Old 08-11-2018, 07:13 AM   #1
A tough rowing ho
Default Dyno day predictions
I have 3 pulls today for $50 through the sports car club anyone want to guess what it'll do?
Stats:
B21- 2117ccs 8.5-1 compression ratio
China bay 20G with 2.5"-3" v band adapter welded on, turbo housing ported to smooth flow into transition
eBay 25x4x8 intercooler
90+ manifold
3" side exit exhaust with 11" glass pack
T5 trans, I assume the pull will be in 4th
26.5” diameter tires
3.91 1030 axle
24 psi on the MBC
5-8 degrees of advance at full boost
Stock k-jet fuel system
IPD turbo cam runs out of steam around 65-6600 rpms rev limiter set to 7k
Microsquirt with Siemens 788cc injectors
B21F intake manifold
I'm hoping near 300 hps but we will see
Me for President
First candidacy driven entirely by smart phone.
Campaign slogan
"Trump, I wouldn't piss on him if he were on fire!"
Old 08-11-2018, 08:28 AM   #2
poulrais
poulrais's Avatar
283hp/265tq
1990, Volvo 740 16v +T
Old 08-11-2018, 09:05 AM   #3
tryingbe
Boosting along.
tryingbe's Avatar
Mustang Dyno?
Dynojet?
Dynocom?
85 GLH 367whp
00 Insight mpg > yours.
Old 08-11-2018, 09:10 AM   #4
A tough rowing ho
Dynojet I believe
Old 08-11-2018, 09:20 AM   #5
tryingbe
Boosting along.
tryingbe's Avatar
What's your max duty cycle reported by Microsquirt?
Old 08-11-2018, 12:27 PM   #6
eabras
Why the low advance at full boost?
eabras is offline   Reply With Quote
Old 08-11-2018, 02:03 PM   #7
A tough rowing ho
So yeah that timing biz is pretty important, first pull made 157hp. I doubled the timing values at the top of the table and got 239hp and 244ft.lbs., needless to say I thought I'd get a little more out of her but happy to get almost a 100hp for $50.00. I need to make some detcans and see what I can wring out of it.
Old 08-11-2018, 02:04 PM   #8
A tough rowing ho
Because I don't know wtf I'm doing apparently
Old 08-11-2018, 02:09 PM   #9
tryingbe
Boosting along.
tryingbe's Avatar
I'm confused.
Old 08-11-2018, 03:38 PM   #10
oldschoolvolvo
oldschoolvolvo's Avatar
stock K-jet fuel pumps & lines??
-Mike
1998 V70 T5
|Feedback|
Old 08-11-2018, 04:04 PM   #11
A tough rowing ho
Originally Posted by tryingbe View Post
I'm confused.
Stock k jet fuel pumps and Volvo EFI fuel rail sorry that wasn't very clear. I'm not running out of fuel, just need a better tune.
Old 08-12-2018, 09:54 AM   #12
eabras
I don't know the wheel sizes in your turbo, but apart from the compression ratio I don't see all that much difference from my previous setup (7.5:1 b21) which made 352whp and 344ft.lbs. at 30ish psi. 19.25 degrees at full boost. So I bet you still have a good bit of power left in that thing
Old 08-12-2018, 10:26 AM   #13
sleepySOHC
sleepySOHC's Avatar
i was tempted to come out and dyno the ole beat b230f to see what it makes haha
93' 245, cut springs, ipd goodies- daily
89 f150 lifted 33s
91 gti, vr6BT in the works
01' jetta, forged, built head, custom manifolds, sxe257
90' 744T built 16vt- parted
97' civic lx- totaled
96' civic ex- totaled
94' civic dx boosted-sold
sleepySOHC is offline   Reply With Quote
Old 08-13-2018, 06:25 AM   #14
A tough rowing ho
You would not have won the lowest HP award, guy brought a Datsun wagon 1.4l that made 43whp.
Old 08-13-2018, 06:33 AM   #15
Sjeng
Sjeng's Avatar
Stats:
90+ manifold
3.91 1030 axle
24 psi on the MBC
Would you like to post your ignition map?
Old 08-13-2018, 08:11 AM   #16
740atl
educator monkey
740atl's Avatar
Keep at it dude. I understand the desire to not blow the motor up. I definitely got bolder once I had a knock sensor on the megasquirt board to listen in for me. Before I always just had a friend drive the car on a flat deserted stretch of road while I listened in on detcans. We'd make pass after pass and incrementally bump the timing until I heard some pinging. That should get you closer to where you want to be power-wise. 24psi through an 8v should get you into the high 200's for power with a b21 with stock heads. If you can afford more dyno time with the det cans, that would be even better.
If dyno is out of the question, the next best thing is the dragstrip. As you add timing, if the trap speed increases, you know you're making more power.
Old 08-13-2018, 08:53 AM   #17
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
it is very difficult for the newly initiated to dial in a timing map without the aid of a dyno. On a purely initeria dyno, it is also easy to go "past" what is best without getting knock on the dyno, and then discover that it's knocking it's brains out on the street. A set of det cans isn't a bad idea but even then one should be careful whilst driving around tuning.
Megasquirt Tuning!
Old 08-13-2018, 11:07 PM   #18
A tough rowing ho
Here's my current tune
Old 08-14-2018, 09:21 PM   #19
linuxman51
linuxman51's Avatar
yeah that timing map is a bit of a mess. ve table is a bit curious too.. looks fat in the 2-3100 range, and then drops off hard above 4000 (out of boost), what's up with that?
Old 08-14-2018, 09:22 PM   #20
linuxman51
linuxman51's Avatar
you wouldn't happen to have a datalog of any of the pulls would you
Old 08-14-2018, 09:38 PM   #21
A tough rowing ho
I did but the computer that they're on isn't working right now. I do have a datalog from the day after.
Old 08-18-2018, 07:19 AM   #22
A tough rowing ho
I keep easing the timing up a degree or 3 in boost, I'm happy with how is working there for now but how aggressive can I get out of boost? I'd like to get a little more bottom end grunt.
Old 08-18-2018, 09:50 AM   #23
linuxman51
linuxman51's Avatar
your 600rpm bucket there on the timing map is useless, and you're running 21 degrees at part throttle at 1600. It's a 2.1L low compression engine, it's not going to have gobs of low end grunt out of boost. This is why I keep the compression up on all but the race car (and even it I'd like to be higher, next set of pistons I reckon). I'll make some changes and tag the map in, I'da done it earlier but I couldn't get the log viewer stuff to work at work
Old 08-18-2018, 09:54 AM   #24
linuxman51
linuxman51's Avatar
same thing I tell my customers, listen for bad noises, try it in lower gears first, don't get a ticket and don't wad it up
Old 08-18-2018, 11:13 AM   #25
A tough rowing ho
Thanks a lot I really appreciate it, I will try to make Southeast and bring you some nice beers or something. I know you get paid for your expertise.
