Old 02-08-2015, 05:23 PM   #101
Yeah it's a real Momo, with the engraving at the back, with Momo branded bolts. Build quality looks on par with other Mod 8 wheels I have seen/touched. Gonna say real Momo.
Old 02-08-2015, 07:41 PM   #102
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Very nice. It looks great
Yet Asher here went with...
Old 02-09-2015, 02:32 AM   #103
As requested, beam pattern. I would say they are pretty damn good for H4s.
Old 02-09-2015, 02:46 AM   #104
iHateVolvoPeople
Is this thing still an auto?
Such a beautiful car, the automatic makes me upset.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 258k
'99 Camry A140E, 262k
'00 Camry A140e, 248k
The 2 party system is a mere distraction, and you're all falling right for it.
Old 02-09-2015, 02:58 AM   #105
The AW71 isn't too bad as long as you are used to driving with it. Sadly I don't have permission to throw $3000 to do a proper T-5 swap right now.
Between the bushings, LSD, and much quicker-spooling turbo it will be more than livable over the next year or two. Right now it's a mildly quick, comfy (still too loud) cruiser with extremely charming looks and a panty-dropping stereo.
Old 02-09-2015, 05:11 PM   #106
iHateVolvoPeople
I've heard the aw71 is awesome for an auto. It is one of the best looking 240's I've seen.
Either way I can't talk trash, I still have a glass m47 and the useless g80.
Old 02-21-2015, 04:42 PM   #107
The M47 isn't all that bad. I do hate the way that G80s work, though.
Just realized I haven't written about 75% of the things I have done to this car since I bought it. Oh well.
Gratuitous Cars and Coffee pics, courtesy of Nick Choy.
Old 02-28-2015, 08:50 PM   #108
So the cylinder head gave up the ghost. Was driving at part throttle, 12 psi, up a hill, misfire, cloud of coolant coming out the tailpipe. Pulled over and found that all the coolant drained out the exhaust. Awesomesauce BCP junk. Suspecting a mix of cheap waterpump, failing t-stat, BCP head, and semi aggressve driving as root cause. Car is at RSI now awaiting a freshly rebuilt hand-ported 530 head that I bought from Mr. John Gates, .027" and a Hepu water pump. While it's there the car will receive a new brake master cylinder, soft lines, and the Kaplhenke brackets. I'm going soft. Usually I would do this stuff in a weekend. Oh well.
Since the B21 uses an old k-jet head with valve cover vent, I decided it was time to go with fancy Yoshifab hardware and bought this:
It's seriously the nicest single-piece metal part I have seen. Props to sdturbo for making some amazing products!
In other news, the 19T kit and some injectors have been sold. I now have some cash freed to buy up some goodies to get this bad boy running
Shout out to the Dude for the hookup. Can't wait to get this thing going!!
Old 02-28-2015, 09:40 PM   #109
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
That turbo looks awesome. Who did you get it from?
Old 02-28-2015, 10:23 PM   #110
fortbrick
fortbrick's Avatar
Duder, I presume.
Cars looking great. I'm excited to get my vent installed too.
Old 02-28-2015, 10:54 PM   #111
Thanks! And that's correct: Duder kindly traded me this for a few parts I had sitting around. It's a pre-production GTX2860R. Compressor wheel is a tiny bit smaller than the production version.
Planning on using a Garrett T25 .64 AR turbine housing. Going to have to get a 90+ re-pinned to get it to work.
Old 03-02-2015, 09:21 PM   #112
So I screwed the pooch. There has been some part throttle misfiring aaaand the cooling system was over-pressurizing. Figured it was a combination of ****ty water pump, as mentioned a few days ago. I think a lot of it has t do with the fact that the head is/was BCP. Mr. Mollerstuen at work:
And then...
Not to worry though. Picked up a *very* freshly rebuilt and ported 530 head. ARP studs, hand ported, 3 angle valve grind...the works short of bigger valves and welding. I got it bucketed and shimmed this morning. Should be done by Wednesday:
Intake
Exhaust:
Old 03-04-2015, 11:40 PM   #113
Sitrep: it's mostly buttoned up. Ended up using a .027" MLS head gasket for a squish distance of .042" and static CR of 8.96:1. Turns out the head was skimmed only .0003", which is nice. Yoshifab PCV plate was not used. Turns out I received the wrong one. Luckily the shop needed one so it's getting used anyway. Pic of my pcv solution. It routes through a Greddy catch can to the stock port on the intake.
So it runs again...
...though a bit steamy. There was a gallon of coolant in the sump...
...sounds mean with the new head!
Old 03-05-2015, 01:42 AM   #114
pyrosanltd
pyrosanltd's Avatar
Aww common man tell us if the head made a butt dyno diff
It started with a screwdriver
pyrosanltd is offline   Reply With Quote
Old 03-05-2015, 02:07 AM   #115
Car has not moved yet! Brakes need some attention. Will report back ASAP.
Old 03-05-2015, 10:04 AM   #116
DanMarino
You should be very proud of your car. It's looking very nice.
DanMarino is offline   Reply With Quote
Old 03-05-2015, 02:33 PM   #117
Thanks!
Old 03-05-2015, 06:13 PM   #118
DanMarino
In that one photo is the head gasket all distorted around that cylinder? I wonder what caused that? Interesting photo, since I've never seen any of the head gasket jobs I've done have a gasket in that shape.
Old 03-05-2015, 06:17 PM   #119
cbevis
Just some guy...
cbevis's Avatar
^powar
FEEDBACK
cbevis is offline   Reply With Quote
Old 03-05-2015, 06:33 PM   #120
Originally Posted by cbevis View Post
^powar
Boost, light detonation, big coolant passage head.
Old 03-05-2015, 11:28 PM   #121
Lord_Athlon
300+ Clurb
Why does it keep popping in that last video
Old 03-06-2015, 12:02 AM   #122
15* base timing advance. Still runs weird at less than 20 degrees.
Could be several things:
O2 sensor (stays in stoich pretty inconsistently...)
ECT wiring (as above...)
Failing power stage
All other IOs seem to be working properly.
Old 03-06-2015, 07:37 AM   #123
oldschoolvolvo
oldschoolvolvo's Avatar
haha @ the smoke rings
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 03-06-2015, 08:00 AM   #124
adomz
Volvo 486 owner :D
adomz's Avatar
Cool. Liked the smoke rings haha. Keep it up! ;)
Errr.... 242... No engine no cringdingding...
=->Adam's youtube channel<-=
adomz is offline   Reply With Quote
Old 03-06-2015, 11:14 AM   #125
qwkswede
faster than you think
Cool turbo. Looks like a nice size for quick spooling tire burning fun.
Is that a GT ball bearing center?
-Ken
1967 Volvo 122S
1992 Volvo 745 driver
