Old 01-14-2020, 07:03 PM   #1501
you should just leave it completely stock. Its fine having a daily driver which hasn't been ****ed with.
Originally Posted by propav8r View Post
Good luck with the E39. I do NOT miss mine.
There's always flipping it and using the proceeds of that, the 245, and the V70 to put toward something with a warranty. And maybe butt warmers. And maybe Android Auto.
Wiper motor decided to get on the fritz. Ordered a replacement from IPD. I should really look into getting a windshield washer bottle as well.
Old 01-28-2020, 02:40 AM   #1502
Replaced the KL underdrive pulley with a nice stock replacement aftermarket harmonic balancer and put on an Aerostar/V6 slip yoke. Vibrations are now much more tolerable.
Also finally found the source of the suspension knock. One of the pockets for the bearings in the BNE strut mount was machined slightly too deep and thus allowing axial play. The gap was too small to fill with a shim so we used some Loctite 680. $100 in loctite, bearings, and shims to fix something that should not have been an issue to begin with. Not bitter or anything.
Now that those things are resolved/improved the car is a lit more enjoyable, especially on the highway. Nice linear power delivery and very surefooted handling, excellent brake feel. Having AC is also nice in our rainy winters, as the heater does not need to run at full blast to keep the windows from fogging up
Old 01-28-2020, 11:22 AM   #1503
LC4CARL
Aero challenged
LC4CARL's Avatar
Well done boss!
@PDXvolvo on IG
Old 01-28-2020, 11:32 AM   #1504
Stiggy Pop
Stiggy Pop's Avatar
I have not back-to-backed the crank pulleys. Is the switch back to the full size/weight pulley noticeable in terms of response?
'79 242
943 pickup
Old 01-28-2020, 12:05 PM   #1505
Originally Posted by LC4CARL View Post
Well done boss!
Thanks
Honestly I have not noticed much impact in throttle response, though it feels less nervous. Engine runs cooler though, which is nice.
Old 01-29-2020, 12:09 PM   #1506
SquareD
An Anomaly
SquareD's Avatar
You're probably better off just fixing the problem yourself anyway. Bne's had my (clunky) strut mounts since mid-December with almost zero updates.
1994 945ti | 15g @ 14psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 01-29-2020, 05:51 PM   #1507
It's done. No more clunk. Loctite did the needful.
On another note, I'm working on a passenger motor mount solution, to avoid valve cover-to-AC line rubbage.
On another another note, I'm tempted to replace the R-sport cluster with a digital dash display like a Haltech LC-7 or at least use CANBUS gauges to replace the round dials. They are inaccurate enough to be noticeably annoying to live with (close calls with speeding tickets, oil starvation scares...things like that). This would also free up the tailshaft gear in the trans to be used by an electronic pickup, which could send a VSS2 signal to the ECU, which in turn would drive the speedo/odo. More to come on that.
Old 06-16-2020, 11:59 AM   #1508
slovo240
slovo240's Avatar
Background...
You did all that but left it auto? Huh?
1986 Volvo 240dl -alternator death
1980 Volvo 244dl -rip
1993 Volvo 240dl -gone
1980 Volvo 242dl LA318 FI V8 swap
1998 Volvo v70 -dead
1982 Volvo 244gl sbc350 th350
1984 Volvo 245glt Jeep 4.0 w/4bbl blow thru carb turbo
slovo240 is offline   Reply With Quote
Old 06-16-2020, 12:07 PM   #1509
You may want to re-read the post you just quoted.
Old 06-16-2020, 12:10 PM   #1510
Broke4speed
Broke4speed's Avatar
Wait...wut?
Did you read post?
1984 244/ AQ140A / M46
Old 06-16-2020, 12:39 PM   #1511
culberro
culberro's Avatar
Lol, start from ~ page 52 and go from there.
http://forums.turbobricks.com/showth...304080&page=52
Old 06-16-2020, 12:49 PM   #1512
I should edit post #1. It is woefully out of date.
Old 06-16-2020, 01:19 PM   #1513
Ursan
Bored Member
Ursan's Avatar
Did you not see this is the entire quote that you didn't need to quote?
how psi a stock can support?
I admit I'm stupid...
Old 06-17-2020, 07:32 PM   #1514
SmokesLetsGo
PooPoo Pee Pee
SmokesLetsGo's Avatar
Wait what happened to the fuel filler door?
If trump has to destroy the country to get rid of the juggalos, so be it.
SmokesLetsGo is offline   Reply With Quote
Old 06-17-2020, 08:27 PM   #1515
volvowagoon
volvowagoon's Avatar
Most of his pics appear to be taken from the driver side, but the door looks fine to me?
1986 Buick Grand National - The show car
2002 Camaro V6 T5 +T - The fun car
2010 C30 T5 - My daily
1989 245 DL - Girlfriend's daily
IG: @v6buick
Old 06-18-2020, 12:19 AM   #1516
Vol242vo
Keep it clean...
Vol242vo's Avatar
First time seeing your 242 with those mesh wheels...Looked great. What were they and do you recall the tire size?
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 06-18-2020, 01:46 AM   #1517
I had sent it to Seattle along with a fender so that bergen could color match it to paint back in...2017? I got the filler door back...
Those were 16x8. Tires were 225/50R16.
Old 09-05-2020, 09:50 PM   #1518
Not much new since the last post. Tried some E39 M5 trans mounts to check whether any improvement could be felt vs. the Energy trans mount. No dice.
Other than that it's been pretty reliable and fairly comfortable other than that. Still need to turn up the boost and smooth out the cold starts, but don't want to **** with anything that will make it less reliable for any reason right now.
What I'm really pining for right now is the Bertone door panels, some decent front speaker enclosures, window film (it gets hot in the summer), and some reprieve from the rumbles
Old 09-07-2020, 02:17 AM   #1519
mblue240
mblue240's Avatar
I sprung for the Carbon Ceramic upgrade when when I had the 244 tinted. The % is about the same as the 242. The temperature difference in the cars is noticeable though and I wish I had paid for the upgrade on the 242. Drive to Highline with the car, they want to see old cars before they promise to work on it, remind them how easy the back windows come out and remove the door cards before you drop it off.
-Michael
Tbricks build
Yep, Michael is right.
Old 09-08-2020, 10:05 PM   #1520
SquareD
An Anomaly
SquareD's Avatar
Not sure on the tire size, but the wheels are 17x8 et20 BMW (BBS) e39 style 42 wheels.
Car looks great OP.
Old 09-08-2020, 11:06 PM   #1521
Vol242vo
Keep it clean...
Vol242vo's Avatar
Car looks great OP.
I was referring to Slovo’s post that he quoted from page 1.
ESMs 16 x 8 meshies. He must have edited his original post as it included all the pictures from the first page.
Old 09-09-2020, 09:32 AM   #1522
SquareD
An Anomaly
SquareD's Avatar
Woops, nevermind then. Haha.
Old 09-10-2020, 01:30 PM   #1523
RvolvoR
I think you should find an M90 to dump in it.
Old 09-10-2020, 04:13 PM   #1524
cosbySweater
cosbySweater's Avatar
I think you should find an aw71 to dump in it.
Ftfy
1995 Porsche 993
2013 VW Passat TDI
Old 09-11-2020, 04:29 AM   #1525
Quin
ಠ_ಠ
you say that...
