142 guy
- May 31, 2014
- Saskatchewan, Canada
I have found a lot of conflicting references for doing caster measurement when using a level gauge with a fixture for attaching it to the wheel rim (in this particular case a digital level gauge). The short form of the most common approach is for the right wheel, turn the wheel 20 deg to the right, zero the angle measurement, turn the wheel 20 deg to the left and read the angle measurement. Multiply this measurement by 1.432 and this is your caster measurement. Repeat for the left wheel.
Is this the approach being used by others?
I had my front cross member powder coated when I did my resto mod and since then I have been driving around with a single 1/8" shim at each adjustment point. To save me a lot of install / measure / remove / repeat does anybody have an estimate of the total shim thicknesses that they are running (and what your corresponding caster and camber is)? Or, as an alternative can anybody confirm how to interpret the shim graph that is in the factory service manual? I read the graph as saying measure your angle first then 'add or remove this shim thickness to get this angle change'. However, 2 x 1.0 mm does not get you the same change as 1 x 2.0 mm so ?? I am slightly confused.
