sideways242
- Nov 3, 2017
- Sacramento
These cars heavily depend on the MAF signal compared to modern cars. It runs with the MAF unplugged!? Next step is try another MAF.
Or.... you may have huge air leaks. I did a headskaget job just about a year ago and I had a loose hose clamp and it barely ran. I recommend you check all you idle air hoses and intake hoses and their clamps. I use a smoke machine. What also works is having it running and hose down areas heavily with brake cleaner and see if you can get it to stumble or stall.
Thanks for the advice, I'll try the smoke trick after work and see if I can find anything and report back!
