Old 07-06-2017, 07:52 AM   #1
okoye
okoye's Avatar
Default Shim settings for rsi stage 2
What should I shim the cam to? I'd like to get rid of the m cam that came in the 240 motor I swapped into my 940.
Old 07-06-2017, 08:54 AM   #2
EivlEvo
The shim settings are set for the motor not the cam aren't they? When I did my IPD Turbo cam I shimmed based on the specs in the manual anyway...
Old 07-06-2017, 09:02 AM   #3
gross polluter
They see me trollin'
gross polluter's Avatar
No. Depending on the lobe profile, some aftermarket cams want tighter clearances.
Old 07-06-2017, 05:10 PM   #4
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Ultimately, this.
If you don't have that then here's the base B230 Lash / clearance specs:
Edit - Added to post as an attachment given the current image hosting uncertainty.
Old 07-06-2017, 10:03 AM   #5
gsellstr
Vintage anti-ricer
gsellstr's Avatar
What ^^^^ said.
Get any specs with the cam? .016 should be a decent starting point if not.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 07-06-2017, 10:04 AM   #6
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Following.
Originally Posted by 740freak View Post
how psi a stock can support?
Originally Posted by speedn_j View Post
I think this might be my chariot if I can jew the price down.
1990 780t Kind of Modded 1994 945t Pegz, Tintz, Hidz.
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
"Lister, you are a polyp on the anus of society." - A.J. Rimmer
Ursan is offline   Reply With Quote
Old 07-06-2017, 10:09 AM   #7
AndrewNance
Amateur hour!
AndrewNance's Avatar
Just an FYI - I remember needing some thinner shims to get the lash right. Something about the base circle being smaller on the RSI cams I think. I don't think I was able to reuse any of the ones that were in with the factory cam. So maybe it would be worth it to do the kit rental deal
'71 142
'80 245
Feedback
Old 07-06-2017, 10:35 AM   #8
Stiggy Pop
Stiggy Pop's Avatar
yeah I had to order some from eEuro when I went to the RSI2 cam, and some were just into spec with the thickest shim available.
I set mine up at book spec
'79 242
943 pickup
Old 07-06-2017, 10:22 AM   #9
*thicker*
Old 07-06-2017, 11:32 AM   #10
AndrewNance
Amateur hour!
*thicker*
Yeah that
Old 07-06-2017, 10:33 AM   #11
okoye
okoye's Avatar
I'm sure that there is a cam clearance range that won't prematurely wear the cam out.
Old 07-06-2017, 01:27 PM   #12
sbabbs
sbabbs's Avatar
Yep me too, I used the thickest shim on one of them and it still was a little loose, went with it..
Old 07-06-2017, 04:43 PM   #13
EivlEvo
Man... I had my head decked by a lot for the car I bought (blown HG) so with my IPD I had to use the thinnest shims to get even close to spec. *edit to appease the masses they did the valve seats and new hushers too. Regardless I needed the thinnest shims to get close to spec. Regardless I needed the thinnest shims to get close to spec. Regardless I needed the thinnest shims to get close to spec. Regardless I needed the thinnest shims to get close to spec.
Maaaad.
Old 07-06-2017, 05:27 PM   #14
gross polluter
That statement alone makes absolutely no sense.
Old 07-06-2017, 05:52 PM   #15
cosbySweater
cosbySweater's Avatar
Lol
Old 07-07-2017, 09:00 AM   #16
EivlEvo
Eh screw you guys... they did the valve seats too with new hushers. Either way checking clearance needed thinnest shims. wth u want from me?
Old 07-07-2017, 09:17 AM   #17
J_Jones
J_Jones's Avatar
Well that makes more sense then
J_Jones is offline   Reply With Quote
Old 07-07-2017, 09:33 AM   #18
EivlEvo
Old 07-07-2017, 11:26 AM   #19
gross polluter
wth u want from me?
A hint of intelligence. Or, just don't post at all.
Old 07-07-2017, 11:30 AM   #20
EivlEvo
Eh...
Old 07-06-2017, 07:15 PM   #21
J_Jones
J_Jones's Avatar
Maaaad.
And that was the moment the turbobricks community knew, this guy didn't know what the hell he was talking about...
Hopefully someone who once worked at RSI has some info on the correct setup
Old 07-06-2017, 08:32 PM   #22
gross polluter
Good luck. Talked to the person yesterday who owns all the rights to that stuff now. Can't even give out the most basic info to properly setup a stage II cam on an engine I'm trying to get running right. Something about fear of giving out manufacturing info. Can't get stuff dialed in on just lift and duration.
Like Erik said, RSI stuff belongs in the garbage.
Old 07-06-2017, 09:22 PM   #23
cosbySweater
Harlards car is the perfect example of trash can comment
Old 07-06-2017, 10:02 PM   #24
gross polluter
That's who's drama I'm trying to sort out. The person who designed the cam flat out refusing to give any sort of information to make the cam usable makes it ****ing useless.
Old 07-08-2017, 06:14 PM   #25
Texas240
Prius Owner
Texas240's Avatar
Hahahaha.... Day made
93 245 LS Engine Swap Project
