Old 05-17-2014, 12:11 AM   #226
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Progress!!
Adapter back from Mueller! Amazing job, can't thank him enough!
Bolting it up!
BOOM, In the car!
Totally thrilled with the LMR mounts. They fit perfect. Looks like the position is as far as forward as you can get with the crossmember. Not sure how Jacob's mounts position but I'm sure it's about the same.
The Trans is about an inch to inch and a half forward of the ideal spot but who cares, just cut the hole forward.
YoshiFab cross member. Wanted the most amount of adjustment I could get. I might have to open one of the slots slightly but 3 out of 4 bolts are in. Hell, good enough. LOL
View from underneath
Going to have plenty of clearance on the exhaust side of the turbo and should be fine for the compressor housing.
So excited! OK, now to start working on the rear end, core support, intercooler and exhaust. Basically anything that'll require welding in, to, against the car.
Old 05-17-2014, 01:31 AM   #227
gsellstr
gsellstr's Avatar
Hell, you're almost there. You can have it running by the end of the month! lol
Looks like it really does fit in there nicely!
I might suggest an SN95 shift lever as it's got a nice kick-back on it to allow you room to move your hand without hitting the center stack. A little heat to straighten the bend so it clears the seat and it fits really nicely, nice and low. That with a hurst or tri-ax and you're set. Looked like the vertical height on that shifter setup is right where mine ended up on the 140 as well.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 05-17-2014, 03:26 AM   #228
Karl Buchka
That must be a huge motivation booster to see the engine and trans in the bay. Looks good!
The shifter ended up in almost the exact same spot on my old car. Enlarging the window a bit was all it took.
You should get in on the Buchka Engineering stainless + delrin shifter train.
https://lh4.googleusercontent.com/-n...hoto%25201.JPG
https://lh6.googleusercontent.com/-W...hoto%25203.JPG
Old 05-17-2014, 07:36 AM   #229
volvobrage
Looks really good!:D
Where did you buy that exhaust manifold, does it come for 6cylinder also?
volvobrage is offline   Reply With Quote
Old 05-17-2014, 08:18 AM   #230
Hank Scorpio
LOL Gary, yep running in a month! A month and two years probably lol
Yep. I'll be bugging you about that shifter. Actually I will want some height like yours,min planning on designing a console of some sort. I want real fawking cup holders!
It's a huge motivator to get the motor in the car! The nice thing is while I already have to start building and gearing up for the next round of trade shows end of the year, it won't be to insane till later this year. I'll get to enjoy a few months where I'll have some time to work on it.
Thanks! It's www.atpturbo.com 's 850 exhaust manifold. I wish they did a 6 cylinder version if they did I'd totally be running a t6 instead!
Old 05-17-2014, 10:46 AM   #231
Råda
Volvoretard/Partshoarder
Råda's Avatar
Looking really good
Jonas
Old 05-17-2014, 11:00 AM   #232
Johann
Johann's Avatar
Half way. Well done!
Johann is offline   Reply With Quote
Old 05-17-2014, 11:34 AM   #233
Hank Scorpio
Thanks Rada!!
Probably 10% done LOL. Really, this is mostly just to do anything welding/mockup related. Once all the things I'll need to weld, drill holes for or mount is figured out then it all comes apart again to start doing the painting stages.
Plus it's a good dry run for practicing how to get the motor in with out buggering the firewall. I think when I do it post paint, I'm going to leave the cross member out so the motor can go in at a flat angle. Then bring the cross member back up to it. That big 960 pan is a tough one to position into place with out banging the firewall.
Old 05-17-2014, 11:43 AM   #234
Johann
Johann's Avatar
The engine sits very close to the firewall, maybe to close to mount the gearbox. I damaged the firewall paint already. Now using a piece of rubber mat at the back of the engine for protection.
Old 05-17-2014, 11:52 AM   #235
Hank Scorpio
That was exactly my thoughts. I'll either use some of the thick rubber pads I keep on my work benches (for doing guitars) or use a moving blanket.
I ended up pulling the motor mounts off the crossmember and that made all the difference. (I have one of those load levelers for the engine puller so I could balance the motor and followed by using a jack under the transmission let it go in pretty flat).
Old 05-17-2014, 12:17 PM   #236
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Could you just put the engine in from the bottom?
Yet Asher here went with...
Old 05-17-2014, 01:53 PM   #237
Hank Scorpio
If I had a lift, absolutely.
Honestly, I'll just loosen the crossmember to drop it an inch or two and leave the mounts hooked to the engine (loose from the crossmember). That's more than enough.
Old 05-17-2014, 02:31 PM   #238
Dammit
+8cm
Looks awesome, the five cylinder is right at home there.
Bit of an odd question- do you think that the ATP manifold and your turbo would work/clear if this was a RHD car?
Not that I'm going to be doing anything like this anytime soon, but it's a (very) long term plan!
Dammit is offline   Reply With Quote
Old 05-17-2014, 05:49 PM   #239
Hank Scorpio
I don't know, honestly I'd put it at less than 50% odds. I think using the OEM manifold puts the turbo further rearwards which might improve steering shaft room.
There's a thread on here with a T5 in LHD and it looks like it worked well.
Old 05-19-2014, 11:47 AM   #240
Mesoam
Mesoam's Avatar
Did you have the ATP manifold in your parts bin from ages ago? I remember some issues fitting that in the FWD cars, looks like it'll do quite well on there! The WG placement is going to look pimptastic!
08 XC90 R-Sport
Mesoam is offline   Reply With Quote
Old 05-19-2014, 12:59 PM   #241
Hank Scorpio
Nope I bought it specific for this car. I think in FWD it works sort of. LOL
Planning on running the internal gate still I think. Looks like I have about 7" of room from the back of the exhaust housing to the firewall. Should be plenty of room to work with what I need.
Old 05-31-2014, 10:21 PM   #242
Hank Scorpio
Went to get sheetmetal, came home with this instead
Couldn't be more thrilled. EXACTLY the front and rear seats I wanted. The back is going to take a little work but looks more than do able. The S40/V50 rear seat is just a smidge wider well to well than the 245 is. I may need to have an upholstery shop open them up for me so I can trim up the internal sheet metal a bit. Power on both front seats too :D
Old 05-31-2014, 10:58 PM   #243
Texas240
Prius Owner
Texas240's Avatar
Like it was meant be. That looks amazing.
93 245 LS Engine Swap Project
Old 05-31-2014, 11:08 PM   #244
Hank Scorpio
Sure look the part. Thats why I wanted this particular set of seats instead of leather, for some reason they just look right to me with the cloth and gold stitching.
Designing up the seat adapters right now. Honestly, I just cut off the excess brackets on the front portion and used one of the 240 mounting points (the seats are about 2.5" wider C-C on than a 240). I actually really like that position in one regard because it improves "shoulder to shoulder" room but the reality is, I think when I add doors it would be to close to the outside.
So I drew these up
Should do the job just fine. Bolts right to the seat rails, just need to hack the vertical brackets off the old seats (did I save those? I can't remember... )
Old 05-31-2014, 11:24 PM   #245
wisturbo
wisturbo's Avatar
What will hold the rear seat in place?
wisturbo is offline   Reply With Quote
Old 05-31-2014, 11:28 PM   #246
Texas240
Prius Owner
Texas240's Avatar
Im not sure how big/ tall you are but I'd be interested in finding a set myself. Im a 6'2 175lb dude and have a hard enough time finding a good amount of car seats comfy under my knees and lower back.
How do these compare when it comes to longer road trips in the comfy area?
Old 05-31-2014, 11:46 PM   #247
Hank Scorpio
Well I have a 2008 C30 and a 2006 V50... there was a reason I wanted THESE seats Extremely comfortable.
I think you'll be able to get them plenty far back and I'm 5'8" 265lbs so more wide than tall. They will go pretty damn close to the floor but to get any lower you'd probably have to mod the floor (which had crossed my mind).
Honestly, I need to figure out what's power on the harness (and not accidentally set of an airbag!) and move the seat as far back and low as I can get it before finalizing my adapters.
I doubt you'd have a problem at 6'2" though.
Old 06-01-2014, 12:14 AM   #248
gsellstr
gsellstr's Avatar
Definitely curious to see how those seats fit in, and if they sit lower than the seats in the 140 I may be interested in swapping those in, as the height on the 240 seats is a bit much.
Hell of a score though!
Old 06-01-2014, 12:39 AM   #249
DaytonAE86
DaytonAE86's Avatar
Try and finda Chevy t5 back half, it moves the shifter back almost 2 inches.
Originally Posted by Toyotahead
exactly, 3 passengers, air con, and wu-tang at 180 mph
DaytonAE86 is offline   Reply With Quote
Old 06-01-2014, 12:41 AM   #250
Hank Scorpio
That thought has crossed my mind, but 2" might be too much. Honestly, a little sheet metal trimming and I'll be fine.
