Old 08-30-2018, 12:00 PM   #1
Chilm
Double Dutch
Chilm's Avatar
Default Knif edging your crankshaft.
Hi guy's
I want to knive edge my B230FK crankshaft, but I have a few questions about it.
Reason: cuts smoother through the oil(mist), less drag, lighter bottom end, faster in the rev's.
And curious if I have the skills
What will it do with the torque, I mean torque will be less but is that noticable?
After doing that it will be re-balanced again.
What are you brickers thoughts about this plan?
Double Dutch - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 08-30-2018, 12:32 PM   #2
JohnMc
JohnMc's Avatar
My thought is that with some very careful dyno testing, you might actually be able to tell the difference. If other conditions were controlled enough.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-30-2018, 12:48 PM   #3
Egez
Torque curve may change, but you should not lose any. Just lighten flywheel / get billet one.
1992 | 245 Polar | B230F+T- Soon to be crushed
1993 | 245 GL | B230FD - Gonna get sweet 16V Jurbo goodness
1990 | 745 GLT | B234F - CRUSHED
1990 | 744 GL | B200F - SOLD
1998 | 945 Classic | B230FT - Daily
Egez is offline   Reply With Quote
Old 08-30-2018, 12:48 PM   #4
John V, outside agitator
Originally Posted by Chilm View Post
Hi guy's
You'll notice more by doing this.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 08-30-2018, 02:12 PM   #5
Chilm
Double Dutch
Chilm's Avatar
As honest as allways John, experienced fapper?
No really, not a good idea?
Did they evah try this out with the group A in Sweden?
It's not amanual.
Old 08-30-2018, 02:21 PM   #6
JohnMc
JohnMc's Avatar
It's not a manual.
Your chances of ever actually noticing a difference just went to (statistically speaking) 0.
Old 08-30-2018, 03:25 PM   #7
culberro
culberro's Avatar
Is the motor spinning over 6k rpm continuously? If not, crank scrapers and knife-edging aren't going to do so much for ya.
Old 08-30-2018, 03:46 PM   #8
JerryJS8
der Junge
JerryJS8's Avatar
No point in knife-edging if a dry sump will get you more for your efforts.
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 08-30-2018, 04:29 PM   #9
Chilm
Double Dutch
Chilm's Avatar
O.k. guy's, points taken
Old 08-30-2018, 05:34 PM   #10
Group A homologation form lists under point 319.h the minimum weight of the crankshaft...
For example, the Frod Squierror with a YBB built explicitly built to beat the old B21 240s has a minimum weight of 14,100g....notice they list it as grams*... People have been disqualified for being just a few grams underweight in some internals...
Pretty hard to knife edge the crank without it getting lighter.
*The homologation form for the Exsquirt Crossways with a YBG
Shows a minimum weight of 14,200 grams.. Oddly enough its the same part number.
Old 08-30-2018, 07:00 PM   #11
Chilm
Double Dutch
Chilm's Avatar
Thanks for your reply John, clear now.
Old 08-31-2018, 10:53 PM   #12
freevolvos
freevolvos's Avatar
knife edge to cut windage add weight back in with Mallory metal
Old 09-01-2018, 04:49 AM   #13
J2_
J2_'s Avatar
For fark sake mister Vanlandingham, you just made my day. It's been a very long time we talked on the phone but it's coming back to me now
J2_ is offline   Reply With Quote
Old 09-01-2018, 04:51 AM   #14
J2_
J2_'s Avatar
@Chilm; I told you several times, you are taking some things waayyyyyyy to far. Listen to the people who have build several 8 valve tractor engines.
Old 09-01-2018, 02:23 PM   #15
Chilm
Double Dutch
Chilm's Avatar
You dunno what I'm aiming yet
Old 09-02-2018, 06:29 AM   #16
J2_
J2_'s Avatar
Seeing you are not ordering a samsonas gearbox, some big ass rear axle, I think you'll be fine with not going overboard. ;)
Old 09-02-2018, 01:33 PM   #17
haltechsupra
haltechsupra's Avatar
A customer of mine had it done in his car. Jason Goodley. It is hard to say if that one thing helped.. But that little car 244 was a rocket in its day. Ran a few 7.8 in the eigth at 20 some psi in 2003 out at kennedale dragway. He had a lot of other supporting mods , and they all seem to work very well together. If I may bore you with details.. Serious ported 8v head by one of Bob norwoods guys, special cam, 93 ported manifolds, b23ft, with imported b23et pistons, shot peened b21ft rods, knife edged b23ft crank, o ringed block, copper headgasket ( nobody made them then so he and I did a run of them and they mostly sucked)haltech e6a, crane hi 6 r full ignition with fireball coil, m46 with American power and brake clutch, drag slicks on open diff , 60-1 turbo, npr intercooler.. I ended up buying this car about 5 years ago. Rebuilt it, got it running. Then sold it.
haltechsupra is offline   Reply With Quote
Old 09-02-2018, 02:20 PM   #18
freevolvos
freevolvos's Avatar
all that work and no posi?
Old 09-02-2018, 02:47 PM   #19
Want to see how important it is? Search Google Images for "F1 crankshaft" and see if you find any knife edged cranks.....
Since Eff Juan is ass-fault I don't pay any attention to it, but I hear they do rev their engines up..Probably a bit higher than road car Volvo.
Old 09-02-2018, 05:06 PM   #20
Chilm
Double Dutch
Chilm's Avatar
That's the trick, every little bit helps.
Getting the complete picture then, learned from what I've been reading and hearing and have experienced.
Old 09-02-2018, 06:06 PM   #21
300+hp on the shelf club
There are already threads about forged cranks vs cast crankshafts if you want to explore Volvo crankshaft discussion more. Here is a discussion on the strongest stock short block.
http://forums.turbobricks.com/showth...ged+crankshaft
Old 09-02-2018, 10:03 PM   #22
Every little bit helps: Truthiness
Every little bit costs money....some little bits may theorectically help, but the "help" may not be measurable, or detectable...The money is delectable, but a quick cost/benefit analys will show certainty that the cost of some "little bit" which is not detectable is not worth it---as if seeing piccies of F1 cranks NOT knife edged wasn't enough to nail this coffin closed..Come on THINK of the pooor horses.
Old 09-02-2018, 10:51 PM   #23
2turbotoys
Salaminizer
2turbotoys's Avatar
Not sure what the goal is, but rather than maxing out the tiny little things (which helps but) maybe bigger turbo/more boost/more cylinders? I think I'm agreeing with John V...is that a powerpoint John?
2006 V50 T5 AWD 16 PSI +
2turbotoys is online now   Reply With Quote
Old 09-03-2018, 12:33 AM   #24
Personlly the fixation boys have on motors might make more sense if that was the only thing that made a car go, or go quickly.. But as I've said for maybe 40 years, we don't drive/ride motors, we drive/ride cars/bikes.. I have seen more cars sunk by crap gearbox and final drive than lousy motors.. And from being a slave to silly fads...excesses in one thing--for a "look" or "street cred"..
Maybe this guy could being by throwing the autotragique versnellingsbaks in the nearest canal..
And think/talk %s ..xx% quicker?
Old 09-08-2018, 04:21 PM   #25
shoestring
shoestring's Avatar
I've certainly gotten into plenty of trouble with 115hp cars.
That said, one of my favorite automotive quotes is from Enzo Ferrari:
"Aerodynamics is for people who can't build engines"
