Old 11-30-2017, 11:07 AM   #1
Murploid1
Murploid1's Avatar
Default Anyone changed an AC drier?
I removed the AC drier from my 82 240 and it is significantly different from the aftermarket part I purchased from IPD.
The original drier has a plug for an electrical connection. Does anyone know what this is for? Is this some sort of safety device if pressures get too high?
Is it required?
Can I remove it and add to the new unit?
This is the drier I purchased:
https://www.ipdusa.com/products/1127...receiver-drier
I am not even sure what side is the inlet - doesnt say?!
Murploid1 is offline   Reply With Quote
Old 11-30-2017, 12:03 PM   #2
EivlEvo
I haven't looked at an R12 system closely TBH, but be CERTAIN you aren't looking at your ACCUMULATOR vs your DRIER as I believe they're different.
Old 11-30-2017, 12:16 PM   #3
J_Jones
J_Jones's Avatar
Can we see a picture of your stock drier? I changed mine out on my '87 245 this past summer and didn't run into this issue. You definitely need the 2-pronged switch though!
Old 11-30-2017, 12:18 PM   #4
J_Jones
J_Jones's Avatar
Not positive it's the same part number but this one looks like what I got:
https://www.ebay.com/p/Four-Seasons-...235/1937387727
Old 11-30-2017, 12:51 PM   #5
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
I always change out the drier after I open the system for good measure and reliability. I don't order A/C stuff from IPD. I purchased the FourSeasons r/d like J-Jones linked above(but from RockAuto) when I refurbed my Wife's 90 244. You need that sensor to allow the compressor to cycle. If it's a double-spade connector on the sensor, just order one from a 90.
For an 75-84 240
For an 85-90 240
-Stephen
#mclovethesenuts
Old 11-30-2017, 01:02 PM   #6
EivlEvo
But isn't the plug on the one posted originally just the spot for the sensor?
Old 11-30-2017, 01:56 PM   #7
KeizerBrickGuy
Sh*t pot stirrer
It is probable, but why not get a new receiver/drier with a new sensor in one purchase. The FourSeasons stuff is good, especially for the price.
Old 11-30-2017, 02:21 PM   #8
2manyturbos
The drier you linked to has a plug in it where the pressure switch goes. As long as the port size and thread pitch match your pressure switch, it will work.
Old 11-30-2017, 02:25 PM   #9
EivlEvo
Agreed, but if you already got the jawn... may as well slap 'er in there.
Old 11-30-2017, 10:11 PM   #10
NWVlvTnr
'83 Biege 245 DL DD
NWVlvTnr's Avatar
Yes, that is the low pressure switch, it is a normally open switch that prevents the compressor cluch from engaging if the pressure is too low.
Is it required?
It can be bypassed but that is not a good idea.
Yes, the new unit has a hex plug that can be removed and replaced by the low pressure switch, the new unit should include an o-ring for the switch or take it from the hex plug.
If it's not labeled I'm not sure how to help, with the pressure switch installed it should only fit with the switch facing awy from the radiator/condenser but its a stretch to assume that's correct. have you asked IPD?
NWVlvTnr is offline   Reply With Quote
Old 11-30-2017, 11:14 PM   #11
Cwazywazy
Cwazywazy's Avatar
I bought a cheapo replacement drier and had to remove a plug and move over the pressure switch from the old one.
I don't know what I have
Old 12-01-2017, 10:56 AM   #12
Locate where your low pressure switch is now. I forget. Then if you already have one, just leave that one installed, but unplugged.
Old 12-01-2017, 03:41 PM   #13
Murploid1
Murploid1's Avatar
Thanks for the responses guys. Very helpful!
