#1 |
![]() Recently I purchased a replacement emblem, 70mm. It's just a sticky decal. How do I get this thing inside the casing on the grille? I assume you'd have to somehow open the casing, scrape off the disintegrated original emblem and stick the new one on, and re-assemble it?
How do you do this exactly? I can't find anything on the internet. |
#2 |
![]() I recently also purchased a replacement emblem for my grill. My car is an 82 and I (stupidly) didn’t measure it- 70mm is too big. So, had to order a replacement smaller badge ugh...
Anyhow, I used a trim tool and a pick to pry the old emblem out, it’s glued in place. Persist and it will come out. I plan on using some sort of flexible adhesive to secure it. Just clean all the old adhesive out. Mine is prepped and ready to be glued when it arrives. I was going to use double sided tape but this will not allow it to sit flush. |
#3 | |
![]() Quote:
Anyway, that gets at the crux of the issue. Exactly how did you get the old emblem out in the first place? It's encased in a space covered by acrylic in the front, metal in the back, affixed to the grille. |
#4 |
![]() Wipe the old rondel with acetone or lacquer thinner let it dry, and put the new one right on top of the original.
#5 |
![]() The emblem is not glued in place. The emblem is applied with double sided tape. If you are using a genuine Volvo emblem, you must use double sided tape. Do no use adhesive, it will ruin the emblem(ask me how I know). If you are using a decal it can be applied over the original emblem.
Click below: Buyer/Seller Feedback My Volvo parts for sale on eBay Volvo parts for sale on forum - Post are regularly updated |
#6 | |
![]() Quote:
White855t is correct regarding adhesive if you have a genuine emblem - they have foil paper on the back. Looks like I will be buying some thinner double sided tape.. |
#7 |
![]() My acrylic cover is in bad shape from a couple hundred thou miles of road sandblasting and rock chips.
Pretty obvious that it cannot be polished out like a headlight lens. ![]() Under cover would certainly seem to be a preferred solution and I might try to pry the old plastic and cut and polish a replacement Maybe Dave Barton will comment.
![]() 1982 Volvo 245 with a Ford 302 V8 Ford V8 Conversion Manual - http://forums.turbobricks.com/showthread.php?t=250257 Bertone Restoration - http://forums.turbobricks.com/showthread.php?t=256460 Last edited by TestPoint; 10-20-2020 at 08:16 PM.. |
#8 |
Dejected by Volvo
![]() A photo of this thing the OP bought would be useful.
Dave B
![]() '84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, hydro clutch, 3.91 diff with unmodified G80. Volvo Ambivalence of Volvo Enthusiast Community: prancingmoose.com/#novolvo Dave's Volvo Page: davebarton.com 240 Mods and Fixes Pages: 240turbo.com/volvo240mods.html |
Thread Tools | |
Display Modes | |
