Old 07-25-2016, 01:33 AM   #326
amerbritcan
Hnnnnnng
amerbritcan's Avatar
No idea about your problem, mine is fighting me too, won't start, after Removing and reinstalling the alternator of all things. Like wtf it should run even if I somehow managed to eff that up.
Anyway, your car looks awesome with the trim on the front, and I love the fogs too! Very sharp.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 07-25-2016, 10:22 AM   #327
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx boss. Dang old cars...
@PDXvolvo on IG
Old 07-26-2016, 12:41 AM   #328
LC4CARL
Aero challenged
LC4CARL's Avatar
Reading the Bentley. Fuel pump fuses are good. Jacked up the car, engine running, hand on main pump, I can feel it "buzzing." Around back, remove the transfer pump floor plate. Cannot discern a "buzz" at the exposed portion of the pump. Disconnected the connector, 12v at one terminal, 10v at the other. To my surprise the car ran the same with the pump disconnected. Have I diagnosed a faulty transfer pump?
Old 07-27-2016, 11:15 PM   #329
LC4CARL
Aero challenged
LC4CARL's Avatar
Picked up a turbo transfer fuel pump, fuel filter, oil filters and special-ordered a carrier bearing from IPD today. These engines make so much power they require two fuel pumps.
Old 07-27-2016, 11:43 PM   #330
Make sure you replace the feed hose on the intank pump with the correct submersible hose.
Old 07-28-2016, 01:20 PM   #331
amerbritcan
Hnnnnnng
I would say yes, but at idle it probably wouldn't make a difference.
No harm in replacing it.
Old 07-29-2016, 12:28 AM   #332
LC4CARL
Aero challenged
LC4CARL's Avatar
Is this what I need?
https://www.ipdusa.com/products/5799...mp-upgrade-kit
Old 07-29-2016, 12:36 AM   #333
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I just installed this exact kit, the hose is a TIGHT fit around the pump, but it will go. Other than that, a straight R/R. Good luck!
1980 242 Turbo
2004 V70R
Old 07-29-2016, 12:45 AM   #334
LC4CARL
Aero challenged
LC4CARL's Avatar
Cool! What did you cut the tube with? Doesn't look there's enough room for the usual tube / pipe cutter.
It's a real bugger getting that sucker in and out of the tank.
Old 07-29-2016, 01:04 PM   #335
Uncleknucklez
bruspeed
Pulled the whole shebang out, and hacked it off with a cutoff wheel. Easy Peasy, just clean it off/out with carb cleaner when complete. I also bought a fuel filter, but didn't change that until after I ran the car a bit, figuring anything I missed would get caught in the old filter, and I could just swap in the new one.
Old 07-29-2016, 03:38 PM   #336
LC4CARL
Aero challenged
LC4CARL's Avatar
Brilliant. I'm on it.
Old 07-31-2016, 05:13 PM   #337
LC4CARL
Aero challenged
LC4CARL's Avatar
Transfer pump in, can hear it running at fuel filler. Replaced the fuel filter and that little hose that goes from the main pump to the filter. Oil change.
Ran fine for +/- 10 miles. Then started to buck again. Topped off the tank (I lost some during the filter change and the gauge said empty), ran fine for the rest of the trip. While I am optimistic, I'll need to run her for a few miles before I trust it too far.
Old 08-02-2016, 07:36 PM   #338
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 08-02-2016, 07:45 PM   #339
Uncleknucklez
bruspeed
Did you change the in tank fuel pump hose as well? Mine looked like this, and while it doesn't have to be ripped in half, it exhibited the same issues you're describing. I'll be curious to know how it runs with less than half a tank.
Old 08-03-2016, 06:41 PM   #340
LC4CARL
Aero challenged
LC4CARL's Avatar
Yikes! Yeah, the upgrade kit came with a hose. I think I measured correctly, but maybe the pick up sock is higher that it's supposed to be now. And, exactly why is the access hole so $##@! small?
Going to run her down town tonight with the half tank of gas. Cruise chicks, drag race some Ricers; all in a days work for a Volvo 245...
Old 08-04-2016, 01:05 AM   #341
LC4CARL
Aero challenged
LC4CARL's Avatar
Car ran beautifully tonight. Cool night air, light traffic, sporty exhaust - so fun. Fog lights fill in the sides of the road noticeably.
Got to fix the steering. I'm pretty sure the play in the wheel is the worn u-joints on the manual rack steering shaft. Not sure what to do. A new or reman shaft would be nice, but I doubt if there is such a thing. The car steered better with the power rack and no pump (less play / faster ratio). Anything wrong with running a power rack without the pump?
Old 08-04-2016, 01:38 AM   #342
Other than the fact it'll feel llke doggy do do?
Dude just get a ZF power rack and live a little...
Old 08-04-2016, 04:08 PM   #343
amerbritcan
Hnnnnnng
I've heard of people draining powered racks, filling them with thicker oil (in some cases grease) and looping the lines.
Old 08-04-2016, 04:45 PM   #344
quillc
yv1a.com
quillc's Avatar
Its likely not the U joints - its probably the 'rag' joint. The little rubber isolator. Volvo calls it a 'clutch'. They are expensive if you can find them.
Chris
www.yv1a.com
Old 08-13-2016, 12:07 AM   #345
LC4CARL
Aero challenged
LC4CARL's Avatar
Finally got out in the garage again. Got the trans mount out. The old one wasn't too bad (like the motor mounts).
The drive shaft support is super saggy. Got the shaft off. Does the bearing need to be pressed on and off? If so, I'll have the U-joints replaced. There appear to be small allen screws in the joints. If I back these out can I lube the joint with a needle?
Old 08-13-2016, 12:10 AM   #346
LC4CARL
Aero challenged
LC4CARL's Avatar
Couple of my old cars from back in the day.
'79 Mustang Ghia 5.0.
'84 GTI.
Turismo 2.2 (forget the year).
Old 08-13-2016, 12:11 AM   #347
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx. I'll take a look.
Old 08-13-2016, 04:44 PM   #348
LC4CARL
Aero challenged
LC4CARL's Avatar
Houston, we have problem...
I think I got the wrong bearing kit from IPD. The OD on the shaft is 1.75", the ID on the bearing is 1.25". IPD is closed today or I would swing by. Kit #106740 is the 2" unit, the kit I got, #106739, is the 1.75" unit. Dunno. Must be doing something wrong.
What is the benefit of swapping these cars to the one piece driveshaft?
And... I just found this on the IPD site:
FYI - The bearing diameter is determined by the OD of the driveline itself, not the bearing mounting surface OD.
Doh! I'm a dork.
Old 08-13-2016, 04:53 PM   #349
77volvo245
77volvo245's Avatar
Discount import parts are open on the weekends
STSmachining
Old 08-13-2016, 07:41 PM   #350
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx!
