Smorgesborg
- Apr 9, 2020
- Eastern MA
Good afternoon, good evening, good morning. I am a newbie to the forums in account, but I am a longtime lurker with a desire for power and many questions I can't find the answer to. I am aiming for between 160-170 HP at the crank.
I am the owner of a 1986 and 1993 Volvo 244 and 245, respectively. The 245 was bought to be a parts car for the 244, after a minor front end collision which required replacing everything after the quarter panels, short of the bumper, radiator and AC condensor. The 245 was cheap, and the body was crunchy, the 244 only had minor rust. The 1986 engine ran fine, getting the 33 year old Volvol to over 100mph on flat ground, while the 1993 engine was barely running.
So, here's where it comes to performance. I want to keep the car as a good daily driver with low-end performance (mostly because of the tall 5th gear in my T5 transmission), and to keep things looking stock for the most part (philosophy of this build is Stock+, the car/engine in this trim package that Volvo could've, but didn't, build). This means I'm not installing a turbo, no ITB's, not even a "cold air" intake. Exhaust and EZK is as far as I'm willing to go, in terms of out-of-engine modifications.
The power modifications I have in mind, so far are:
1. 531 head off an AQ151 with a V cam.
2. Adjustable cam gear.
3. 46/38 valves, with port smoothing to accommodate the new valves (including removing the lip in the exhaust port). 1mm shave of the head would be at the same time, to recover lost compression.
4. EZK ignition
5. Tubular exhaust, with IPD 2.5 inch sport exhaust (with an added resonator for a bit of noise reduction, and 2.5" catalytic converter, in case it ever needs to pass smog again)
6. Front end under-engine aero cladding (nothing to do with power, but probably good for speed).
7. Maybe a windage tray/crank scraper, if I decide to rebuild the engine.
Getting a sandwich oil cooling kit is also somewhere in the timeline.
Napkin math has told me that I should get 140hp from the shaved head and cam alone. The penta AQ145 is a 2.3L with that head/cam getting 138hp with a carburetor. Based on more napkin math, Volvo engines with single carbs tend to get about 8% less power than the equivalent FI engine, but the AQ145 was a boat engine with twin carbs so it's probably not such a big difference.
The valves will get me to 146 (140*46/44, to adjust for improved airflow through valves, and more from the porting), and based on the 5hp gain metric from IPD sport exhaust and extending it to the tubular exhaust I'll be getting about 156. Maybe 160 from porting gains, or more if LH2.2 grants that much more of an advantage over the twin carbs off the Volvo Penta equivalent
Here are my questions:
1. How accurate is my napkin math?
2. How much HP does EZK give? I also noticed that it has no way to compensate for airflow, only RPM, so I'm concerned about partial throttle performance vs Chrysler ignition for daily driving (does it just advance until knock, then pull back?).
3. What kind of power gain could I expect from having less valve lash than recommended?
4. Should I build up the 93 engine in the background, getting the block honed, decked, maybe B230A/E pistons?
5. How would other cams that maintain low end torque for daily driving compare? The engines with the same cam are: AQ145 which shows 138hp, and the B230E shows 131hp at 5400 with 140lbft at 3600. Difference is the head casting (531 vs 530), compression (9.7 [wouldn't it be 9.3 based on the B230FX CR?] vs 10.3), and fuel system (twin carb vs K-Jet).
Thank you for your guys' help, and please don't scream at me for not doing a +T.
4. EZK ignition
a) Would the Oil squirters compensate for the risk of knock from higher compression?
b) I'd honestly prefer to build the 86 block, since even though it's a "weak" Redblock it's still pretty solid and is in incredibly good condition for its age. I also want to keep it with the car. Would the squirters be that much worth it for an NA engine, and how much would it cost to install the BMW squirters into the older blocks?
