http://www.amazon.com/gp/aw/d/B00G9...=AC_SX110_SY165_QL70&keywords=23+mm+drill+bit.I'd rather not attempt to destroy a 40$ set of poly bushings.
Nor do I intend to buy a massive drill bit that cost as much as the bushings.
IPD replacement 23mm brackets and poly bushings actually help stiffen up the feel of the 23mm bar. Must be the poly holding the bar better than the old worn out rubber.
This pic is a 23mm bar powder coated and IPD sticker applied with the IPD bushings.
It's not mine, I was just helping build it. http://forums.turbobricks.com/showthread.php?t=311909First off, your car is incredibly clean, do you even drive that thing?
I was debating on going rubber but this solidified my opinion.
Cancel order and order the better poly ones with new brackets from IPD?I think (hope) the official Volvo part number is: 1273184 I have a set of these on order from Tasca but let's just say that promptness and responsiveness don't seem to apply once my credit card was charged. These mate with the original 23mm Volvo brackets. Poly aftermarket 23mm bushings may need a different bracket.
I'm gun shy about too much poly giving a loud and harsh ride (I bought into the AC VW poly coolaid many years ago and ended up replacing most of it with quality rubber).
For quietest/smoothest ride, what are the top few bushings that should stay rubber and which ones can go to poly for better handling? And for these, are there certain brands of poly that should be avoided for excessive harshness?
