Old 12-21-2013, 05:16 PM   #76
Ollu
Ollu's Avatar
Todays work. But still, more information tomorrow.
Ollu is offline   Reply With Quote
Old 12-22-2013, 02:50 PM   #77
Ollu
Ollu's Avatar
I brought myself a christmas present. And now I can say that I have a turbobrick also.
Engine is from that car.
http://www.youtube.com/watch?v=yzzdb...ature=g-crec-u
B230FT and that engine goes to my blue 240.
Ollu
Old 12-22-2013, 04:56 PM   #78
Old Iron
I Roll
Old Iron's Avatar
Ohh shoot, this project is escalating!
Turbobricked
Old 12-23-2013, 05:59 PM   #79
Ollu
Ollu's Avatar
Made it this far today.
My old engine - B230FD
Came with 740 - B230K
Whats this?
What connecting plug is on that hose?
Should lamba be so close to a turbo?
A few pic of a turbo
B230FT wiring
B230FT came out
B230K went in. Tomorrow should start. Almost everything is attached and connected. Have to do a few more things.
Ollu
Old 12-24-2013, 12:34 PM   #80
D.E
tvåförti
D.E's Avatar
Is the B230FT originally from that 740? Looks like an 88 or 89 which would mean skinny rods. If so, the B230FD bottom end would be a lot better because it has 13mm rods and oilsquirters.
'88 Volvo 245 - B230F, LH2.4, A-cam, 4-2-1 header, de-cat, M47
'83 Volvo 244 - B23A, M46, 48k miles
'64 Ford 17M, '59 Plymouth Custom Suburban, '76 Ford Granada 2.8
D.E is offline   Reply With Quote
Old 12-24-2013, 06:26 PM   #81
Ollu
Ollu's Avatar
Turbo engine should be from 1990 740.
B230K was originally on that 740. Someone took that out, Put B230FT in and I bought it, took B230FT out and put that same B230K in.
B230FD was from 1994 945.
Old 12-25-2013, 02:37 AM   #82
janne81
Sweet car!
I think -94 FD block is probably without squirters(not 100 sure), but -95 block wich i had was with squirters.
janne81 is offline   Reply With Quote
Old 12-25-2013, 08:24 AM   #83
D.E
tvåförti
D.E's Avatar
I see, 1990 is good, it has thick rods.
I'm pretty sure all FD blocks have squirters.
Old 12-25-2013, 03:50 PM   #84
janne81
I have seen -93 FD block W/O squirters.
Old 12-25-2013, 08:24 PM   #85
Ollu
Ollu's Avatar
So these oilt squirters are with block? So I should change FT block to FD?
Old 12-25-2013, 10:16 PM   #86
John V, outside agitator
No just drill 4 holes make threads to M8 x 1 use BMW squirters for under 20 Euro each..
Very easy to do to any Redblock all the way back to B16
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 12-25-2013, 10:20 PM   #87
I think you are making a huge exaggeration... No way can you call those later b230 rods "thick".
THICK is like the monstrous "M" rods.
Early skinny B200/B230 rods are like spaghetti, late B230 rods are like "2 pieces of spaghetti"..
Still very thin just not anorexic thin needing immediate medical treatment.
Old 12-26-2013, 06:56 AM   #88
Ollu
Ollu's Avatar
Guys what do you think about 1000405 head? Or should I go with 531? Atm I have 530.
Also what cam to use? I have T-cam and one cam that has X. I think somewhere is A cam too.
Old 12-28-2013, 06:26 AM   #89
janne81
Yes, you can use FD block but you have to make turbocharger oil connections to it and use FT pistons if you want 8.7:1 compressions.
405 head may be with big coolant passages so it is not that good as 531 wich is propably with small coolant passages. You never know about these, better look those things in live.
Old 12-28-2013, 09:39 AM   #90
D.E
tvåförti
D.E's Avatar
It has the thicker of the two versions of B230 rods.
531 is probably better because 405 is likely to have K-Jet injector holes. They have very similar if not identical ports so from a performance standpoint it doesn't matter. Use the A-cam.
Old 12-28-2013, 04:36 PM   #91
Mattis
Mattis's Avatar
Just check the date on the block (Behind the passenger side engine mount)
Or just pop the pan, to see exactly what you got..
You'll have to replace the gasket, but you might break it anyways when you swap to the block mounted distributor..
Mattis is offline   Reply With Quote
Old 02-09-2014, 10:41 AM   #92
Ollu
Ollu's Avatar
Ollu
Old 03-03-2014, 10:11 AM   #93
Ollu
Ollu's Avatar
Tiny update.
Olari
Old 03-03-2014, 12:40 PM   #94
petiww
petiww's Avatar
Coming together!
1980 Brown 244 GL
Old 03-03-2014, 03:03 PM   #95
Reuvers
Reuvers's Avatar
engine bay in cream white looks good with the blue! Good progress
Reuvers is offline   Reply With Quote
Old 03-08-2014, 12:51 PM   #96
Ollu
Ollu's Avatar
Old 03-25-2014, 02:23 PM   #97
Ollu
Ollu's Avatar
Little flashback from last season
Old 03-28-2014, 01:41 PM   #98
Ollu
Ollu's Avatar
Also one from behind;)
Old 04-14-2014, 05:09 AM   #99
Ollu
Ollu's Avatar
Changed to a electric fan.
Ollu
Old 04-14-2014, 01:19 PM   #100
Awful Hero
Awful Hero's Avatar
You already know, i love this car. :-)
Transmetropolitan IG: Awful_Hero
FB: Unfriendly.Garage
Awful Hero is offline   Reply With Quote
