Old 05-05-2018, 08:44 PM   #251
cosbySweater
cosbySweater's Avatar
1995 Porsche 993
2013 VW Passat TDI
Old 05-05-2018, 09:36 PM   #252
122power
dude
122power's Avatar
I find it funny 740 is on your plate lol
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 05-10-2018, 09:36 PM   #253
cosbySweater
So after alot of going back and fourth with which turbo ls car to keep I decide the Volvo is going to stay. It's so well sorted for what it is and it doesn't feel like it's going to kill you like the Fairmont does. So next on my list is cam and springs. New turbo setup and some bigger injectors because I am currently maxed out on e85 with the 80lb injectors. Also it's getting a 6 point cage and it will be ready to so some real damage at the strip.
Old 05-10-2018, 10:06 PM   #254
THE MOST SORTED
Old 05-11-2018, 08:36 AM   #255
InTheWhite
InTheWhite's Avatar
Realy entertaining thread you got here! Like what your doing!
Old 05-11-2018, 12:00 PM   #256
cosbySweater
Thanks! I've really enjoyed it!!! It's also hilarious now when you can do 80mph rolling burnouts on the highway with the 215 tires. Haha
Old 06-07-2018, 02:20 PM   #257
cosbySweater
Cam is on the way! Hopefully next Sunday I can remove the old cam, and do a cam and valve springs in it. It will be interesting to see what cam it is, because I totally forgot which one I have.... Also picking up the turbo for it this Saturday. I'm half tempted to see if I can dyno it before the weekend for a base line run and see the improvements from just a cam and springs
Old 06-07-2018, 02:31 PM   #258
Stiggy Pop
Stiggy Pop's Avatar
does the cam come out with the engine in place when they're in a 240?
'79 242
943 pickup
Old 06-07-2018, 03:09 PM   #259
cosbySweater
Thumbs down
Yes it does, you just have to remove the radiator. On both my turbo ls cars I mounted the ic as far forward as possible just to make servicing alot easier.
Old 06-12-2018, 03:31 PM   #260
cosbySweater
Let's see if it's gonna clear the hood! Hoping it does, I measured the height from the exhaust flange to the center of the turbine shaft on both turbos and it's about 7mm taller overall and the center of the turbine shaft to the top of the compressor housing and it's about the same. It would be killer to not have to redo the hotside piping but we will see. Going with dual 44mm wastegates on the crossover this time and a exhaust cutout right behind the front wheel. Once the turbo and cam are installed it's going to a friend's shop for a 6 point cage and then back to the track. Right now with the gearing in the car it's geared for about 140mph at the top of 3rd at about 6500rpm. Last time at the track I was hitting 6900rpm so we will see. But hopefully after summer I can get some more track time with it and see what the car is capable of
Old 06-12-2018, 04:48 PM   #261
122power
dude
122power's Avatar
Is that from a semi? Lol
Old 06-12-2018, 04:50 PM   #262
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
195's and an open diff allow smoke shows at 100mph... these cars are stupid fun haha
Current setup - Aluminum L33/Summit Turbo Stage 2, Billet 80mm turbo, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 06-12-2018, 05:07 PM   #263
cosbySweater
No it's a gtx4202r.
Old 06-12-2018, 05:07 PM   #264
cosbySweater
Yea they really are. Especially with sorted suspension and a limited slip
Old 06-12-2018, 05:48 PM   #265
Duder
Comes with a free Frogurt
Duder's Avatar
Inb4 "it'll nevar spool"
Old 06-12-2018, 07:19 PM   #266
cosbySweater
Old 06-12-2018, 08:01 PM   #267
gsellstr
gsellstr's Avatar
Jesus man. That's like going from a 13c to a GT3071R for the rest of us. lol
If you wanna run up here in Sac, lemme know. I wanna see ya run, Ryan wants to run Betty and get some times, probably could drag a couple others out to watch the ****-show go down as you piss off the locals. lol
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-12-2018, 09:46 PM   #268
cosbySweater
I'll let you know for sure, I'm thinking about making a pass just after the cam and spring swap to see what it does.
Old 06-13-2018, 01:01 AM   #269
55superbeetle
Thats a baller turbo. The dodge d100 I did a turbo 5.3 setup in has a gtx4294r on it, he fell into a crazy deal on it after his ebay gt45 let go. Traps 130 on 15 pounds of boost at some hideous long bed american truck weight. Any reason you went with that over tried and true s400?
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 06-13-2018, 09:38 AM   #270
Tfrasca
Tfrasca's Avatar
Count me as a potential spectator. Would like to see some drags. (never been!)
Old 06-13-2018, 09:50 AM   #271
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I'll come run my junk and see what a 15 second car looks and feels like
1980 242 Turbo
2004 V70R
Old 06-13-2018, 12:13 PM   #272
cosbySweater
I basically fell into the same situation. Got a screamin deal on it. I was looking at getting into a force inductions s476r t4 but this kinda just happened. I really want to get some practice in and I would love to have this car do 140s in the 1/4. And as you can tell from my video I launched the car so soft off the line. I have a circle d tripple billet in it so I should in theory be able to do full lockup down the strip which will help too
Old 06-13-2018, 02:53 PM   #273
gsellstr
gsellstr's Avatar
Kinda bummed I didn't get to see you run when you were at Sac last time.
Sounds like we need a track night!
Old 06-14-2018, 11:34 AM   #274
cosbySweater
Yea it needs to happen. And honestly all you missed was the et. The car is so docile it isn't much of a show! Lol
Old 06-14-2018, 02:43 PM   #275
gsellstr
gsellstr's Avatar
All the better for trolling the kids at the track. lol
