Old 02-20-2014, 09:53 PM   #101
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Originally Posted by Stiggy Pop View Post
Busy business is a good problem. Take some pics of the blasted shell!
Ofcourse!
Old 03-20-2014, 04:40 PM   #102
Hank Scorpio
Well, the shell is still stuck at the strippers... I've been "2 days away" from being done for about 3 weeks now. LOL
In the mean time with some help from The Poi I worked out the T5/T5 adapter
(the green ring being the bellhousing side was before I verified that dimension this morning, it's much bigger than that).
Then mocked it up on my CNC. The bearing retainer and centering ring on the bellhousing side are just a hair looser than I'd like but an easy enough change. If there's any interest I can send the drawing off to Rodger-dee to have them made.
I picked this up from RSI a few months ago
Basically half finished T5 adapter. The ID for the bearing retainer is too tight but otherwise it's pretty good. Going to pass this off to a friend and let him finish it up for me.
Otherwise it's been pretty boring. Just been picking up parts where I can: Homers brake kit, ipd drop sways, these guys:
Those are the LMR T5 adapters. For the price, was better than fabbing something up myself. I have Jacob's car side adapters too which are now a bit superfluous.
I think this weekend I might start sorting through the crates of parts and start pulling out what I'd need to start the next stage:
Old 03-20-2014, 04:44 PM   #103
J_Jones
J_Jones's Avatar
If you are willing to send off all of your drawings and measurements for a T5-T5 adapter, that would be awesome to finally have this in production!
Old 03-20-2014, 04:45 PM   #104
Hank Scorpio
I should probably double check mine once I wrap it up but I'm happy to do it. It would be really easy to mill, you can do all the steps from the bellhousing side (just remember to tap the T5 side from the other side of the plate). I drilled all the holes, milled the step then cut it to shape all at the same time on my (wood only sadly) CNC.
Old 03-20-2014, 04:59 PM   #105
gsellstr
gsellstr's Avatar
Haven't had a chance to bolt it up in a 240 yet but I may have a literal bolt-in crossmember for the T5 with the exception of about 5 minutes with a grinder and installing 2 riv nuts into the frame rails. It's slightly different than my 140 but that simply means I need 3 riv nuts instead of 2 (yes, T5 is in, needs another hour of time and it should be on the road). lol
We can discuss this weekend if you want.
Glad to see progress on the powertrain!
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 03-20-2014, 05:02 PM   #106
Hank Scorpio
I was thinking I might do the yoshifab once because I like the exhaust clearance but who knows.
I still don't have a t5 for it yet anyways. I picked up a 40 dollar empty case to verify with though.
Old 03-20-2014, 05:16 PM   #107
gsellstr
gsellstr's Avatar
I'll snap some pic's tomorrow night when everything is installed. Clears the current exhaust setup with about 3/4" around it, plus it has clearance to run duals if you wanted. lol
Old 03-20-2014, 05:47 PM   #108
Mueller
Mueller's Avatar
Interesting adapter Doug, makes me wish I hadn't sold my extra 5 pot Whiteblock
Old 03-20-2014, 09:14 PM   #109
Hank Scorpio
Like that eh? It wouldn't be a DougK build with out some "natural composite" used in the process LOL
The brown portion is just a laser cut representation of a T5. I'll know if this worked out monday when the case shows up.
Old 03-20-2014, 09:31 PM   #110
Homer
OEMplus++
Homer's Avatar
I completely forgot you bought mine and now I'm angry. FURIOUS.
-Jacob:
2017 allroad - Comfy DD
Old 03-20-2014, 09:48 PM   #111
Hank Scorpio
LOL sorry about that
Old 03-21-2014, 06:01 AM   #112
narancs
narancs's Avatar
Originally Posted by Hank Scorpio View Post
these guys:
http://www.pbase.com/dkauer744/image/154906854.jpg
http://www.pbase.com/dkauer744/image/154906855.jpg
I'm curios how "comfy" they are.
I have 240 mount on custom bracket on the intake side which I'm sure is playing a big role of the shaky-shaky that goes on in my car..
'97 945 T5, mk1 IRS, NA cams, m90, 18T. COP converted Motronic 4.4 + Ostrich not gone.... but "changing"
'95 960 m90, 2.3 T5, VEMS, custom intake manifold... GONE
'97 850 T5m gone :(
narancs is offline   Reply With Quote
Old 03-21-2014, 09:49 AM   #113
Hank Scorpio
Well I'm guessing these will transmit more vibration but I doubt the motor will have much availing to shake with these. Looks stout.
Old 03-22-2014, 07:49 PM   #114
Hank Scorpio
Got word that I should be able to pick up the car monday! Had a bit of a free day today, probably the only free day till after the open house. When I stripped the car down I didn't really to do much organization, I just crated everything up I could and put the crates on top the lumber racks at the shop.
Today I pulled them down and started sorting stuff out. Then spent some time at the bead blaster and did the crossmember, control arms, firewall plates and a bunch of other little odds and ends. I didn't do everything, I figured I'd just work on stuff that'll be in needed during the engine bay mockup phase (next). Plus the tip on my blaster was pretty much worn out so it was slow progress.
(couldn't quite reach the ends of the crossmember in my blaster so I ended up doing those by hand after the picture)
Shot everything with 2k primer for now. I'm probably going to have to patch and shave quite a few holes in both panels (AC holes, wiring ones, some previous owner additions) so I didn't feel like using an epoxy primer for this. Just enough to seal up the surfaces for when I get to them next... in 6 months. LOL
Kind of a boring update... but gotta start somewhere.
Old 03-22-2014, 08:27 PM   #115
RvolvoR
just get them powdercoated....
Old 03-22-2014, 08:32 PM   #116
Hank Scorpio
I probably will but I want to patch all the unneeded holes. Didn't want to leave all the parts as raw metal that long. It's exactly why I used this 2k urethane, it's quick to sand/blast off again for welding and or powdercoating.
Old 03-24-2014, 11:08 PM   #117
Hank Scorpio
Empty T5 case showed up, everything lines up like it should. :D
Oh and this guy appeared in my trailer tonight
Old 03-25-2014, 12:19 AM   #118
:huzzah:
Old 03-25-2014, 12:36 AM   #119
Hank Scorpio
:huzzah:
Now we are getting somewhere eh? ;)
Hoping I can into the neighbors booth tomorrow.
Old 03-25-2014, 12:37 AM   #120
Lando
Arthur Digby Sellers
Lando's Avatar
I'm hoping the formica/partical board adapter is just a template.
Originally Posted by 11110000 View Post
I didn't think there was anything to the whole 7/9 thing, but I have to say that my 745T is the only Volvo I've owned that blew up and self-immolated.
Lando is online now   Reply With Quote
Old 03-25-2014, 12:43 AM   #121
Sooner is better, once it flash rusts it'll be a big job.
Old 03-25-2014, 12:47 AM   #122
Hank Scorpio
LOL ofcourse it is. I can't mill aluminum on my CNC but I sure as hell can make mockups in wood till my hearts content ;)
Yep. Tomorrow morning.
Old 03-25-2014, 01:10 AM   #123
The Full Banana
not yet good enough
The Full Banana's Avatar
Wow, that is quite the blank slate. John Locke would be proud.
-Tom 1980 242 T5
Old 03-25-2014, 09:40 AM   #124
slow240
Home Schooled
slow240's Avatar
Might have missed it, but what color?
I'll polish your face
Old 03-25-2014, 09:51 AM   #125
Stiggy Pop
Stiggy Pop's Avatar
It's really a sad statement about my life that these are the things I dream about; but I had a dream last night this car came up in some beautifully done but awful bright teal color. But what does it mean?!
That shell looks awesome! Going to be quite a car.
'79 242
943 pickup
