vwbusman66
Stößelstange über alles
- Oct 12, 2016
- SE MI
Is the vibration just in one gear or in any gear at 25 under load? Could be the trans mount... didn?t see pictures of yours, but if the trans mount is cantilevered out you can get into weird speed based load harmonics.
The cross member is straight and the mount doesn't appear torqued in either direction. As it so happens, I was wrong about the 25mph. It only happens when pulling out turning left or right.
It has nothing to do with the actual driveline. I put 10 miles on it today and discovered that the rear end is doing the same wishy-washy rear steer thing that my 244 with wasted rear bushings did. I suspect the trailing arm bushings are completely wasted (would also explain the squeaking going over bumps at low speed) and is causing all the rear end noises and clunks.
