Old 04-10-2016, 12:23 AM   #176
LC4CARL
Aero challenged
LC4CARL's Avatar
Got it! Thanks! Looks good.
@PDXvolvo on IG
Old 04-10-2016, 12:55 AM   #177
LC4CARL
Aero challenged
LC4CARL's Avatar
OK. Next problem...
I have three gauge clusters: The original, broken electric speedo / no tach. An old cable speedo with a tach. And a "working" electric speedo with tach.
I swapped in the "working" electric speedo / tach unit and the car would not run. So I unplugged everything and it ran. So, then took the tach out of analogue speedo assembly and put that in the original broken electric speedo and it runs, has a functioning tach, but still has the broken speedo.
So, why wouldn't the car run with the second gauge cluster? Was it grounding out the ignition?
Old 04-10-2016, 01:18 AM   #178
No idea, but I think 86-89 clusters are compatible.
Perhaps start a thread in maintenance & nonperformance, and our electronics expert Art Benstein aka cleanflametrap will noodle it out?
Old 04-10-2016, 06:51 PM   #179
LC4CARL
Aero challenged
LC4CARL's Avatar
Good idea. I wonder if the tach signal from the ignition was grounding out someplace. More mysteries.
Old 04-10-2016, 06:52 PM   #180
LC4CARL
Aero challenged
LC4CARL's Avatar
Went to the land fill transfer station. She went across the scales at 3250 lbs with driver and passenger. So maybe 2950 lbs for the car. Does that sound about right?
Old 04-12-2016, 11:09 PM   #181
LC4CARL
Aero challenged
LC4CARL's Avatar
Installed the IPD seat grid in the driver's seat. Scored $3.47 in loose change and some debris I'd rather not think about.
Old 04-13-2016, 12:31 AM   #182
LC4CARL
Aero challenged
LC4CARL's Avatar
I searched. Does a flat hood fit on an '87? If memory serves there's a cowl fitment problem.
Old 04-13-2016, 01:15 AM   #183
amerbritcan
Hnnnnnng
amerbritcan's Avatar
That's exactly right. It can be made to fit but there's issues at the cowl.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 04-13-2016, 08:45 AM   #184
Prime240
240 addict
Prime240's Avatar
It fits but it will not align as previously stated
1980 242GT /1992 245
Prime240 is offline   Reply With Quote
Old 04-13-2016, 04:17 PM   #185
LC4CARL
Aero challenged
LC4CARL's Avatar
The fit issue is where the hood drops in the center, but the cowl goes straight across?
Nice looking 240 BTW.
Old 04-13-2016, 04:33 PM   #186
Prime240
240 addict
Prime240's Avatar
Yes it is misaligned there. Does not affect function at all only form
Thx for the compliments but as you will find here the car is not as purdy as it used to be
Old 04-13-2016, 07:26 PM   #187
LC4CARL
Aero challenged
LC4CARL's Avatar
Wow. Of all the cars I have bought and sold, I think I have seen maybe one or two of them later. Really unusual.
I had an idea while I was jogging. You know how guys will jack up the back of the hood to vent under hood heat? Well how about a flat hood, jacked up so now the center is even with the cowl, but the sides vent over the fenders?
Old 04-13-2016, 09:54 PM   #188
amerbritcan
Hnnnnnng
That too has been done, but looks a little goofy.
Old 04-14-2016, 01:36 AM   #189
LC4CARL
Aero challenged
LC4CARL's Avatar
Hmm. In my mind it was cool.
Old 04-14-2016, 01:40 AM   #190
LC4CARL
Aero challenged
LC4CARL's Avatar
OK. Next problem...
Busted out the Bentley. Says if both the odometer and the speedometer are inop, to check the sending unit on the axle. Seems reasonable.
Old 04-15-2016, 10:41 PM   #191
LC4CARL
Aero challenged
LC4CARL's Avatar
Alrighty. Along the way, somebody had swapped the plastic relay for the metal one. Now the headlights work. Added a ground, replaced a bulb, and followed Redwood's tail light photos: brake, fog, tail and reverse lamps are not functioning. Woot!
Spent $100 at IPD. (Call it $2200 altogether.) New floor mats, etc.
Couple of junk yard runs. I think I have all the interior trim now.
Took the family out in her for the first time. Suspension didn't bottom with four inside. Good deal.
Having fun.
Old 04-17-2016, 12:26 AM   #192
LC4CARL
Aero challenged
LC4CARL's Avatar
Molding adhesive...
Gone.
Old 04-18-2016, 10:52 PM   #193
LC4CARL
Aero challenged
LC4CARL's Avatar
Is there something that holds the floor panel against the back of the seat?
Old 04-18-2016, 10:56 PM   #194
Yes there should be a hinged metal strap thing that controls that panel.
Old 04-19-2016, 01:01 AM   #195
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx. I'll take a look.
Old 04-20-2016, 10:41 AM   #196
LC4CARL
Aero challenged
LC4CARL's Avatar
About 1 1/4" of sag.
Old 04-24-2016, 06:24 PM   #197
LC4CARL
Aero challenged
LC4CARL's Avatar
Pleased with my moto / rack solution I headed out to the woods today. Cruising the center lane with another vehicle to my left, a semi swung wide and clipped the bike as I passed by. Two tie downs broke, two held. I drug the machine on her side for a short distance. Everybody is OK. Moto damage is not severe. No damage to car. Driver was cool. Meh.
Old 04-26-2016, 12:42 AM   #198
LC4CARL
Aero challenged
LC4CARL's Avatar
Spend some time with the polisher. Only burned through once! Looks way better.
Headlights cleaned up a bit.
Old 04-26-2016, 12:45 AM   #199
LC4CARL
Aero challenged
LC4CARL's Avatar
Went to another salvage yard. These cars are so plentiful. Always find something I need. Snagged two mirrors, a right tail lamp and a (non-rusty) lug wrench.
Took forever to get all that sealant (around the tail lamp) off the quarter. Yuck.
IPD Garage Sale in a month. Gotta keep moving...
Old 04-26-2016, 01:23 AM   #200
LC4CARL
Aero challenged
LC4CARL's Avatar
IPD photo contest contenders. Need input. Pick two:
