Old 05-08-2020, 01:24 AM   #51
Finnish240
Finnish240's Avatar
New battery, fuel- and oil filter with fresh oil are in. Car starts like it should and works fine. Fuel filter change was such a pain in the ass because banjo fittings started to leak, and leak wouldn't stop until I did put old copper rings back. New copper rings from my 50 piece sortment were too wide from touching surface. Next task was to install new wideband Bosch lsu 4.9 sensor. Old sensor stopped working last fall and Innovate showed only E8 fault code. Some times 22.4 was shown but it couldn't read any afr's right. Common issue with Innovate mtx-l.
Works and shows afr's how it should
Volvo 240 GL - not so low, but yes.... it is slow
Finnish240 is offline   Reply With Quote
Old 05-16-2020, 01:17 AM   #52
Finnish240
Finnish240's Avatar
So now there is some boost added, -18t makes 0.95 bars with additional spring and bleed. Needs +0.25bars more. It feels quicker of course, but it ain't a rocket. It needs more spring/new WG actuator.
We had some issues with my IC piping, one hose popped off three times during tune up and once when I was coming back to home. Piping is made of steel, so I will weld shoulders to joints.
I had odd lean running issue at idle and while test drive before tuneup. I used this topic -> http://www.turbobricks.org/forums/sh...d.php?t=272004
and my "tuner guy" but we didn't find anything. Car gets fuel, alot of it from fuel line, and FPR seems to work, injectors work, samw temps on each cylinder, working AMM, working harness, no leaks, only thing/parts that is changed are in last posts. After all the searching I unplugged resistor pack, since it has hi resistance injectors, and boom! 14.7 afr's. Year ago we tuned engine with bad battery, maybe the new one changed currents or voltages in critical points?
Old 06-15-2020, 05:32 AM   #53
Finnish240
Finnish240's Avatar
Not much have been changed since last post, now I have 1bar on clock and few odd spots on chip, but nothing majure to stop me driving the car. Car feels how it should have been from the beginning. I am not a photographer, but took some pics while enjoying how clean car feels.
Old 06-18-2020, 11:16 AM   #54
adomz
Volvo 486 owner :D
adomz's Avatar
Love this!! Great looking 240!! ;)
ADam
Errr.... 242... No engine no cringdingding...
=->Adam's youtube channel<-=
adomz is offline   Reply With Quote
Old 06-19-2020, 01:06 AM   #55
Finnish240
Finnish240's Avatar
ADam
Thanks, appreciate your words!
Old 07-31-2020, 06:02 AM   #56
Finnish240
Finnish240's Avatar
Question
M90 is working well, and feels good and fast enough for me. Last week I changed oils to it, and tranny feels bit smoother now. Car has changed a bit with new front splitter, it is made of poly ethane if I remember correct. Car feels more stable at 120km/h when cross winds blow.
Pic under the car
IMG-20200721-151204
New wheels arrived
IMG-20200731-090059
They are 59° North wheels D-004. 17*8.5 front/17*9.5 rear. Monday I will get some tyre on them.
Old 08-04-2020, 12:00 AM   #57
Finnish240
Finnish240's Avatar
Got the wheels wrapped and installed
IMG-20200803-182318
IMG-20200803-182256
IMG-20200803-182218
IMG-20200803-182333
IMG-20200803-182525
Old 08-04-2020, 01:11 AM   #58
Finnish240
Finnish240's Avatar
Double post
Old 08-04-2020, 01:55 AM   #59
R-Pow3R3d
Master of Disaster
R-Pow3R3d's Avatar
Wow, that's pretty!
1990 745 Turbo Intercooler
2007 XC90 V8 Sport
2007 XC70
R-Pow3R3d
R-Pow3R3d is offline   Reply With Quote
Old 08-04-2020, 08:01 AM   #60
JCol91
Macaracachimba
JCol91's Avatar
Love the new wheels!!
'95 855 Turbo - In hibernation
'93 244 N/A - 18" Eikers, IPD Sways, Eibach Red Lowering Springs, Bilstein Tourings, M47
IG: @stock_bricks
Flickr: @JCol91
JCol91 is offline   Reply With Quote
Old 08-04-2020, 08:43 AM   #61
Finnish240
Finnish240's Avatar
Originally Posted by R-Pow3R3d View Post
Wow, that's pretty!
Thank you, I like it too very much now
Thanks
Old 08-14-2020, 12:08 PM   #62
Finnish240
Finnish240's Avatar
Gave a good wash and waxed whole car. Next I took it for a drive and took some photos
Old 08-18-2020, 03:28 AM   #63
Pete.M
Slow Member
Pete.M's Avatar
I'm more of a 740 guy but there's something about a white 240. Especially this one.
Pete.M is offline   Reply With Quote
Old 08-20-2020, 04:03 AM   #64
Finnish240
Finnish240's Avatar
Nice to hear, I was really close to get 16V 740 ten years ago, but dad bought this for me.
Old 09-02-2020, 08:10 AM   #65
Finnish240
Finnish240's Avatar
This project is a slowly moving one, but progress is coming in future with new engine. I am going to rebuild it with H-conrods etc. Redblock of course, b230fk squirter block. I am still making decisions with turbo that it will have, maybe s200 borq warner, that need a rebuilt kit, or something with ball bearing.
Took some rolling shots with friends.
Old 09-02-2020, 05:05 PM   #66
GTJordan
Been here for too long
GTJordan's Avatar
Looks good! What are the wheels?
Old 09-03-2020, 03:19 AM   #67
Finnish240
Finnish240's Avatar
Thanks, they are 59° North wheels D-004 17*8.5"/9.5".
Old 09-26-2020, 11:03 AM   #68
Finnish240
Finnish240's Avatar
Few weeks till this goes to garage. plan is to make new exhaust, not sure tho will it be RST or regular exhaust pipe, size will be 3''.
Old 09-26-2020, 11:42 AM   #69
LC4CARL
Aero challenged
LC4CARL's Avatar
First class.
@PDXvolvo on IG
Old 09-28-2020, 09:14 PM   #70
whatshouldido
Great build , amazing looking 244 really looks so good! Do you have more info on the Bross Body kit stuff? Thanks looking forward to more!
---1991 volvo 745 turbo wagon
**m47 swap incoming !
--1977 244 360k+ miles all original
** drive till wheels fall off
whatshouldido is offline   Reply With Quote
Old 09-29-2020, 03:32 AM   #71
Finnish240
Finnish240's Avatar
Originally Posted by LC4CARL View Post
First class.
Thanks
Thank you! Bross kits were originally made from sort of plastic, but these copies that are sold nowdays are made of fiberglass. Mine has fiberglass copy parts in front that are made in Finland, skirts are genuine plastic pieces and rear part is made of broken Bross and original Volvo 240's rear valance. Front parts reguire two or few holes drilled on front fenders, but rest is bolt on.
