Old 10-11-2017, 11:56 PM   #1
maxitoman007
Default Prosport Evo wideband, narrowband emulation question
Anyone running a prosport evo wideband and using the narrowband emulation signal for LH? Hoping I don't have to weld in another bung (don't really have room because it's a hoodpipe).
Car is a 1987 740 Turbo.
Thanks.
maxitoman007 is offline   Reply With Quote
Old 10-12-2017, 02:18 AM   #2
Egez
Narrowband emulation is too slow for LH.
1992 | 245 Polar | B230F+T- Soon to be crushed
1993 | 245 GL | B230FD - Gonna get sweet 16V Jurbo goodness
1990 | 745 GLT | B234F - CRUSHED
1990 | 744 GL | B200F - SOLD
1998 | 945 Classic | B230FT - Daily
Egez is offline   Reply With Quote
Old 10-12-2017, 03:50 AM   #3
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i once used a zeitronix with emulation, that worked pretty well, but i had to wait always for the lambda to heat up.. took around 15-20 secounds everytime i wanted to start.
Old 10-12-2017, 09:29 AM   #4
turbotankshane
I've got a prosport evo in my 240, have played with lh extensively, and it doesn't like that emulation. It did stay at 14.7 all the time, but never oscillated and never drove right.
Old 10-12-2017, 10:32 AM   #5
maxitoman007
Oh I see, have you tried letting the sensor heat up like the last guy said?
Old 10-12-2017, 02:28 PM   #6
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
that shouldnt be the problem, i could start with a cold lambda but car ran like **** and sometimes it flooded the cylinders so i just waited.
When started cold everything was alright after the wideband had its temp
Old 10-12-2017, 02:28 PM   #7
turbotankshane
Yes, but his was a different controller and even with the same sensor not all controllers are created equal.
The bung is cheap, drilling a hole is cheap, having someone else weld the bung on if you cant is still cheap. Just add a bung.
Old 10-19-2017, 07:28 PM   #8
maxitoman007
Added a bung
Old 10-20-2017, 02:35 AM   #9
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
always better ;)
