Old 06-15-2018, 06:23 PM   #276
cosbySweater
cosbySweater's Avatar
Exactly, these dudes that ran their hell cat were making fun of it, and I ran the same time as them lol
1995 Porsche 993
2013 VW Passat TDI
Old 06-16-2018, 02:16 AM   #277
centason
Autogestion
centason's Avatar
And you spent less money to run the same time.
Member: TBCCS
"Those who do not move, do not notice their chains." -Rosa Luxemburg
Old 06-16-2018, 02:54 AM   #278
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
FTFY
Originally Posted by centason View Post
And you spent WAAAAAAAAAYYYYYY less money to run the same time.
1980 242 Turbo
2004 V70R
Old 06-17-2018, 12:38 AM   #279
cosbySweater
Soooo I did the cam and springs today. Went really smooth. Picked up a TON of power. Need to re tune it now.
so did look at the part number on the cam and it was a ls1 cam. So it is a late model ls1 cam so it was 198/208@50 idle sat at a very nice 21inhg, the cam in it now is a 228/230@50 and idle is around 12inhg. I'll take the loss because it sounds great and seems to work well. No cam bearings were hurt in the swap and no lifters fell in the pan
Old 06-17-2018, 09:43 AM   #280
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
You shouldn't have lost that much at idle. Tweak the AFR and timing to get some VAC back. Unless you are talking about at idle in drive?
Current setup - Aluminum L33/Summit Turbo Stage 2, Billet 80mm turbo, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 06-17-2018, 04:39 PM   #281
cosbySweater
Got the tune pretty dialed in it idles solid at 750rpm now and got it to about 16inches of vacuum. Pulled some fuel and added some timing. Backed off the timing up top due to the pump gas and compression in it. Accidentally hit 20psi on the highway which was awesome.
Old 06-17-2018, 07:19 PM   #282
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Those "accidental" 20psi hits are amazing.
Glad you got some vacuum back. Tweaking the tune usually helps quite a bit.
Old 06-18-2018, 01:43 AM   #283
cosbySweater
Yea in retrospect I probably should have gone with the smaller cam. But it's done now and I'm not swapping the cam again. I've got the fuel side dialed in really well, freeway cruising is at like 34degrees of advance and sits at around 15.5:1 which is where I was getting the best milage with the ls1 cam.
Old 06-18-2018, 12:45 PM   #284
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I bet it sounds amazing.
I have the sloppy stage 1 and do love it though. I'm on the baby 4.8 motor though, I wanted as quick of spool as possible. I went with a small cam(212/218) and a small crossover(1 7/8").
During cruise as well it's best to tune for maximum vacuum. It'll help with mileage too even though you may end up a little richer overall.
Old 06-18-2018, 01:09 PM   #285
cosbySweater
It's honestly no louder then the ls1 cam at idle, you hear a little chop but not much at all. When the wastegate opens at wot, it is alot louder. Also the valve train is a tad louder now
Old 06-18-2018, 01:32 PM   #286
Got life insurance?
Old 06-19-2018, 10:54 AM   #287
I'm taking out a policy on Erik
Old 06-20-2018, 08:24 PM   #288
cosbySweater
Lol it's getting a cage. Should be fine
Old 06-21-2018, 10:05 PM   #289
cosbySweater
Got the boost dialed to 15-16psi. It's absolutely hilarious. I feel confident at this point it will do 10s on pump. The cam and springs are so good in this car right now. I really need to dyno it and see what it makes on pump. I'm running very low timing and it's still a total animal.
Old 06-21-2018, 10:54 PM   #290
gsellstr
gsellstr's Avatar
Just wait until you get the new turblow on there. lol
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-21-2018, 11:14 PM   #291
cosbySweater
My goal is to run out of gear in the 1/4 so that means I need to trap 142mph
Old 06-22-2018, 01:31 PM   #292
Duder
Comes with a free Frogurt
Duder's Avatar
Sounds exciting! I've done 140 in my E36 Lemons car...not in a race but on the front straight at Willow Springs' big track. It felt utterly fine. I'm not sure how a 240 will behave at those speeds though. Any thoughts about aero and stability?
Old 06-22-2018, 01:46 PM   #293
JanP
JanP's Avatar
Looks fine to me:
https://www.youtube.com/watch?v=02hv4d2bkiM
-92 240 Wagon
JanP is offline   Reply With Quote
Old 06-22-2018, 02:34 PM   #294
cosbySweater
Yea I've done 130 in it a few times on the back roads and suprisingly it's actually very stable. I'm going to put a splash pan back on it. It feels like there is alot of turbulance in the front of the car but other then that it feels very very solid and controllable
Old 06-22-2018, 02:46 PM   #295
gsellstr
gsellstr's Avatar
I've done around the same in my wagon, really does feel planted. The belly pan should help a bit as well.
Old 06-22-2018, 05:55 PM   #296
M.H. Yount
M.H. Yount's Avatar
https://www.youtube.com/watch?v=H6Ni2gPo5Us
Old 06-22-2018, 06:19 PM   #297
Duder
Duder's Avatar
Well damn, I didn't realize this many folks were hitting 130+ in their 240s. Good to know! I guess I don't pay much attention to drag racing trap speeds.
The belly pan should help reduce underbody drag a bit.
Old 06-22-2018, 07:18 PM   #298
My car would get a little light in the rear end at 120 or so on the back straight of PIR, FWIW...
Smoothing out the bottom after the rear axle would do wonders.
Old 06-22-2018, 08:55 PM   #299
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
This is 3rd gear 6500rpm limter 25.5" tire 3.73 gears, wastegate pressure. Should be 130mph at top of third. I was shocked at how stable it was. 100% factory suspension.
Old 06-22-2018, 09:57 PM   #300
cosbySweater
Your car never went 120 at pir
