont plan on banging gears? or you dont plan on missing a shift?
