Old 08-25-2015, 12:30 AM   #276
Yes; it shows the equivalent of 14 psi on the gauge when warm. Last time I checked with a gauge it was around 28 psi at idle. It may be that the oil cooler brings it down significantly. Running synthetic 5w40 right now, which it seems to like. We'll see what's what once I plug it in.
Old 08-25-2015, 12:48 AM   #277
Addicted242boost
))<>(('s Avatar
5w40 is the nectar of the gods! (Rotella T6)
Down in CA where it gets monkey balls hot I run 15w40 (Rotella T5) to.
Is your car for sale?
))<>(( is offline   Reply With Quote
Old 08-25-2015, 01:51 AM   #278
It's always for sale at the right price!
Old 08-25-2015, 06:59 PM   #279
So an alternator belt exploded, making the power steering belt jump out of place. That was fun.
Upon closer inspection it appears that the front alternator pulley is ever so slightly dented. Must have happened when I accidentally dropped it. Whoooops.
Old 08-26-2015, 11:12 AM   #280
propav8r
F*ck Edgar
propav8r's Avatar
Ughh that buzzer. I miss that buzzer.
I should work on the '79.
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 08-26-2015, 12:41 PM   #281
Yes you should. You can '79 much better than me. Mine breaks all the goddamn time and it's always my fault.
Old 08-26-2015, 05:21 PM   #282
Quin
ಠ_ಠ
YEP
Old 09-02-2015, 01:13 AM   #283
Been working on little things here and there. Next couple items will be a sorely needed alignment and a torque damping solution for the engine block. It's vibrating so badly at idle that the somewhat solidly mounted exhaust is quite tiring to live with.
Otherwise I bought a set of intact and slightly faded headlamp bezels. Gave them a quick Plasti Dip spray and threw them on. Hides the crash damage nicely when the chrome rectangle is not broken up. Still looking for replacement panels or a good body shop. Been playing with the idea of doing a Kintsugi-style fix on these body panels. No idea how it would be executed, but embracing the bumps and bruises that this car has received, as opposed to hiding them seems more appealing to me.
Lucky over at ARD made this charge pipe out of old 240T stuff that I had laying around. He did a fantastic job, especially considering that he worked with old material. Eventually I will grind off the beads and have it, along with all other intake piping, intercooler, strut brace, brackets, and valve cover powder coated gloss black for a nice OEM+ finish. That will be once I get something else that needs to stay in one piece on a daily basis:
Old 09-02-2015, 07:21 AM   #284
sweet brace
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-02-2015, 10:21 AM   #285
Isn't it?
Gee, I wonder who made it...
Old 09-02-2015, 01:15 PM   #286
Duder
Comes with a free Frogurt
Duder's Avatar
I still think some PDR work on that fender would get it 95% of the way back to looking right. From the pics it appears that the paint only cracked in a few small areas, which could be touched up and blended without having to repaint the entire panel(s).
Engine bay is looking nice. Glad to read you made improvements in boost response and creep reduction simultaneously.
Old 09-02-2015, 01:24 PM   #287
PDR will do the trick on the fender, I agree. The core support is what worries me a little more. Hopefully it won't be all too bad.
As for boost: yeeees. It's so nice to drive now at 14 psi. I can only imagine how good it will be at 20
Old 09-15-2015, 11:46 AM   #288
Khrrck
Professional Amateur
Got a ride around the block in this last Friday. Quite the beast. Also sounds great.
'87 240 budget wagon.
Old 09-15-2015, 12:08 PM   #289
You are too kind! It felt slow to me
Old 09-15-2015, 01:43 PM   #290
Khrrck
Well, I had just gotten out of a N/A 245, so I think it was fast in contrast!
You definitely need to fix your self-pressurizing fuel tank though.
Old 09-24-2015, 09:28 PM   #291
Megasquirt going in this weekend. This is going to either be great, or a miserable failure. Bear in mind that:
A. All my tuning experience is in Ostrich and
B. This old POS is still my commuter.
Old 09-24-2015, 09:42 PM   #292
With megasquirt,,,, effort in usually correlates to how well the car drives if you know what you are doing. Its not that difficult, you just need to be patient, datalog, and be willing to dial in all the small stuff.
Old 09-29-2015, 12:20 AM   #293
It will get there eventually. It's all pretty straightforward and most of the challenging stuff that I was worried about is either automated or well-documented.
Anyway, the car is off for the nip and tuck (Asher kindly offered to do it for me) meanwhile I'm studying up the Megamanual, particularly Tunerstudio and Megalogger.
Meanwhile I'm dealing with a head cold and enjoying some time off work with the newest arrival to my family.
Old 10-04-2015, 08:26 PM   #294
I'm curious as to whether I'll be able to get this thing to crack the 300whp mark with the 577cc/min injectors in its current configuration. Cosbysweater predicts 260whp at 20 psi...
Old 10-06-2015, 03:50 PM   #295
Asher finished the Megasquirt install a couple days ago and loaded a basic map to the car. So far I have been tuning idle, cruise, and medium loads. Spark map seems almost spot on so far except for the high RPM/190-200 kpa range, where there is some minor detonation, and it's a bit rich at 100-180 kpa. No big deal. I'm not too big of a fan of autotune, it must be said...
Car already feels like it has picked up 20 whp up top and a ton of torque at part throttle boost, which is just awesome.
So far this is much easier than messing with Tuner Pro and Ostrich on LH 2.4. Pretty excited!
Old 10-06-2015, 04:06 PM   #296
tuning MS is far easier then tuner pro and ostrich
Old 10-07-2015, 12:31 AM   #297
Other than the random disconnects, yes. Yes it is. Serial to USB adapter cable gets a ton of noise...
Old 10-07-2015, 02:44 AM   #298
pyrosanltd
pyrosanltd's Avatar
here is the answer to your issues, or should be I use them at the datacenter I work at, most reliable USB to Com port adapter i have used so far.
http://www.amazon.com/Sabrent-Serial...al+to+usb+ftdi
It started with a screwdriver
pyrosanltd is offline   Reply With Quote
Old 10-07-2015, 08:51 AM   #299
Stiggy Pop
Stiggy Pop's Avatar
How come?
'79 242
943 pickup
Old 10-07-2015, 10:00 AM   #300
Buying!!
Originally Posted by Stiggy Pop View Post
How come?
I take it back. AFR table needed tweaking.
