redblockpowered
bad username length
- May 5, 2015
- Swampscott, MA
I'm looking to put an M90 in my 940, and something I read has me puzzled. Anthony Hyde says "Another issue is the length of the mainshaft - Initially the box mates to a thick dual mass flywheel (expensive), BUT if used with a Volvo flat flywheel the input shaft is not long enough to fit into the crank pilot bearing. An adaptor would be required, more info when a fix comes to light." regarding mating the transmission to the early style flat flywheel. I understand there are now spacers you can get from Sweden that address this problem, but I am mating my M90 to a dog dish flywheel instead of a flat flywheel. Do I still need this/any spacer?
