Old 07-09-2020, 10:31 PM   #551
Broke4speed
Broke4speed's Avatar
Took the valve cover off the AQ140A...and there's a 'D' cam in it. Absolutely no oil staining or baked on crud. It looks like a fresh rebuild, TBH.
There's no downside so far!
1984 244/ AQ140A / M46
Old 07-13-2020, 06:10 PM   #552
Broke4speed
Stopped by a local clutch company (Ottawa Clutch/Bully) to get a badly-pitted flat flywheel machined...and an hour later I had this:
I still have the AQ140A flywheel too, but it needs a lot of lightening before use. It's 4mm thicker than the stock flat one, and the rear recess is smaller too. It's HEAVY. I should sell it to STS, since they could probably make a useable one out of it .
I also did a bit of math and it looks like my adapter plate is going to have to be 1.25" thick if I stick with the SN95 input shaft. If I swap to the usual pre-94 one, the plate would be 1/2" thick. I guess it depends on which is more expensive...swapping shafts or a thick chunk of aluminum. I can definitely say it would be far easier to work with the thinner plate...but is it worth $200 CAD (ebay input shaft kit)...
Old 07-14-2020, 12:53 PM   #553
DET17
Reformed SAABaholic
It looks like you've decided to dive back into the cast iron tractor engine.... to each his own, I can't imagine leaving the inline 6 with it's modern tech versus the iron lump.
FWIW, I'm sure that DeeWorks makes a direct T5 adapter disk that registers into the whiteblock bolt on BH which is on your auto box behind the inline. I know that you know this..... but you really don't have to invent anything in order to built a whiteblock with T5 manual behind it. Most likely the slave issue is well resolved (check the Full Banana's 242 which I believe runs this trans).
That said.... carry on.
Old 07-14-2020, 02:40 PM   #554
Broke4speed
There's nothing wrong with the whiteblock, it's actually pretty great...but I think I'd like to run a redblock for a while .
It's all been done, so there's an easy recipe for everything I'd like to do. I have never built an adapter plate, so I'd like to try. I find dealing with Deeworks.ca...exhausting. Their communication is...lacking...and I'd rather not deal with someone I have to harass just to get a tracking number or a shipping update. It's always gone the same way when I've ordered from him, which I guess most folks don't mind, but it drives me up the wall.
Ultimately, the cost of putting a manual box behind a whiteblock is what put me off. The trans isn't an issue anymore, but the flywheel is a $700 CAD expense of it's own, without a clutch or pressure plate. Then there's the hydraulic conversion, which is just a bit of my time, but then I have to buy/plumb the master...and an internal slave...and it all requires lines and fittings. Even if I made the adapter, I'd probably be out another 2k CAD minimum before I could even think about driving it. Right now, I'm only into the redblock T5 setup for about $200 CAD, since I got most of it in trades or for free.
I'll keep the main whiteblock swap bits, like the bellhousing, mounts, oil pan, etc, for the future .
Old 07-19-2020, 08:46 PM   #555
Broke4speed
Further down the rabbit hole!
I want to run as close to original/simple as I can, so that involves a centrifugal/vac dizzy. The AQ140A came with a centrifugal points distributor, but I am a big supporter of vac advance (because it works!) so I set about converting it to vacuum. I've got a box of miscellaneous VW points distributors so I pulled the points mount/sliding advance plate out of one and replaced the static one in the Penta unit. I left the penta weights and springs in there for now, even though they seem a bit heavier than the usual stuff. It's supposedly all-in by 2800, which is fine...but it's a maximum of 36*-38*, which seems excessively high. Then I drilled a couple holes in the body of the distributor for the canister, and voila...done. I'll probably pertronix it, because as fun as points are, they're not for me. I want to run a pretty hot coil, and the last thing I want is to burn up the points.
Now, I'm not a total heathen, and I've run carbed cars in the past...but I do it in a modern way. I am KEEPING the Speeduino on board to datalog throttle position (I will retrofit a TPS), AFR (wideband staying in), coolant temp, air temp, and RPM. It makes tuning a LOT easier, because you can see exactly where each jet comes into play, and where the flat spots are exactly. I find that traditional carb tuning is not as good as the 'experts' say it is, and on a previous VW Rabbit on dual carbs I had, I managed to eek out 30mpg while not losing any power/torque. Now, it was a smaller car and only slightly brick shaped, but it was a mildly cammed 1.8L 8v. I haven't decided on my carbs just yet, I want to do more research.
Old 07-19-2020, 08:54 PM   #556
Broke4speed
Fun fact: If you remove the throwout bearing sleeve from an M47/M46 bellhousing, and enlarge the hole to 1 7/16", it's a tight fit over the T5 bearing retainer sleeve. This allows you to get a very positive register for marking the bolt holes on a DIY adapter plate . The one I'm making is currently at the machine shop getting a 4.9" hole cut in the center to line up on the transmission securely. It's not critical to have it dead center, but I wasn't about to try to use a huge holesaw on a piece of 1.25" aluminum plate. I should be picking it up tomorrow and I can get started on marking the holes.
Old 07-23-2020, 06:59 PM   #557
Broke4speed
I've started cleaning up the AQ140A and so far it's the best engine I've ever had. EVERYTHING is in great shape, and the oil pan is 100% rust free. The red paint on the block is still bright, and even the frost plugs are shiny.
I also got the first part of the T5 adapter done. I had a 2.8" hole cut in the bellhousing (due to mistakes being made on my part on the first try) and I'm going to make a locating ring that fits over the T5 release bearing sleeve and press-fits into the bellhousing. This will allow me to drill the bellhousing holes in the adapter and center everything. After that, I can cut off the excess material and make it nicer looking.
Old 07-24-2020, 03:21 AM   #558
TurboDutch
I like where this is goin!
TurboDutch is offline   Reply With Quote
Old 07-27-2020, 09:56 AM   #559
Broke4speed
I got the bellhousing back from the machine shop, and turned down some locating rings on the lathe at work. Once I make a rack to hold the transmisison bellhousing-up, I'll be drilling and tapping the holes. Then an Ironworker buddy of mine is going to trim the plate down with the plasma cutter at the Union hall. I did not relish trying to do it with a jigsaw or sawzall.
I put some time into cleaning the head, which was already ridiculously clean, but now it's better. I am going to try to use the AQ manifold somehow, so I drilled and tapped it for a brake booster port. The part that goes between the branches is a balance port, so it was a pretty convenient place to mount it. I have it pointing downwards, so it's mostly invisible unless you flip the manifold .
For the people who are slightly confused as to why I'm swapping the whiteblock out...let me tell you that I sometimes wonder that myself. The best explanation I can offer is that I just want to go back to a simpler engine. The B6304 is modern tech, and it drives like it. I miss the sound of an old cast-iron tractor engine, even if it's going to be much slower. A decade or so ago I found myself fighting with my own 'need for speed', and it was seriously affecting my finances (see username), and after being content with slow for a long time, the desire for more and more power was starting to get out of hand again. I have to step back but I don't want to give up my car...so the turbocharged temptation is coming out. Extreme, I know, but it works for me.
Old 07-27-2020, 03:10 PM   #560
Broke4speed
The dilemma.
Before the T5 fell into my lap, I got this M46. I ordered a bunch of stuff from IPD to refresh it (and let me tell you, the premium to get it all into Canada is NOT low), then found the T5 a couple days later after it was too late to cancel. I just put all the goodies into it (fresh gaskets, new O/D tailshaft seal, STS bronze shifter bushings, and an STS delrin clutch cable bushing.
Now...what do I do with it? If I use the M46, all I need is a clutch/pp and the engine could be swapped now. If I wait for the T5...it'll be fall/winter and I still need a ford 8.5" disc, volvo PP, throwout bearing of some sort, and a custom driveshaft piece. UGH, I had NO manual boxes and now I have too many.
Old 07-27-2020, 07:45 PM   #561
Broke4speed
Still not sure...but today the pertronix and bosch blue coil showed up .
Old 07-28-2020, 08:01 AM   #562
240wagonguy
I liked my M46, popping in and out of overdrive with a button press was convenient. Downsides, clunky shifting. Ford T5 is much tighter.
Old 07-28-2020, 08:17 AM   #563
Broke4speed
It's definitely driving me crazy. The M46 is a bolt-in affair, that would cost me a Rockauto.com clutch kit. The T5 is something I really want to do, but would require a bit more spending, and a trip to a driveshaft shop. If I hadn't ordered stuff to fix up the M46 before I got the T5, I'd just flip the Volvo box and work on the Ferd one.
I have nothing to lose by doing the M46, since my only concern is a dead O/D unit. If it is dead, then I guess I'll have 4 speeds while waiting to finish the T5 swap parts collecting. It would give me a chance to re-make a few parts that I'm not totally happy with.
I guess I've decided then. M46 for now, so I can finish the swap before winter (which is a concern, because I can't work on the car during the cold months and having something half-done will drive me batty). Then accumulate the rest of the parts I need for the T5.
Old 08-01-2020, 12:21 PM   #564
Broke4speed
As I was putting the exhaust studs in yesterday, I noticed something funny. Every single stud hole has been helicoiled. This engine has definitely been refurbished .
The 8.5" turbo clutch kit is showing up next wed/thurs, and then I can start to plan the install of the engine.
Old 08-01-2020, 08:57 PM   #565
Broke4speed
Never throw out your original power steering pump, especially if it has all the tensioner brackets on it. You'll find yourself buying stuff you shouldn't have to, ugh.
Thankfully a local dude had what I was after .
Old 08-03-2020, 03:48 PM   #566
Broke4speed
The adapter is done. It needs trimming, and I have no idea how far out from true it is, but I did it and I'm stoked. I need to get it trimmed, and figure out if I'm going to sacrifice the M46 bellhousing (although I don't have to mod it) or stick with the one that's on it currently, that means I have to use a Ford throwout bearing. Going with the M46 one means I can use the volvo bearing, but that's the only difference.
Old 08-03-2020, 11:24 PM   #567
robsvolvos
If you do end up installing that M46, keep in mind that it is an older unit from a pre-1979 car, so it has fewer splines on the input shaft. You may not be able to get a heavier duty clutch kit for it.
Rob
robsvolvos is offline   Reply With Quote
Old 08-04-2020, 04:15 PM   #568
Broke4speed
It's a 22-spline box .
Heading down to the local Iron Workers union hall on sat to use the plasma cutter and trim up the adapter. A buddy of mine (also a neighbour) is an instructor there and offered to let trim it myself.
Hell.
Yes.
Old 08-04-2020, 09:26 PM   #569
robsvolvos
Hell.
Yes.
Oops, I was looking at the pic in post#557, but now I’m realizing that this input shaft is the T5 tranny.
Rob
Old 08-18-2020, 04:17 PM   #570
Broke4speed
Well...it has begun. Driveshaft, exhaust, and auto shifter are all disconnected/removed.
I leave on staycation in a couple weeks, and I'd like to have the AQ140A/M46 in the bay at least.
Old 08-19-2020, 03:31 AM   #571
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Needs DCOE carbs, if not K-Jet or LH-Jet... If only for their intake sounds...
@john242ti on IG
Old 08-19-2020, 07:30 AM   #572
Broke4speed
DCOEs are the end goal, but I have particular requirements in that regard...and that means a fair bit of saving my pennies. A good set of Webers is not cheap, and Dellorto DHLAs (my personal favourite) are almost non-existent now (if you're looking for non-emissions versions, anyway). Not to mention needing to buy 4 of every jet/tube when tuning them. I want to be able to buy the carbs and a ton of jets at the same time.
I started tearing down the whiteblock for removal last night, and found a LOT of oil in the intake. Maybe this swap was a good idea...
Old 08-19-2020, 09:17 AM   #573
240wagonguy
Let me know on that whiteblock turbo manifold if wanna let it go.
Old 08-19-2020, 10:44 AM   #574
Broke4speed
Sure thing. Once I get it off I can check it for cracks and such.
Old 08-22-2020, 04:18 PM   #575
Broke4speed
It begins...
Did a bit of pressure washing to try to get more of the oil-coating out of the bay, removed the Speeduino/MS, and the POI-shift. Next up is to remove the shifters, and boost controller.
I'd really like to find a way to keep the existing Homer mounts, since they definitely provide a better mounting solution, IMO. The positioning is such that no extra torque mount would be needed to keep the crappy stock mounts from tearing and the engine from rocking.
