Old 04-22-2013, 05:41 PM   #1
kinematics
Default rear 740/940 full coilover
Has anyone ever done this? Modify the rear end to accept a full coilover shock setup? Would like to see some pictures. Can you install a coilover in there upside down to fit inside the shock tower and fashion a mount at the bottom? just curious. Educate me.
1993 Volvo 945t
kinematics is offline   Reply With Quote
Old 04-22-2013, 05:50 PM   #2
Mueller
Mueller's Avatar
If you know the true definition of your screen name, I'd think you'd be capable of doing a simple google search with "volvo 740 rear coilovers"
http://www.kaplhenke.com/index.php?o...d=19&Itemid=34
Just one link of many....
Old 04-22-2013, 05:50 PM   #3
Fitzy
Fitzy's Avatar
Ooogle away.
08 c30 2.0 MT
06 s60R MT - Dead
84 242 Ti 4spd - A work in progress...
Fitzy is offline   Reply With Quote
Old 04-22-2013, 05:55 PM   #4
kinematics
By full coilover shock setup I mean a coil OVER shock setup. Not an adjustable spring perch with separate damper.
Thank you.
Old 04-22-2013, 05:59 PM   #5
Mueller
Mueller's Avatar
lazy person is lazy....
http://www.kaplhenke.com/index.php?o...d=45&Itemid=34
INB4 "I don't have IRS"
No reason it couldn't be done, just have to be creative and have some $$ to spend....one of those things that if you have to ask, then no, you cannot do it.
Old 04-22-2013, 06:09 PM   #6
kinematics
Naw, I'm thinking about adapting WRX coilovers to my car and want to see if anyone else has done it. Those you linked me to run inverted and that is all I really need to know, if it can be done. Looks like it can be done so perhaps that is the path I am going to take as well. Or maybe I will do something different. That's the point of this forum isn't it, to have a discussion.
Old 04-22-2013, 07:15 PM   #7
John V, outside agitator
Wait a second. My head is packed wif snot and i can barely open my eyes without wincing but what you saying?
Don't get hung up on terminology, OK It only confuses and derails crap..
Coilover is anything when the coil goes over/around the shock/strut.
This is a coilover shock used on the back of a bunch of Volvos and Toyota RWD cars ANDS coil over STRUTS (and modded knuckkles)
Coilover shocks (these are swank aluminum 50mm Bilsteins)
These are Volvo 240 knuckles---which share the "ear" dimensions with Subie, you talking about modding your bottom knuckles?
What are you going on about in back..
That's real simple but probably seems a bit drastic for most of you guys...
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
John V, outside agitator is online now   Reply With Quote
Old 04-22-2013, 07:32 PM   #8
kinematics
Thanks john that's what I was looking for. Those knuckles would be great for up front on my car, basically I would like to be able to use Subie suspension components to bolt into my car, if possible. I mostly just wanted to see a discussion about it in this thread.
For the rear, what I'm asking is, is it possible to fab up something to make a subie coilover fit in the back as well? On the 7/9 the spring and strut are separate, but can the shock tower in back be modified to run a
Can you install them upside down due to the nature of how the shock bolts in the back? Can the rear shock towers be modified to fit something like this properly? Or will I just be laughed at right here.
Old 04-22-2013, 07:45 PM   #9
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Of course it can be modified. Cut and weld.
Fake Race Car
Old 04-22-2013, 07:50 PM   #10
kinematics
oh I'm sure it can, I just want to see who has done it and if there are pictures.
Old 04-22-2013, 08:03 PM   #11
Karl Buchka
I don't think anyone has ever adapted Subaru coilovers to a 740.
You seem like a bright enough guy. You're not asking about time travel, squaring the circle, cold fusion, or P versus NP. This isn't rocket surgery. If you have the means and the will to do it, then let nothing but fear stand in your way.
Old 04-22-2013, 08:03 PM   #12
Karl Buchka
Double post.
Old 04-22-2013, 08:06 PM   #13
kinematics
Or any coilovers? It doesn't matter, maybe I will do it. I can't fabricate but I have ideas. Will wait to see what John says.
Old 04-22-2013, 08:10 PM   #14
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
962j 815/692@27psi
THIS IS FORSALE V
Old 04-22-2013, 08:13 PM   #15
kinematics
cool nathan, that looks like a set up for drag racing is my understanding?
Old 04-22-2013, 08:22 PM   #16
nathaninwa
nathaninwa's Avatar
Its my DD. Suspension was redesigned for more anti squat, but not a full drag setup.
Old 04-22-2013, 08:28 PM   #17
mafoose
Boost Addict
mafoose's Avatar
It is my understanding that you can't run every strut/shock inverted. They have to be made with that capability, otherwise it screws with the dynamics of the unit.
- 84 242 - 92 740 - 72 240z - 78 280z -
mafoose is offline   Reply With Quote
Old 04-22-2013, 08:29 PM   #18
VQ
Not such a PRVert Anymore
VQ's Avatar
Just a random thought, an Impreza is a lot lighter than a 740/940 Volvo. Why would you insist so much on running suspension parts off another make and model when others are suggesting alternatives that work...
hellastock
Speed Bumps? No Problem.
264 GLE RIP
88 740T wagon
1964 122s
88 760GLE
Old 04-22-2013, 08:36 PM   #19
nathaninwa
nathaninwa's Avatar
The suspension on a 7/9 is just fine. When lowered you lose antisquat for forward traction, so I redid it to get it back when I installed a beefier rearend. The front you can get a Bilstein HD inverted strut and either run Bens stuff or install a sleeve yourself and have front coil overs too.
Cut, fab, reweld it.
Old 04-22-2013, 08:40 PM   #20
kinematics
WRXs are in the 3200-3400lb ballpark range as are 740/940s.
Old 04-23-2013, 07:19 AM   #21
grnmachine02
Indicating?
grnmachine02's Avatar
WRX dry weight is 3400 pounds~ My 745 corner scaled at 3300~ A sedan should be even lighter.
1990 745t- b230ft, ebay manifold, hy35, Microsquirt, t5 2jz and w58 eventually, and a lot of memories.
Rage boner achieved.
grnmachine02 is offline   Reply With Quote
Old 04-23-2013, 10:55 AM   #22
Mueller
Mueller's Avatar
Only 2 reasons I can think of....
He already has the parts or is a Subie WRX fanboi and thinks adding "WRX" parts to his vehicle will gain him street cred.
Old 04-23-2013, 11:18 AM   #23
doucheNozzle
doucheNozzle's Avatar
I'm confused on the insistance to use the Subaru stuff too.
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 04-23-2013, 11:35 AM   #24
nathaninwa
nathaninwa's Avatar
If one has a wrecked Subie, one should transplant the whole front and rear for awd brickness!
Old 04-23-2013, 11:37 AM   #25
Mueller
Mueller's Avatar
OP does not realize that when it comes to parts like these, besides slight geometry changes and slight valving changes these parts are not much different if installed on a Subaru, Dodge, Ford or Honda.
The brand (Bilstien or Koni or Monroe) is more important than what car the shock assembly was originally designed for.
