Old 09-13-2019, 10:41 PM   #1401
Texas240
Prius Owner
Texas240's Avatar
yeah, that's a concern I've had with the cd009, but in the world of V8 folks tend to go to higher rear ends unless they're running big tire setups (which still monkeys with your effective ratio anyway). 3.08 isn't uncommon at all. I gotta decide if I want to go to something like that on mine when I go 8.8, the 3.31 is fine for most things but starts to get a bit annoying on the interstate at 80-85mph. Of course, I don't really road trip the car all that often, so.. (but it'd also help with towing by being able to drop out of OD and not spin to the moon either)
I was looking at a 2.95 or 3.30 area when I put the Dana 36 c4 rear end in at some point never.
93 245 LS Engine Swap Project
Old 09-19-2019, 08:43 AM   #1402
JohnMc
JohnMc's Avatar
The wagon hasn't caught fire for a while now (w00t), but it does have a tendency to run on 7 or 6 cylinders when it gets all warmed up. I got a set of new coils and new plugs (still running whatever plugs it had in it from the junkyard). Not all that big of a task to do... other than those damn headers. I'm pretty sure they need to come off to get the plugs out.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-19-2019, 09:32 AM   #1403
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Sounds like it'll be ready for MM!
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 09-19-2019, 11:32 AM   #1404
patrickstar
patrickstar's Avatar
And impressions so far on the CD009/LS combo? Probably tainted by the 3.73 rear end. But overall gearing range aside (it's a little on the short side for a lower revving motor), it's just... too many gears? The thing has *grunt*, *oomph*, etc, but the gear ratios are so close together that you almost spend more time shifting than you do in the gear. *shift* *vroom*shift* *vroom*shift*.
Maybe I'll get more used to it and start skipping gears at some point?
Adding to that mess is that I apparently broke the little plastic pivot ball in the CBF shifter. Normally you wouldn't put much of a twist on the shifter stub, but I have an offset arm that repositions the lever back to where it needs to be. With a nut that holds it on, which means you twist the lever when you tighten that nut. I guess I should have held the lever firmly, it cracked, it's got some wiggle now. And it's already a bunch of gear (6 + reverse) in a very short throw area, so a little wiggle isn't helping. The CBF guy said he'd toss one in a box for free if I paid shipping, last Friday. Last check, maybe it will happen next Monday.
On the plus side, it is still mostly usable with the broken ball.
Obviously not the same, but my truck (nissan frontier) has a big V6 and 6 speed manual, and I feel the same way. Constantly rowing through gears. Now that I've owned it a while I've figured out which gears I can skip and lug it down a little. I usually do 1-2-4-6
patrickstar is offline   Reply With Quote
Old 09-19-2019, 11:54 AM   #1405
JohnMc
JohnMc's Avatar
Oh, and he did get back to me this Monday (when he said he would) and shipped that pivot ball out.
Old 09-19-2019, 09:26 PM   #1406
poulrais
poulrais's Avatar
Geez! Go get yourself a lottery ticket!
1990, Volvo 740 16v +T
Old 09-20-2019, 06:42 AM   #1407
DET17
Reformed SAABaholic
When I was looking into the T56 trans. as a conversion for my 70 Chevelle, I found that these later GTO's and Camaros all had a real desert gear in the back.... like a 2.56 to 1. I'm not sure how your first gear measures up to those.... but they are so steep to become near useless with moderate final gearing.
A GM sage quipped on the HAMB that a street driven performance V8 should target a total ratio of something between 10.0 to 11.0 torque multiplication in the lowest gear. I don't know how tall the gearing is in the 8.8, but you could abandon your trans OD gear and gain some "leg room" between shifts with such a numerically low final gearing.
Good luck getting those plug wires to stop burning up..... many of these tightly packed turbo V8's must suffer the same trouble without proper CMs (countermeasures)........
Old 09-20-2019, 08:57 AM   #1408
JohnMc
JohnMc's Avatar
And it actually showed up in the mail yesterday.
Haven't put it in yet, I was putting in new spark plugs.
Which sounds like a fairly mundane task... but it involves taking those headers off.
I'm starting to sort of regret those headers. If I'd realized what a nightmare they'd be in regards to spark plug wires and spark plug access...
Old 09-20-2019, 09:31 AM   #1409
stick70
All the gauges
stick70's Avatar
It's always got tons of room until you finish it and take a step back!
Old 09-20-2019, 10:09 AM   #1410
JohnMc
JohnMc's Avatar
And I did find an issue, which I was hoping to do. One of the wires had a burnt wire near the end. That was the one that was often missing, especially when hot.
There's no great solution for wires on a couple of cylinder on the driver's side, running a 90 degree ceramic boot and pointing the wire forward and running it out between the exhaust runners above and the collector below is really the only way to do it.
I originally had all 4 wires doing the same thing, 90 degree boots pointed forward, wrapping around under. But now I have a mixture of wires. A 135 degree short direct one in front, a straight short one on #2, a 90 degree wrapped around the front, and another 135 degree.
All I know is I'm bringing a whole bunch of spares and options with me on the trip to MM.
Old 09-20-2019, 11:18 AM   #1411
JohnMc
JohnMc's Avatar
I also got a stronger e-fan. I got a dual 10" fan setup that moves 1500 cfm between the two of them, mostly because it's pretty flat and fits in pretty well. But I just have a feeling that 1500 cfm isn't really quite enough. So I ordered a single 10" fan that pulls 2750 cfm and I'm just going to replace one of them for now. See how that works.
It's just slow to recover from heating up after some spirited driving.
Old 09-20-2019, 12:13 PM   #1412
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
like I said with mine, I haven't burned a wire since '15, I made 4 custom wires for the passenger side (the only side where stuff gets close), put the hi temp boots on em and then used fairly basic heat shielding stuff and looped the wires around the back of the head. As well as the stock manifolds weld, I should've hacked up the driver's side manifold instead of trying to make it all work with two passenger side manifolds (that worked great on the driver's side, but creates heat issues for coils and wires on the passenger side). I don't think I have a really good picture of any of it tho.
I also spaced the passenger coils up a little (and maybe back a touch as well, don't recall).
fake edit: spaced up and back from the exhaust on that side, looks like I bumped em up about an inch or so, and back... half an inch or so. I'll probably re-do a fair bit of it at some point but hell, it works and it's done.
sorting out the little things later is what separates the slops from the finishers.
Megasquirt Tuning!
Old 09-20-2019, 11:13 PM   #1413
JohnMc
JohnMc's Avatar
Finished up on the driver's side coil and plug swap. Stared at the passenger side for a bit ( it's a bigger job - downpipe and manifold have to get out of the way), and just let it sit for now. Took it out for a quick zoom around the neighborhood.
And wow, I'm not sure if it was running on all 8 before. Maybe 7. Dunno, but all of them are firing now and holy hell is it brutally fast. Before the boost would kick in and it would feel pretty stout, but nothing too silly. Now? Oh heck yes!
Old 09-21-2019, 02:27 PM   #1414
JohnMc
JohnMc's Avatar
Thing drove great going to and from Cars & Coffee today (hung out with SquareD for a while). Only issue I noticed was that when I got home and turned it off, it wouldn't start again. Not even a click from the starter. It was a wee bit heat soaked. I put a fan on it and it worked again after about 5 minutes. Still, not a great party trick. So I took the starter out and made a heat shield out of an old license plate. About a half inch air gap between it and the starter, shiny aluminum side out. Hopefully that will do the trick. Or I'll just leave it idling at gas stops on road trips.
Temps are nicely cooler here today, it ran nice and cool on the freeway, doing a few romps and pulls. It stays at 180, it would go up to 190 or so, then drop right back down again.
Old 09-23-2019, 08:42 AM   #1415
JohnMc
JohnMc's Avatar
I put 150 uneventful miles on it yesterday, just seeing if it would act any differently on some extended driving. All good, steady temps, nothing putting out weird smells, smooth, fast, comfortable. Only used a half tank of gas so it's not exactly guzzling fuel down either.
Old 09-23-2019, 09:30 AM   #1416
stick70
All the gauges
stick70's Avatar
Old 09-23-2019, 10:36 AM   #1417
linuxman51
linuxman51's Avatar
this all sounds exactly like what mine was doing lol. I got to the point where I could tell if it was missing based on how it idled and being a little lazy to spool up (but still plenty fast). It wouldn't lope or anything at idle, but it would shake the car a little. I didn't know what was going on at first because I had no idea what to expect so it took a bit to figure that out.
Old 09-23-2019, 12:34 PM   #1418
JohnMc
JohnMc's Avatar
It's very subtle - going down the line of coils and unplugged the connector one by one. The idle doesn't change very much at all.
Old 09-23-2019, 12:56 PM   #1419
propav8r
F*ck Edgar
propav8r's Avatar
I will never miss an opportunity to use this Classic Ng comic:
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 09-23-2019, 01:11 PM   #1420
cosbySweater
cosbySweater's Avatar
Yea it's funny how these engines still seem okay even when misfiring on one cylinder untill you get on it
1995 Porsche 993
2013 VW Passat TDI
Old 09-29-2019, 09:33 PM   #1421
JohnMc
JohnMc's Avatar
2000-ish miles on it over the weekend and I didn't have to touch anything. Running on all 8 every time I checked. Never overheated or did anything too rude other than drip a little gas out of the charcoal canister.
Only slightly iffy thing was getting stopped form 85 mph at a car crash, and then sitting there on a hill for about 20 minutes. The car kept creeping up degree by degree, to 220. Not an issue yet, but I was glad traffic started flowing again. It got a little warmer from time to time on the fast Mountain Meet drives, but not an actual issue, just something I need to get used to.
Old 10-03-2019, 11:56 AM   #1422
propav8r
F*ck Edgar
propav8r's Avatar
It was good seeing you this past weekend...my only regret is that I didn't make time for a ride in your car!
Old 10-03-2019, 12:02 PM   #1423
JohnMc
JohnMc's Avatar
It's laughably unsuited to the roads around there. Although it does handle pretty well, it was mostly a case of getting it pointed straight, bbbRRRAAP*HARD ON THE BRAKES*. Those little straights start feeling even shorter.
Old 10-08-2019, 03:20 PM   #1424
JohnMc
JohnMc's Avatar
I was crawling around it briefly on Sunday, seeing if there was room for an oil cooler up front somewhere. And modestly quickly realized that my cooler adapter (that bolts in place on the side of the block above the oil filter) wasn't going to work. The stock pan is completely flat along that plane, but the Holley pan has a sort of protruding lip just below the place where the plate or adapter bolts in place.
You can see it in their pic here - where the oil filter seal sits there's a semi-circular lip:
Not there on a stock pan (at least on the Hummer pan I still have laying bout:
That certainly put a halt on the oil cooler thing for now until I figure out what to do. Possibly an oil filter adapter - but I certainly don't want to push the filter down to where it's a low point.
I suppose I could always just put the filter out somewhere along the cooler lines. But I couldn't use a thermostat bypass then.
Old 10-08-2019, 03:24 PM   #1425
JohnMc
JohnMc's Avatar
Oh, and finding room for the cooler lines to go forward was proving to be a bit challenging, at least going underneath. There are hot things, moving things, etc all over the place. I'd probably need to run the lines up along the firewall, the over along the side of the engine bay to the front.
